Re: oil questions/ zinc...... [Re: CompSyn] #289089
04/16/09 10:41 PM
04/16/09 10:41 PM
albany ny
0
05dakota Offline
05dakota  Offline
albany ny
so the solution is oil thats $10.75 a qrt?
Re: oil questions/ zinc...... [Re: 05dakota] #289090
04/16/09 11:30 PM
04/16/09 11:30 PM
Wilmington,NC
I
I go fast Offline
I go fast  Offline
I
Wilmington,NC
If you're an oil salesman!
Re: oil questions/ zinc...... [Re: 05dakota] #289091
04/16/09 11:42 PM
04/16/09 11:42 PM
Pacific NW USA
CompSyn Offline
CompSyn  Offline
Pacific NW USA
Not exactly. It doesn’t have to be that costly.
That same oil is $8.30 per quart with the Amsoil Preferred Customer membership. Or a less costly alternative could be Synthetic SAE 10W-30/SAE 30 Heavy-Duty Motor Oil (ACD) . The ACD works out to $5.97 per quart Preferred Customer cost.
ACD 10W-30:
Zinc content 1339ppm
Phosphorus content 1180ppm
Around the 1200ppm mark for Zinc and Phos., is considered to be adequate for flat-tappets.
Also, consider the cost of a quality alternative motor oil plus the cost of an aftermarket additive. The two added together is getting up there in price. In the end what’s the difference in price, $10-$12? And if you go that rout, you’re not guaranteed 100% compatibility of the motor oil additive package to the aftermarket additive. For example are you going to end up with oil foaming tendencies by using a motor oil and aftermarket additive? That's happened.
One oil product, one cost, no worries… Some like to go that rout, but not all.
CompSyn
Re: oil questions/ zinc...... [Re: Junky] #289092
04/17/09 10:20 AM
04/17/09 10:20 AM
Wherever I am.
Junky Offline
Junky  Offline
Wherever I am.
Stock or mild builds with flat tappet cams like at least 1200 ppm zinc. Major builds more, due to stronger valve springs etc.
I run 5W40 Shell Rotella T full synthetic which has close to 1400 ppm zinc. Most, if not all, heavy duty (diesel) motor oils have a good amount of zinc. Racing oils too, but may not be suitable for every day cruising. www.bobistheoilguy.com has tons of info.
I read on Bob Is The Oil Guy's web site a used oil analysis stating that the new CJ4 Shell Rotella T (SRT) 5W40 full synthetic at about 1380 ppm zinc. Last night I emailed Shell's tech, who responded back that their newest CJ4 SRT 5W40 has 1200 ppm zinc.
2010 Black Challenger SE <> 3.5 V6
Custom Shift Knobs www.flameball.com Check It Out
Re: oil questions/ zinc...... [Re: Junky] #289093
04/17/09 11:18 AM
04/17/09 11:18 AM
hooziewhatsit Online content
hooziewhatsit  Online Content
Chevron Delo 30wt has ~1200ppm zinc according to their datasheet for it. Here it costs me $13/gallon.
Re: oil questions/ zinc...... [Re: hooziewhatsit] #289094
04/17/09 12:22 PM
04/17/09 12:22 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
Just found a bottle of Lucus additive at Advance for $12. It has zink and some other stuff in it "specially formulated for engines using flat tappet cams" It's a break in lube + additive.
Coming soon!!!!
Re: oil questions/ zinc...... [Re: Mr.Yuck] #289095
04/17/09 12:47 PM
04/17/09 12:47 PM
Wilmington,NC
I
I go fast Offline
I go fast  Offline
I
Wilmington,NC
Just so you know,oil is blended for specific applications.Additives can and will change the properties of oil or any thing else that is diluted which is what you are doing when adding anything that was not originally blended in the original product.And,unless you have an analysis actually done what you read and what you are told is only hearsay.
Re: oil questions/ zinc...... [Re: I go fast] #289096
04/17/09 01:03 PM
04/17/09 01:03 PM
I totally agree with the comments about buyer beware. Back when all the SM oils came out, I contacted many of the oil mfgs and was told SM was fine for flat tappet engines. Now we now better. Even after the issues came up, when I contacted Amsoil, they wouldn't tell me how much zinc was in their oil, but it was enough. I had two pushrod failures on Amsoil diesel oil back then, change oil to another brand and no more problems.
I like to run the motorcycle oils, as they have all the additives you need, without the extra stuff in diesel oils that you don't need.
I like this in 5W40 for drivers and our motorhome and in the 20W50 for the TT340 Chally.
http://www.castrol.com/castrol/sectiongenericarticle.do?categoryId=9021703&contentId=7040544
Re: oil questions/ zinc...... [Re: I go fast] #289097
04/17/09 01:06 PM
04/17/09 01:06 PM
chatham, Ilinois
fox Offline
super street
fox  Offline
super street
chatham, Ilinois
Guys, if you can find a Schaeffers retail store, or a rep and buy in voluume, you can buy it for $4-5$ a quart. Ask for a demo, this oil will protect the flat lifter.
Re: oil questions/ zinc...... [Re: fox] #289098
04/17/09 02:28 PM
04/17/09 02:28 PM
La Grange, Ky
70rrclone Offline OP
La Grange, Ky
i have contacted Lucas oil about the zinc content of there line of conventional oil's. i'll post the results when i get them
shane
Re: oil questions/ zinc...... [Re: Mr.Yuck] #289099
04/17/09 09:32 PM
04/17/09 09:32 PM
Pacific NW USA
CompSyn Offline
CompSyn  Offline
Pacific NW USA
Is it Lucas Oil Stabilizer or another product. Just curious. Below is some information on Lucas Oil Stabilizer.
Click HERE for thread on Lucas Oil Stabilizer.
Click HERE for a look at bench test with Lucas Oil Stabilizer.
Re: oil questions/ zinc...... [Re: CompSyn] #289100
04/18/09 01:39 PM
04/18/09 01:39 PM
Renton, Wa.
Classof70Chally Offline
super gas
super gas
Renton, Wa.
They have two different products. One is an oil stabilizer/smoke reducer similar to 'motor honey'/stp, etc. The other is a zddp additive and motor/cam break-in product. It comes in a 16oz bottle and states that it is not to be used in 1994 or newer cars as it will trash the convertors. I used a bottle to break-in my recent 440 bullet in my sig car and just picked up another for an oil change.
