Re: 92 W150 Leaf Springs
[Re: Hotlumpy]
#2891480
02/21/21 01:48 PM
02/21/21 01:48 PM
Posts: 18,414 UPPER MICHIGAN, MARQUETTE COUN...
NITROUSN
As far as I know the springs were the same from 1975-1993. There were several different weight ratings. The paper tag under the hood showed what springs you had. Most were all 3 leaf. Possibly the HD had 5 leafs. After market may sell a replacement spring that is basically one size fits all so you should replace both of them. All the springs were negative arch. Are you sure yours are bad? They are pretty tough. With the negative arch a lot of people think they are worn out by the look. If they are not riding on the snubber they are most likely ok. You might just need a good shock.
[Re: NITROUSN]
#2891501
02/21/21 02:29 PM
02/21/21 02:29 PM
NITROUSN
Here is the tsb. The year does not matter as they never corrected the problem. You could first try the new springs to see how it sits. My experience the heavier the spring capacity the less the lean. I dealt with this issue being a dealer with the suspension and dynamics division of Dodge. They were well aware and wanted to have left and right springs to correct this. However production wanted no part of doing this. So hence the leaner. Models: 1985-1988 "W"' & "AW" Series Four- Wheel Drive Vehicles
This bulletin supersedes Technical Service Bulletin 02-05-87, adding 1988 models.
Symptom/Condition:
Vehicle leaning or low on the left side
Parts Required: Spring Spacer Package 4397949 Consists of:
1 Spacer PN 4404171 2 U-Bolts PN 4404151 (Spicer Model 44 Axle) 2 U-Bolts PN 4404240 (Spicer Model 60 Axle) 4 Nuts PN 6029459
Repair Procedure:
This repair procedure describes the installation of a spacer block between the left front spring and axle assembly.
1. Using a hoist or hydraulic crane hooked to the towing eyes or at frame attachment, raise truck until weight is removed from front springs.
2. With wheels still touching the floor, install stands under side frame members as a safety precaution,
3. Remove the four nuts, lock washers, and both "U" bolts securing the left spring to the axle.
4. Raise vehicle slightly and insert spring spacer, PN 4404171, between spring and axle. Be sure spring center bolt aligns with locating hole in spacer and axle pad.
NOTE: ONLY ONE SPACER IS TO BE USED - DO NOT STACK.
5. Install the two new "U" bolts, new lock washers, and nuts and tighten until nuts push lock washers against axle spring plate.
NOTE. "U" BOLTS (SHORTER ONES), PN 4404151, ARE TO BE USED ONLY WITH THE SPICER MODEL 44 AXLE. "U" BOLTS (LONGER ONES), PN 4404240, ARE TO BE USED ONLY WITH THE SPICER MODEL 60 AXLE.
6. Remove stands from under frame and lower truck so weight is resting on wheels. Tighten "U" bolt nuts to 95 foot pounds.
Notes:
POLICY: Reimbursable within the provisions of the warranty
TIME ALLOWANCE: Labor Operation No. 02-27-05-90 . . . . . . . . . . . . . 0.6 Hrs.
FAILURE CODE: 6X - Weak
[Re: Hotlumpy]
#2891544
02/21/21 04:11 PM
02/21/21 04:11 PM
NITROUSN
And that later included 92 models? Not sure of the differences between ‘88 and ‘92 models. I assume the ‘88 ran the same Dana 44 up front, similar weight? I have the NV4500 five speed and 5.2 Magnum w/AC. As far as I know they are exactly the same. As far as weight the axle is un-sprung so that has nothing to do with the suspension.
[Re: NITROUSN]
#2891554
02/21/21 04:34 PM
02/21/21 04:34 PM
Posts: 15,851 Central Florida
larrymopar360
Stud Muffin
Stud Muffin
Central Florida
Remember, when you shim to lift one side, it will bring up the other side some too. Been there, done that. Just lift one side of your vehicle by hand (I know, not easy) while someone is holding yardstick to other side. You'll see, other side will come up approximately half or more of the side you are pysically lifting.
Facts are stubborn things.
[Re: larrymopar360]
#2891558
02/21/21 04:39 PM
02/21/21 04:39 PM
NITROUSN
Remember, when you shim to lift one side, it will bring up the other side some too. Been there, done that. Just lift one side of your vehicle by hand (I know, not easy) while someone is holding yardstick to other side. You'll see, other side will come up approximately half or more of the side you are pysically lifting. There is very little difference when shimming this way because it is un-sprung weight.
[Re: NITROUSN]
#2891641
02/21/21 08:13 PM
02/21/21 08:13 PM
Posts: 5,800 ohio
ruderunner
ohio
My observations over the years, 3 leafs go with Dana44 and the 5 leaf goes with Dana 60.
I've never experienced the drivers side sag.
I've not noticed a big difference in ride with either spring. Bigger improvements are in shocks and tire pressures.
Angry white pureblood male
[Re: ruderunner]
#2891658
02/21/21 08:57 PM
02/21/21 08:57 PM
larrymopar360
Stud Muffin
Stud Muffin
Central Florida
Thankfully my '79 W150 doesn't have sag. I've seen plenty for sale with it. I was looking to buy a D150 that had a severe case. I even bought a set of the horse shoe like leveling shims for coils to use on one side (someone here showed them to me) in anticipation of purchasing the truck, but that fell through. I still have them.
[Re: larrymopar360]
#2891935
02/22/21 05:27 PM
02/22/21 05:27 PM
Posts: 2,228 ILLINOIS
volaredon
ILLINOIS
I never knew of an issue with the 4wds but it was a known issue on certain years of the 2wd trucks. I've replaced the fronts with Moog Cargo Coils on the 2wds to eliminate the lean before. If it wasnt noticeable til 130K (unless that was when you 1st got it) there is a good chance it is just from normal wear and tear, when you are teh only person in the truck, you are on that side. The gas tank is also on that side. After several years it would not be surprising for a truck to lean that way. When I was an alignment guy, often (not always) all I had to do on vehicles with torsion bars (especially trucks/ and at that, especially Chevy S10s and S10 Blazers) was to crank the torsion bar on the low side to match the height of the high side, and the alignment would mysteriously and magically come back to "dead nuts". Alot of times no need to mess with shims or cams to bring them back into alignment. Often the driver side would be 1-1/2" lower at the center of the front fenderwell vs the passenger side, and if I had to then make further adjustment, it was usually on vehicles that had previously been aligned, while the truck had the lean. Before I sent my Durango in for alignment I made sure that my front end was level and cranked up to where it needed to be. (I no longer have alignment machine access, wish I did)
also if there is a problem in one corner, it will be also noticeable in the diagonal opposite corner.
[Re: volaredon]
#2892780
02/24/21 05:35 PM
02/24/21 05:35 PM
larrymopar360
Stud Muffin
Stud Muffin
Central Florida
One thing that can help for anyone with the lean is getting a lithium battery (someone here was recommended to me when I just wanted overall weight savings). HUGE weight savings over standard battery. Takes some weight off that corner. They are more expensive, but supposedly they are much longer lasting and make up for the extra cost. I got a braille group 34. Their weight is somewhere between 5-10 pounds!
