74 duster hood latch finish?
#2885902
02/09/21 03:46 PM
02/09/21 03:46 PM
Posts: 5,668 South Dakota
hotairballoonpilot
South Dakota
Curious on a 74 duster the hood latch,pop up spring,hood catch and striker. What finish would they have? owner says he has 2 original 74 a bodies and the catch and spring are body color. My thought they all would not be.
On a trunk the striker naturally is body color and the latch is normal latch coating?
What is everyone using for the latch coatings if not sending them in for redoing?
Contact Me about AMD Prices
Re: 74 duster hood latch finish?
[Re: autoxcuda]
#2886110
02/10/21 12:14 AM
02/10/21 12:14 AM
Posts: 1,655 Cut and Shoot, TX
kentj340
Cut and Shoot, TX
The hood catch is finished in black zinc, which means it is zinc plated and dipped in black chromate. The final color is sometimes more brownish than black. See photos here that are labeled "black zinc".
[Re: kentj340]
#2886184
02/10/21 08:26 AM
02/10/21 08:26 AM
Posts: 768 Dry Heat AZ
AAR#2
Dry Heat AZ
. . . zinc plated and dipped in black chromate. The final color is sometimes more brownish than black. See photos. Can’t say I’ve ever experienced or seen black chromate appear brownish, though slight variations in depth of color and amount of iridescent effect does vary. It’s a beautiful finish that’s very durable.
[Re: AAR#2]
#2886189
02/10/21 08:56 AM
02/10/21 08:56 AM
AAR#2
Dry Heat AZ
I decided to see if I could find anything on the subject of “brown” chromate and stumbled onto the following link on finishing.com (great forum for all things plating) https://www.finishing.com/587/97.shtmlBill posted three photos of examples, where the first appears easiest to read. To me this appears to be a trunk latch with two distinctive finished, black chromate and yellow chromate. The yellow appears very dark as if left in the chromate solution for an extended period or very concentrated bath, as one response later suggests. The black does appear light and unsure why this occurred, thin base layer of zinc? Worn out chromate bath? Reduced time in chromate? The follow on 2 photos to me appear similar, but black, where I think it may just be the light source adding to the brownish color, particularly on the hood latch as the top surface is the only surface that doesn’t appear black. Of course while he stated the parts were protected from sun and never installed, plating degradation over 45-50 years Lilly had some affect on the visual aspect of the finish
[Re: AAR#2]
#2886444
02/10/21 05:13 PM
02/10/21 05:13 PM
Posts: 27,471 So Cal
autoxcuda
So Cal
[Re: autoxcuda]
#2886572
02/10/21 10:20 PM
02/10/21 10:20 PM
Posts: 315 Ontario, Canada
RealWing
Ontario, Canada
the correctly restored "brown zinc" hood latch on my '69 Cuda, by Stephan.
1970 Superbird 440-6bbl, auto 1969 Barracuda 340-4bbl, FB Formula S auto 1969 Barracuda 6.1 L Hemi, 5 speed, Convertible 2022 Can Am Spyder RTL
[Re: autoxcuda]
#2887104
02/12/21 10:56 AM
02/12/21 10:56 AM
AAR#2
Dry Heat AZ
SF Resto does this plating
He took over the business Jules had . . . These two gentlemen have always performed fist class work, and perhaps more noteworthy is their professional demeanor and ethical business practice. I found this thread interesting, and apparently at a time when Jules was on the road of discovery; https://board.moparts.org/ubbthreads/ubbthreads.php/topics/139012.htmlSince that time Jules was able to find a solution, with Stephan perfecting the results after his passing. Hats off to both gents for their contributions to the hobby!
[Re: AAR#2]
#2887544
02/13/21 09:54 AM
02/13/21 09:54 AM
Posts: 3,267 Connecticut
1972CudaV21
Connecticut
Hi,
What is the average cost to have these latches, strikers, catches, etc. plated?
China is the enemy.
[Re: 1972CudaV21]
#2887564
02/13/21 10:54 AM
02/13/21 10:54 AM
RealWing
Ontario, Canada
Hi,
What is the average cost to have these latches, strikers, catches, etc. plated? Best to simply send the photos of the parts you want restored to Stephan. He will get back to you fairly quickly with an accurate quote. Jim
[Re: RealWing]
#2887580
02/13/21 12:02 PM
02/13/21 12:02 PM
1972CudaV21
Connecticut
Hi,
What is the average cost to have these latches, strikers, catches, etc. plated? Best to simply send the photos of the parts you want restored to Stephan. He will get back to you fairly quickly with an accurate quote. Jim I agree. Just wondering what folks are paying.
China is the enemy.
[Re: 1972CudaV21]
#2887670
02/13/21 03:42 PM
02/13/21 03:42 PM
RealWing
Ontario, Canada
I dug back through my emails and here are the costs to do my Cuda parts. These prices are 2 years old. They are in CAD funds Main hood latch: $ 185 Safety hook: $ 95 Trunk latch : $ 95 Trunk catch: $ 20 Door latches: $ 150 ( pair ) Strikers: $ 50 ( pair ) Wiper motor 3 speed $ 325 Wiper motor 2 speed $ 225
[Re: RealWing]
#2887824
02/13/21 08:57 PM
02/13/21 08:57 PM
1972CudaV21
Connecticut
Thanks for sharing!
China is the enemy.
