Co-worker loses her 57 due to the snow storm
#2890951
02/20/21 12:01 PM
02/20/21 12:01 PM
Posts: 19,955 Puttin' on the foil in Charles...
not_a_charger
Mr. Big Shot Moparts Moderator
She and her family live in Mississippi. The roof of their 60x60 shop collapsed, and the beam landed directly on her 57. The truck was just completed 2 weeks ago. Her husband's C10 (his grandfather is the original owner) had the roof land on it, but it only resulted in a 2 inch scratch to the paint, thankfully.
Her husband also runs a custom parts/accessories business out of this building, so the impact is greater than just the damage to their personal property.
Earning every penny of that moderator paycheck.
DBAP
Re: Co-worker loses her 57 due to the snow storm
[Re: Mastershake340]
#2890990
02/20/21 01:00 PM
02/20/21 01:00 PM
Posts: 3,318 Southern Maryland
klunick
Southern Maryland
I'm thinking that can be rebuilt with a donor. Just a point, take a look at that beam. Does that not look like the beam actually snapped?
67 Barracuda FB
69 Superbee
"Southern Maryland: If you want a good looking woman, you had better bring her with you"
[Re: DrCharles]
#2890992
02/20/21 01:00 PM
02/20/21 01:00 PM
not_a_charger
Yeah, the weld appears to be a concern. Regardless, I doubt that codes in MS are similar to codes in the Northeast/Midwest, because how often do they get snow like this?
DBAP
[Re: ChryCoGuy]
#2891018
02/20/21 01:28 PM
02/20/21 01:28 PM
Posts: 994 rust belt
Moparite
rust belt
I'd hazzard a guess that that was not an engineered building. Just out of curiosity, where's the beam that's supposed to be supporting that I-beam ?? I'm not the only one who noticed this! If you look at the end of the "I" beam it look like somebody welded a plate on the inside. This is not the way to weld I beams together. Back yard builders probably. Hopefully either the vehicle or homeowners insurance will cover it. And have somebody skilled rebuild the roof.
[Re: not_a_charger]
#2891030
02/20/21 01:59 PM
02/20/21 01:59 PM
Posts: 11,684 W. Kentucky
justinp61
W. Kentucky
They did not build the building themselves. I'd be having a conversation with my contractor then.
[Re: Moparite]
#2891110
02/20/21 04:10 PM
02/20/21 04:10 PM
Posts: 10,228 Colleyville
3hundred
Colleyville
I'd hazzard a guess that that was not an engineered building. Just out of curiosity, where's the beam that's supposed to be supporting that I-beam ?? I'm not the only one who noticed this! If you look at the end of the "I" beam it look like somebody welded a plate on the inside. This is not the way to weld I beams together. Back yard builders probably. Hopefully either the vehicle or homeowners insurance will cover it. And have somebody skilled rebuild the roof. IMHO as a structural steel fabricator, this was not a complete (PEMB) pre-engineered building kit. Somebody went to MBCI, Mueller Supply or similar and bought purlins, panels and other components and pieced something together. From what I can make out, looks like really crappy workmanship. I don't know if Mississippi has contractor licensing, whether this area requires building permits or whatever else that would give at least an illusion of competence here. If nothing else works out they could roll the dice on a lawsuit. 2ยข
'68 Fury Convertible '69 300 Convertible '15 Durango 5.7 Hemi '16 300 S Hemi
[Re: justinp61]
#2891116
02/20/21 04:14 PM
02/20/21 04:14 PM
Posts: 7,495 Minnesota
Hemi_Joel
Minnesota
That's really sad that that happened. Hopefully they can get that truck fixed and get their shed rebuilt.
About 20 or 25 years ago, a guy in our car club had his entire collection of really nice cars severely damaged when his pole barn collapsed under a heavy snow load. The issue there was that overhanging trees had caused an accumulation of sap on the metal roof panels, which made it sticky, so the ice and snow didn't slide off easily, leading to a heavy buildup. At least that's what he said afterwards. Because of that, I watch my pole barn roof very carefully. If I get a foot of snow up there I have the roofers come out and shovel it off. Not worth the risk of leaving snow up there.
[img]http://i.imgur.com/boeexFms.jpg[/img]31 Plymouth Coupe, 392 Hemi, T56 magnum RS23J71 RS27J77 RP23J71 RO23J71 WM21J8A I don't regret the things I've done. I only regret the things I didn't do. "Wise men talk because they have something to say; fools because they have to say something. ~ Plato"
