74 duster hood latch finish? #2885902
02/09/21 03:46 PM
02/09/21 03:46 PM
South Dakota
hotairballoonpilot Offline OP
South Dakota
Curious on a 74 duster the hood latch,pop up spring,hood catch and striker. What finish would they have? owner says he has 2 original 74 a bodies and the catch and spring are body color. My thought they all would not be.
On a trunk the striker naturally is body color and the latch is normal latch coating?
What is everyone using for the latch coatings if not sending them in for redoing?
Contact Me about AMD Prices
Re: 74 duster hood latch finish? [Re: hotairballoonpilot] #2885923
02/09/21 04:24 PM
02/09/21 04:24 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
One of the Archive threads, there's a few, addressed this. General opinion:
Pop-up spring black phosphate
Hood latch & secondary catch a brownish zinc.
Hood striker body color.
Hood release lever brown zinc.
Trunk latch clear zinc (silver color).
Trunk striker may have varied by plant, either clear zinc or painted.
Attaching bolts to plated items black phosphate.
No painted latches or levers on anything I can think of.
Actually, different parts of the latches were different colors/plating.
Scott Smith's observations differ:
Moparts Forums › topics › factory-finishes-for-70-340-duster-parts-help
Re: 74 duster hood latch finish? [Re: topside] #2885953
02/09/21 05:48 PM
02/09/21 05:48 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
1973 survivor
Car was aftermarket undercoated when new. That is the black you see top of inner fenders
Looks like same grey-brown finish as 71 and earlier cars.
More pics here: https://board.moparts.org/ubbthreads/ubbthreads.php/topics/1619053/1.html
Re: 74 duster hood latch finish? [Re: autoxcuda] #2886110
02/10/21 12:14 AM
02/10/21 12:14 AM
Cut and Shoot, TX
kentj340 Offline
kentj340  Offline
Cut and Shoot, TX
The hood catch is finished in black zinc, which means it is zinc plated and dipped in black chromate. The final color is sometimes more brownish than black. See photos here that are labeled "black zinc".
Re: 74 duster hood latch finish? [Re: kentj340] #2886184
02/10/21 08:26 AM
02/10/21 08:26 AM
Dry Heat AZ
AAR#2 Offline
AAR#2  Offline
Dry Heat AZ
Originally Posted by kentj340
. . . zinc plated and dipped in black chromate. The final color is sometimes more brownish than black. See photos.
Can’t say I’ve ever experienced or seen black chromate appear brownish, though slight variations in depth of color and amount of iridescent effect does vary. It’s a beautiful finish that’s very durable.
Re: 74 duster hood latch finish? [Re: AAR#2] #2886189
02/10/21 08:56 AM
02/10/21 08:56 AM
Dry Heat AZ
AAR#2 Offline
AAR#2  Offline
Dry Heat AZ
I decided to see if I could find anything on the subject of “brown” chromate and stumbled onto the following link on finishing.com (great forum for all things plating)
https://www.finishing.com/587/97.shtml
Bill posted three photos of examples, where the first appears easiest to read. To me this appears to be a trunk latch with two distinctive finished, black chromate and yellow chromate. The yellow appears very dark as if left in the chromate solution for an extended period or very concentrated bath, as one response later suggests. The black does appear light and unsure why this occurred, thin base layer of zinc? Worn out chromate bath? Reduced time in chromate?
The follow on 2 photos to me appear similar, but black, where I think it may just be the light source adding to the brownish color, particularly on the hood latch as the top surface is the only surface that doesn’t appear black.
Of course while he stated the parts were protected from sun and never installed, plating degradation over 45-50 years Lilly had some affect on the visual aspect of the finish
Re: 74 duster hood latch finish? [Re: AAR#2] #2886444
02/10/21 05:13 PM
02/10/21 05:13 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
SF Resto does this plating
He took over the business Jules had that this web board section is named after
Read here:
https://board.moparts.org/ubbthread.../s-f-restoration-in-jules-footsteps.html
And : https://m.facebook.com/pages/catego...estauration-Automobile-1863991680523016/
Re: 74 duster hood latch finish? [Re: autoxcuda] #2886572
02/10/21 10:20 PM
02/10/21 10:20 PM
Ontario, Canada
RealWing Offline
RealWing  Offline
Ontario, Canada
the correctly restored "brown zinc" hood latch on my '69 Cuda, by Stephan.
1970 Superbird 440-6bbl, auto
1969 Barracuda 340-4bbl, FB Formula S auto
1969 Barracuda 6.1 L Hemi, 5 speed, Convertible
2022 Can Am Spyder RTL
Re: 74 duster hood latch finish? [Re: autoxcuda] #2887104
02/12/21 10:56 AM
02/12/21 10:56 AM
Dry Heat AZ
AAR#2 Offline
AAR#2  Offline
Dry Heat AZ
He took over the business Jules had . . .
These two gentlemen have always performed fist class work, and perhaps more noteworthy is their professional demeanor and ethical business practice.
I found this thread interesting, and apparently at a time when Jules was on the road of discovery;
https://board.moparts.org/ubbthreads/ubbthreads.php/topics/139012.html
Since that time Jules was able to find a solution, with Stephan perfecting the results after his passing.
Hats off to both gents for their contributions to the hobby!
Re: 74 duster hood latch finish? [Re: AAR#2] #2887544
02/13/21 09:54 AM
02/13/21 09:54 AM
Connecticut
1972CudaV21 Offline
1972CudaV21  Offline
Connecticut
Hi,
What is the average cost to have these latches, strikers, catches, etc. plated?
China is the enemy.
Re: 74 duster hood latch finish? [Re: 1972CudaV21] #2887564
02/13/21 10:54 AM
02/13/21 10:54 AM
Ontario, Canada
RealWing Offline
RealWing  Offline
Ontario, Canada
Originally Posted by 1972CudaV21
Hi,
Best to simply send the photos of the parts you want restored to Stephan. He will get back to you fairly quickly with an accurate quote.
Re: 74 duster hood latch finish? [Re: RealWing] #2887580
02/13/21 12:02 PM
02/13/21 12:02 PM
Connecticut
1972CudaV21 Offline
1972CudaV21  Offline
Connecticut
Hi,
I agree. Just wondering what folks are paying.
China is the enemy.
Re: 74 duster hood latch finish? [Re: 1972CudaV21] #2887670
02/13/21 03:42 PM
02/13/21 03:42 PM
Ontario, Canada
RealWing Offline
RealWing  Offline
Ontario, Canada
I dug back through my emails and here are the costs to do my Cuda parts. These prices are 2 years old. They are in CAD funds
Main hood latch: $ 185
Safety hook: $ 95
Trunk latch : $ 95
Trunk catch: $ 20
Door latches: $ 150 ( pair )
Strikers: $ 50 ( pair )
Wiper motor 3 speed $ 325
Wiper motor 2 speed $ 225
Re: 74 duster hood latch finish? [Re: RealWing] #2887824
02/13/21 08:57 PM
02/13/21 08:57 PM
Connecticut
1972CudaV21 Offline
1972CudaV21  Offline
Connecticut
Thanks for sharing!
China is the enemy.
