Dodge Fiberglass hood #2892617
02/24/21 10:58 AM
02/24/21 10:58 AM
ar.
bobs69 Offline OP
bobs69  Offline OP
ar.
Who makes the best quality Fiberglass hood for a 64 330?
Re: Dodge Fiberglass hood [Re: bobs69] #2892630
02/24/21 11:26 AM
02/24/21 11:26 AM
an8sec70cuda Offline
Check w/ Glasstek. They only show a stock flat hood on their website when you look up 63-64 dodge, but they will put whatever type of scoop on it that you want.
You won't find any nicer fiberglass body parts than Glasstek.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Dodge Fiberglass hood [Re: an8sec70cuda] #2892710
02/24/21 02:43 PM
02/24/21 02:43 PM
ar.
bobs69 Offline OP
bobs69  Offline OP
ar.
Thank you. All I need is a hood I have a scoop from another hood. Going to get the bolt on hood. getting too old for the lift off.
Re: Dodge Fiberglass hood [Re: bobs69] #2892745
02/24/21 03:43 PM
02/24/21 03:43 PM
Cab_Burge Online work
Cab_Burge  Online Work
I would check with Unlimited also, 877-735-7722.
The new owner has made this one of the best fiberglass body part company in the country now twocents
They make really good fitting and finish parts now, race or street weights up scope
Re: Dodge Fiberglass hood [Re: bobs69] #2892746
02/24/21 03:43 PM
02/24/21 03:43 PM
Wi.
old_racer Offline
old_racer  Offline
Wi.
Glass tek or VFN my VFN hood is awesome, bolt on. bottom of hood looks factory.
Re: Dodge Fiberglass hood [Re: old_racer] #2892869
02/24/21 10:28 PM
02/24/21 10:28 PM
BigFish69 Offline
BigFish69  Offline
Unlimted nicer quality better then the last glasstec hood i got
