Re: Is this the fix for Edelbrocks off idle dead spot?
[Re: Sniper]
#2884811
02/06/21 06:30 PM
02/06/21 06:30 PM
Posts: 12,296 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
Correction. The problem is not that the CarterBrocks need tuned. It's how difficult they are to tune. And how difficult they are to find parts for and information on how to tune them. The OP talked to the manufacturer straight on and they blamed someone else for their problem. Either they didn't know they had a problem or knew it and hid the info. Which one is worse?
Here it is 2021, this platform carb has been around over half a century and the fix for a common problem that people have been dealing with for decades is still news to many. That is the problem.
Master, again and still
[Re: lewtot184]
#2884832
02/06/21 07:11 PM
02/06/21 07:11 PM
Posts: 4,321 Prospect, PA
BSB67
Prospect, PA
all they're doing is richening up the idle jet. the idle jet is the small tube in the primary cluster. i do this a bunch and is a major help on factory avs's. in short go to .035" on the 600cfm carbs and somewhere between .037"-.040" on the 750's and 800's. i never use large squirters on anything i drive; they don't work. i do use the tan colored accelerator pumps exclusively. also look for casting flash in the groove that feeds the pump reservoir. simple stuff.
i'm going to add something else. i've found dealing with the 800avs (not the avs2) that taking fuel out does help them drive better off idle. they have a .040" idle jet and don't go bigger. i've reduced main metering jet area and used small squirters to improve tip-in.
35 year old stuff. Probably 15 year old stuff 35 years ago. What's old is new again. I remember you and I talking about this in the early 1990s. You were giving pointers back then. Probably what you said above.
[Re: DaveRS23]
#2884971
02/07/21 08:29 AM
02/07/21 08:29 AM
Posts: 1,341 VA
dragon slayer
VA
Here it is 2021, this platform carb has been around over half a century and the fix for a common problem that people have been dealing with for decades is still news to many. That is the problem. That is a better statement of the problem. Let's remember Carter went out of business. Then the spin offs. Holley won the competition war especially when it came to racing. But I would not classify them as easy to work on either. Those Edelbrocks are generic AFB and AVS. I have seen them used out of the box and work fine for a basic street car with some minor tuning. Some times I question if they even have engineers testing anymore, or just have the overseas manufacture copy an old design. I do not think many appreciate all the different variations OEM carter had with top size and shape, venturi dimensions, let alone jetting. Same goes for the spin off fuel pumps. Even washer sizes were engineered inside a fuel pump with plenty of patents on the design. All that gets washed away by an overseas manufacture that doesn't know why it was like that but can save some pennies per unit using something more generic. I would say this for an old carb. You need to take it apart and clean and dimension the idle and fuel jets. Aluminum corrosion, growth, dirt, all tend to shrink the hole sizes. Clean it out really well, and get back to OEM base line. Carter manual or Service Manual give spec for air and fuel bleeds/jet. Have that base line then change for your motor/todays fuel.
[Re: dvw]
#2885038
02/07/21 12:01 PM
02/07/21 12:01 PM
Posts: 2,815 Sobieski Wi
bee1971
Sobieski Wi
And at what RPM are you launching those 1407 s ???
Street Versus Race And Off Idle / Flat Spots Versus RPM are completely eliminated
Edelbrock 1407/1411 where notorious for off idle flat spots / going lean on Big Block Mopars on the street No damn drill bits where fixing those - Maybe a garbage can or EBay
I like the factory Carter AVS found on the 69 - 71 440 HP motors - So easy to tune when converted over to Eddy internals and flat metering rod covers
With that said , I Absolutely LOVE my Eddy AVS 2 800 - Idle and Off Idle are flawless / perfection to say the least on a street car
Anyways 1407/1411 - From Speedtalk
The secondary venturi cluster emulsion tube is “pinched” at the bottom with a .073” orifice the fuel must pass through to enter the tube to get up to the discharge nozzle….. and (it gets worse) …… the secondary Main Air Bleed is .073”. Imagine what a Holley would do if it had a .073” bleed in the booster leg.
The reason it doesn’t seem to matter what jet size is used is the .073” air bleed kills the venturi signal and no matter what main jet size larger than .073” is used the fuel must pass through the .073” restriction downstream of the main jet.
As if that isn’t bad enough, the primary MAB (the tube pressed in the top of the cluster) is occasionally very large, .040” or more, and occasionally different on left and right.
Occasionally the idle jet (the small tube pressed in the bottom of the cluster) is different left and right and sometimes the idle jet larger than necessary, resulting in a very rich off-idle.
The 1407 750 CFM uses the same casting for the primary cluster as the 625 CFM carbs in spite of the fact the venturi minor diameter is 5/16” or so lower in the 750 body. This places the exit of the booster venturi that much above the “vena contracta” in the air flow, the result is the “booster signal” is not obtained in the correct location and the metering is erratic, the A/F wanders rich and lean as load and RPM vary as the throttle position is changed.
1971 Dodge Charger Superbee 2011 Ram Sport 1500 Quad Cab Deep Water Blue Loaded Siberian Huskies
[Re: dvw]
#2885157
02/07/21 03:36 PM
02/07/21 03:36 PM
bee1971
Sobieski Wi
Launch at 2800-3100. And yes I’m chasing inconsistently in the 60ft that is not traction related. Doug Interested in your results switching over to the Holleys , especially with what your describing on the Eddy 1407 s if that indeed is the issue
[Re: BSB67]
#2885174
02/07/21 04:14 PM
02/07/21 04:14 PM
Posts: 3,916 usa
lewtot184
usa
35 year old stuff. Probably 15 year old stuff 35 years ago. What's old is new again. I remember you and I talking about this in the early 1990s. You were giving pointers back then. Probably what you said above. when i got back into the afb/avs i just did some research on old info and service manual specs and applied it. some of the old race tips help too. there's info out there and the edelbrock parts support helps. using some grade school math figuring jet area's instead of just jet or rod numbers helps. i enjoy the challenge and the challenge isn't big. i firmly believe that the afb carb was and still is a very good efficient design.
[Re: bee1971]
#2885188
02/07/21 04:33 PM
02/07/21 04:33 PM
Posts: 3,916 usa
lewtot184
usa
as for your speed talk quote, and i've read this before, if a careful look is taken at the cluster in question you'll notice an additional flow tube that does help that matter, but if there still is an issue with size the "special" drill bits from a set of number drills solves the problem. there are also clusters out there that have a straight thru emulsion tubes that aren't swaged down. a concern to me with edelbrocks (not the old sand cast carters) is the fuel passages from the jets to the cluster wells. the edelbrocks are smaller and not machined near as nice as the old stuff. holley's do have better and larger fuel passages that could be a make or break deal for someone in competition.
[Re: hooziewhatsit]
#2885200
02/07/21 04:45 PM
02/07/21 04:45 PM
Posts: 3,916 usa
lewtot184
usa
I just pulled a spare 1405 (or was it a 1406? ) off the shelf. A 0.028" drill bit is the biggest that will fit in the orifice. I'm also having an off idle stumble, so I may just drill them out to 0.035" the 1405 that i'm using for a secondary carb on a ch28 did have a .028" idle jet and the 1406 i use for primary had a .033" idle jet. ironically these two carbs were totally different internally in relation to the clusters and jets. i'm using .036" idle jetting now in both carbs but i do have a little bit of cam in the engine and sometimes that needs a little fuel help. i use nothing bigger than .028" squirters with the orange/tan ( 1467 pump) accelerator pump (carbs came with this pump) and no stumble, hesitations, spits, sputters or nothing adverse. power is very smooth and reliable.
[Re: buildanother]
#2885213
02/07/21 05:06 PM
02/07/21 05:06 PM
Posts: 884 Missouri
jwb123
Missouri
I buy Holley air bleed jets the small ones, takes a 6-32 tap, I drill a bigger hole to just sink the jet, then tap it for the screw in air bleed. I think most of these stock have about .040 idle airbleed, I reduce that to around .030 and it fixes idle quality and the stumble. I got the idea on this forum, do a search, the post had photos. Also on the stumble, fire up the engine let it idle at normal speed, lossen the plate over the metering rod piston, and slide it to the side, be careful so you don't shoot it out, but play with the throttle and watch the piston move, stretch the spring until the instant you touch the throttle the piston starts to rise, makes them very responsive. They do make different weight springs, I seldom need them unless it has a big cam. The other issue is the AFB carb design, is a very good one, but it is 50 years old at least, we are not burning the same fuel in our cars that they did 50 years ago. Fuel injection systems adjust for a lot of variables, carb adjust for nothing, if you don't want to drill a few holes and change some parts to get it perfect, just buy and injection system and let the computer do it for you. Tuning a carb is a dying art.
[Re: jwb123]
#2885231
02/07/21 05:48 PM
02/07/21 05:48 PM
Posts: 3,916 usa
lewtot184
usa
I buy Holley air bleed jets the small ones, takes a 6-32 tap, I drill a bigger hole to just sink the jet, then tap it for the screw in air bleed. I think most of these stock have about .040 idle airbleed, I reduce that to around .030 and it fixes idle quality and the stumble. I got the idea on this forum, do a search, the post had photos. Also on the stumble, fire up the engine let it idle at normal speed, lossen the plate over the metering rod piston, and slide it to the side, be careful so you don't shoot it out, but play with the throttle and watch the piston move, stretch the spring until the instant you touch the throttle the piston starts to rise, makes them very responsive. They do make different weight springs, I seldom need them unless it has a big cam. The other issue is the AFB carb design, is a very good one, but it is 50 years old at least, we are not burning the same fuel in our cars that they did 50 years ago. Fuel injection systems adjust for a lot of variables, carb adjust for nothing, if you don't want to drill a few holes and change some parts to get it perfect, just buy and injection system and let the computer do it for you. Tuning a carb is a dying art. from what i can tell the afb's have two idle bleeds, plus an economizer bleed, and several emulsion tube bleeds. they have a bunch of places to mix air with the fuel. i think they are more sophisticated than a holley at mixing air and fuel. i think of a holley as being one step above a lawn mower carb because it has a cruise circut,....lol. . one race tip is to solder up the air holes in the emulsion tubes.
[Re: lewtot184]
#2885265
02/07/21 07:12 PM
02/07/21 07:12 PM
Posts: 3,909 Oregon
hooziewhatsit
I just pulled a spare 1405 (or was it a 1406? ) off the shelf. A 0.028" drill bit is the biggest that will fit in the orifice. I'm also having an off idle stumble, so I may just drill them out to 0.035" the 1405 that i'm using for a secondary carb on a ch28 did have a .028" idle jet and the 1406 i use for primary had a .033" idle jet. ironically these two carbs were totally different internally in relation to the clusters and jets. i'm using .036" idle jetting now in both carbs but i do have a little bit of cam in the engine and sometimes that needs a little fuel help. i use nothing bigger than .028" squirters with the orange/tan ( 1467 pump) accelerator pump (carbs came with this pump) and no stumble, hesitations, spits, sputters or nothing adverse. power is very smooth and reliable. I have a 1406 (I'm pretty sure ) on my truck right now. Apparently 1405s and 1406s have different venturis, boosters and idle circuits? It's been several years since I've been in the carb. I'll get the tan accelerator pump (thanks for the part number!), then dig into it at some point.
[Re: hooziewhatsit]
#2885331
02/07/21 09:36 PM
02/07/21 09:36 PM
Posts: 3,916 usa
lewtot184
usa
I just pulled a spare 1405 (or was it a 1406? ) off the shelf. A 0.028" drill bit is the biggest that will fit in the orifice. I'm also having an off idle stumble, so I may just drill them out to 0.035" the 1405 that i'm using for a secondary carb on a ch28 did have a .028" idle jet and the 1406 i use for primary had a .033" idle jet. ironically these two carbs were totally different internally in relation to the clusters and jets. i'm using .036" idle jetting now in both carbs but i do have a little bit of cam in the engine and sometimes that needs a little fuel help. i use nothing bigger than .028" squirters with the orange/tan ( 1467 pump) accelerator pump (carbs came with this pump) and no stumble, hesitations, spits, sputters or nothing adverse. power is very smooth and reliable. I have a 1406 (I'm pretty sure ) on my truck right now. Apparently 1405s and 1406s have different venturis, boosters and idle circuits? It's been several years since I've been in the carb. I'll get the tan accelerator pump (thanks for the part number!), then dig into it at some point. venturi are the same; clusters are different. circuits are just calibrated different and can be easily changed. 1406's are lean on the primary side. i use .100" jets with 71x47 rods.
