Fan Belt Keeps Coming Off #2888069
02/14/21 12:45 PM
02/14/21 12:45 PM
Spanaway, Washington State
P
patosmith Offline OP
P
I have a 72 Challenger with a big block.
When I make a pass, the fan belt comes off. The belt is a "V" belt and drives the water pump and alternator.
I have checked pulley alignment and I can't find anything off. I have tried different width belts. Right now I have a pretty skinny belt on and seems to stay on but it is not right.
I really do not want to go with a serpentine setup.
Any ideas?
Re: Fan Belt Keeps Coming Off [Re: patosmith] #2888077
02/14/21 12:54 PM
02/14/21 12:54 PM
Kirkland, Washington
Pacnorthcuda Offline
Is your alternator bracket(s) stock for the big block you are running? Is the length of the belt longer than necessary causing a longer span from crank pulley to alternator?
Almost without a doubt the belt is whipping at speed in this span and eventually loses contact with the alternator and comes off.
Is it simply too loose? Is the alternator adjustment bolt slipping?
Re: Fan Belt Keeps Coming Off [Re: Pacnorthcuda] #2888096
02/14/21 01:05 PM
02/14/21 01:05 PM
n.c.
geo. Offline
geo.  Offline
n.c.
I had(have) the same problem with my then 318 powered Challenger.
I used to autocross a few times a year with the car, it was common to lose the fan belt during a run.
Someone suggested removing the fan and fan clutch before a run.
It worked, belt stayed on! If you're still running a stock style clutch and metal fan I'd try a run with fan removed.
I'd drive to the event and remove the fan, wasn't too hard to do, and replace for the ride home.
I don't know if there's a lighter fan and clutch I can try. Or if the fix is going to be adding an electric fan.
Re: Fan Belt Keeps Coming Off [Re: Pacnorthcuda] #2888097
02/14/21 01:06 PM
02/14/21 01:06 PM
P
P
The alternator is in the stock location but I think you hit on what my thought was.
The length of the belt between the crank pulley and the alternator. That is the only thing I can come up with.
I have tried to find a deep pulley for the alternator to see if that helps but haven't had any luck finding one.
I am looking into a tensioner on Mancini Racing but I'm not sure if it will fix the problem.
The pic I posted is not a good shot but you can see the location of the alternator.
Re: Fan Belt Keeps Coming Off [Re: geo.] #2888106
02/14/21 01:16 PM
02/14/21 01:16 PM
P
P
I was running a fan but have since converted to electric. I thought the centrifugal force of the fan (non clutch) was helping throw the belt.
The belt stays on but it is the skinny one I mentioned.
Re: Fan Belt Keeps Coming Off [Re: patosmith] #2888107
02/14/21 01:17 PM
02/14/21 01:17 PM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
How are you checking your pulley alignment? Are you using a straight edge, a lazer pointer or a wooden dowel? It's not as easy to do correctly as most people think, and close enough often isn't. What thickness belt are you using? Does it fill the entire v-groove of the pulley? Does it stick up beyond the groove?
Look closely at each pulley where the belt begins to contact the pulley. There are two places to check on each pulley. Does the belt touch one side of the pulley wall more than the other at these 6 locations?
More pictures of these locations would be helpful.
Re: Fan Belt Keeps Coming Off [Re: jbc426] #2888139
02/14/21 01:48 PM
02/14/21 01:48 PM
P
P
I used a straight edge to align the 3 pulleys. I had to make minor adjustments to the alternator to get it aligned.
I have used a belt that fit correctly in the pulleys which is fine around town but not at the strip. I used a belt that stuck up out of the pulley which I know is not correct. That one didn't work.
The only one that stays on at the strip is the skinny one. It sits way down in the pulleys but isn't really right either.
Sorry, I don't have any better pics on my computer to post and I don't have the belt dimensions available. I bought so many different sizes I don't remember which is which.
Re: Fan Belt Keeps Coming Off [Re: patosmith] #2888166
02/14/21 02:15 PM
02/14/21 02:15 PM
central il.
second 70 Offline
second 70  Offline
central il.
Any ideas?
Easy fix put a dayco top cog belt on it and that will fix it. I couldn't keep a belt on my hemi and then switched to a dayco and haren't tossed a belt in over 10 years. I use a 15470 belt.
Mike
Re: Fan Belt Keeps Coming Off [Re: patosmith] #2888173
02/14/21 02:20 PM
02/14/21 02:20 PM
BDW Online content
BDW  Online Content
How much wrap around the alternator? Is the belt touching between 1-9 (clock) or 12-6........
Longer belt and swinging the alternator as high as possible will give more contact area.
Re: Fan Belt Keeps Coming Off [Re: patosmith] #2888200
02/14/21 02:50 PM
02/14/21 02:50 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
They cured that problem on the Max Wedge by going to deeper groove pulleys. IOW, a 3/8" belt in pulleys designed for a 7/16" belt. (truck?)
Re: Fan Belt Keeps Coming Off [Re: John_Kunkel] #2888239
02/14/21 04:02 PM
02/14/21 04:02 PM
Central Pa
moparjim79 Offline
moparjim79  Offline
Central Pa
Had the same problem with a high strung 360 in my car. It once threw the belt off and over the fan without catching the fan( do NOT ask how! Still miffed) i see you have a double groove pulley on the alt. I had a/c pulleys on mine as well, no a/c, so I thought I'd just run 2 belts. It kind of worked, but I did remove my fan and shroud asm and went electric. Much better.
Re: Fan Belt Keeps Coming Off [Re: moparjim79] #2888280
02/14/21 05:18 PM
02/14/21 05:18 PM
South Park, Pa.
68LAR Offline
68LAR  Offline
South Park, Pa.
You might try loosening up the tension a bit. Sounds crazy, but it works.
4 speed street legal. Best time 10.99 @ 124 mph on 93 octane pump gas @ 3926# total weight
Re: Fan Belt Keeps Coming Off [Re: second 70] #2888295
02/14/21 05:47 PM
02/14/21 05:47 PM
A Red State
SNK-EYZ Offline
SNK-EYZ  Offline
A Red State
Any ideas?
Mike
iagree
I had the same problem with our 69 Dart 383 GTS that has a 451 stroker in it.
It threw every standard type V-Belt. I switched to a DAYCO top cog V-Belt and haven't thrown one yet.
The Dayco Top Cog Belt sits lower (farther) into the pulley grooves when installed.
Re: Fan Belt Keeps Coming Off [Re: SNK-EYZ] #2888403
02/14/21 09:03 PM
02/14/21 09:03 PM
Pato....here’s another idea. If you take your timing light and point it at the belt, while reving the engine, you will get an idea of what the belt is doing under various conditions. It helps determine what is working (like tight vs loose) and what is not.
Re: Fan Belt Keeps Coming Off [Re: Pacnorthcuda] #2889154
02/16/21 12:29 PM
02/16/21 12:29 PM
Connecticut
FurryStump Offline
FurryStump  Offline
Connecticut
Had the issue on my small block. I would tighten belt REALLY tight and it would live for a bit. Not really fair, I shift it at 6400 rpm. What really stopped it was a March under drive crank pulley. Remember one of the first gauges you check after the stripe is the alt gauge. Not charging the belt is gone. You catch it much quicker that way than seeing it start to get hot.
best of 11.24 at 119 mph 1.60 60’. 68 340 S Barracuda Fastback F.A.S.T [IMG]http://i67.tinypic.com/2mnnnnt.jpg[/IMG]
Re: Fan Belt Keeps Coming Off [Re: FurryStump] #2889226
02/16/21 02:27 PM
02/16/21 02:27 PM
Tucson, AZ
Ramrod39 Online work
My New Title
Ramrod39  Online Work
My New Title
Tucson, AZ
I had this problem with a fast revving small block. Checked/adjusted pulley alignment multiple times, tried a boat load of different belts. Even tried a larger alternator pulley, nothing really worked. I finally put a reduction pulley (smaller diameter) on the crank and went back to the stock alternator pulley and the problem was solved.
Re: Fan Belt Keeps Coming Off [Re: patosmith] #2893942
02/28/21 01:18 AM
02/28/21 01:18 AM
southeast NE
lemondana Offline
lemondana  Offline
southeast NE
Any ideas?
Post the brand and number of belt you now have on the car.
Re: Fan Belt Keeps Coming Off [Re: patosmith] #2894375
03/01/21 01:18 PM
03/01/21 01:18 PM
CT
GTX MATT Offline
GTX MATT  Offline
CT
Stock location but it looks a little high, do you have a picture of your alternator bracket? It could be the angle, but make sure you don’t have an AC lower bracket, this makes the belt needed much longer.
What do you have for a fan?
Re: Fan Belt Keeps Coming Off [Re: GTX MATT] #2894661
03/02/21 07:27 AM
03/02/21 07:27 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Put a straight edge on the alternator pulley. My bet is that its centerline is off in at least one plane. Or the pulley centerlines are forward or back from one another. The straightedge should stay perfectly square to both the crank and and water pump when placed on the alternator pulley. If the straightedge doesnt touch both faces of all three pulleys you have an issue. Do the same with the crank and water pump. I've had combos throw belts. Every time it's been one of 2 issues. Alignment or bracket flex. Currently have 3 cars. All have modified brackets, pulleys, etc. None of them ever through a belt. All run to at least 7000.
Doug
Re: Fan Belt Keeps Coming Off [Re: dvw] #2894741
03/02/21 11:18 AM
03/02/21 11:18 AM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
Doug
iagree
and will add
the longer the distance is between the pulleys and the less contact around the pulley the more prone they will be to throwing the belt.
Some of the c-2, c-3 corvettes used an adjustable belt guard that would not allow the belt to raise up enough to come out of it's groove. This was placed on the adjusting arm between the water pump near the alternator. NOTE: the alternator is the smallest pulley with the least amount of contact. This was on cars that had L (drivers side) mounted alternators.
Another trick from years ago was to place a long 5/16 or 3/8 bolt just above the belt to limit its upward movement thereby kepping the belt in the pulleys. Again this was done between the alternator and water pump.
Interesting that several have commented to Dayco top cog belts have resole their problem. I do know there are some slight variations on the belt V angles being made by different manufacturers. That may be the root cause shruggy beer
