Re: Your Piston Specs - B1 head valve reliefs
[Re: 440Jim]
#2893638
02/27/21 11:02 AM
02/27/21 11:02 AM
Posts: 1,313 Charlotte, NC
LSP
Charlotte, NC
I am planning 0.043" top and second rings; comments on 3/16 or 3mm oil ring? The 3mm oil ring is more than enough, will meter oil better than the 3/16" oil ring will, and the extra .070" skirt length will add to piston stability.
[Re: WadeMetzinger]
#2893892
02/27/21 09:24 PM
02/27/21 09:24 PM
Posts: 2,073 Tulsa, Ok
WadeMetzinger
Tulsa, Ok
Jim, I messed up. Those p-to-V numbers were test fitting, no head gasket and before I milled the heads .040.
Here is a pic of the actual P-to-V measurements.
Wade Metzinger 918-809-0987 71 Cuda 9.28@145 -1s, Pglide 68 Cuda 10.64@124 1.45 60's 318->390 eddys Moparts discount code on WIX - moparts www.Filter1.com
