Re: Inside car battery shut off [Re: Chief] #2892663
02/24/21 12:52 PM
02/24/21 12:52 PM
St.Pete,Florida
lancer493 Offline
lancer493  Offline
St.Pete,Florida
I wanted an interior electrical shut down for fire/crash senarios so I built one relatively cheaply after viewing Doug's (DVW) post w/pictures.Nearly identical to his except the bellcrank arrangement. It is similar all the way back to the master switch.Instead I just welded a short lever at 90* to a 1/2 nut with the threads drilled out. Added 2 set screws to opposing sides of the nut and slid the rear shut off handle rod through it. Now it is totally adjustable and can be locked down any where on that rod.Added an anchor bracket for morse cable to the nearby rollcage tube so that the cable ran parallel to rear shut off handle rod. No lever arc for the morse cable to follow. All on the same plane.Same idea, less parts. Thanks for the idea Doug.Appreciate the photos.Not very good at posting pictures on this site, but I can email picture of the rear section if anyone is interested. It is very simple to replicate and cost is very small. I have about $60 tiedup in the front control altogether with new morse cable and parachute style lever located on shifter mount. Bill
Re: Inside car battery shut off [Re: humpty] #2892671
02/24/21 01:14 PM
02/24/21 01:14 PM
Texas
Chief Offline
Chief  Offline
Texas
Originally Posted by humpty
I looked at those but couldn't figure out how to actuate them from two points. Either way - I can see tech having an issue with them. It would be a nice setup with a big red kill button within easy reach.
I haven't wired one, but I would think it would wire up similar to a light that can be turned on or off from a switch on either side of the room..
Dave Covey
Re: Inside car battery shut off [Re: Chief] #2892765
02/24/21 04:41 PM
02/24/21 04:41 PM
Minnesota
Hemi_Joel Offline
Hemi_Joel  Offline
Minnesota
Some of these solutions would make Rube Goldberg smile. penguinhat grin
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: Inside car battery shut off [Re: Hemi_Joel] #2892768
02/24/21 04:53 PM
02/24/21 04:53 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
haha
My solution to all this is to never turn the switch off unless the car is parked at home. Nothing on my car uses power when the key is off and I use a continuous duty solenoid for the alternator so even its not hot unless the key is on.
I'll be honest though, if the car sits in the garage a few weeks I always forget to turn the power on when I get in, luckily I am not belted up for that.
68 Barracuda Formula S 340
Re: Inside car battery shut off [Re: Hemi_Joel] #2892935
02/25/21 07:05 AM
02/25/21 07:05 AM
MN
JERICOGTX Offline
JERICOGTX  Offline
MN
Says the guy with 8- 2 barrel carbs on his 392 HEMI...
69 GTX 68 Road Runner
Re: Inside car battery shut off [Re: JERICOGTX] #2892936
02/25/21 07:09 AM
02/25/21 07:09 AM
MN
JERICOGTX Offline
JERICOGTX  Offline
MN
I've already sent these to Jeff, but here is mine. I'd never build another car that didn't have a inside cutoff switch. Couple tabs, a morse cable,(that is a shifter cable from B&M), some heim joints, and a lever. Done.
