Page 3 of 3 1 2 3
Re: rear sway bar and parts finish or coating [Re: ogopogo] #2891590
02/21/21 06:13 PM
02/21/21 06:13 PM
BC Canada
O
ogopogo Offline OP
ogopogo  Offline OP
O
BC Canada
I`m assuming the sway bar was bolted to the car before sound deadener(undercoating) application?
Re: rear sway bar and parts finish or coating [Re: ogopogo] #2891745
02/22/21 04:24 AM
02/22/21 04:24 AM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Is your car a undercoating optioned car? Or just the standard undercoating?
My 71 R/T has lots of undercoating on the sway bar. But not completely. The frame brackets are pretty much covered. Including the self tapping bracket to frame bolts.
Re: rear sway bar and parts finish or coating [Re: ogopogo] #2891747
02/22/21 07:06 AM
02/22/21 07:06 AM
Virginia
larry4406 Offline
larry4406  Offline
Virginia
yes thanks to all you guys,i can proceed now !! :-)
Beautiful!
Re: rear sway bar and parts finish or coating [Re: autoxcuda] #2891861
02/22/21 01:32 PM
02/22/21 01:32 PM
BC Canada
O
ogopogo Offline OP
ogopogo  Offline OP
O
BC Canada
thanks autox,I will be applying just the standard sound deadener in the wheelwells to the car........
Re: rear sway bar and parts finish or coating [Re: ogopogo] #2892057
02/22/21 11:08 PM
02/22/21 11:08 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
My car is full undercoating
The pictures Steve70 posted and I posted are of a 70 challenger t/a with standard undercoating.
Page 3 of 3 1 2 3
