Re: Is this the fix for Edelbrocks off idle dead spot?
[Re: 74RALLYE]
#2884323
02/05/21 12:42 PM
02/05/21 12:42 PM
Posts: 25,925 Rio Linda, CA
John_Kunkel
Rio Linda, CA
That mod was the fix for the same problem with the factory AVS. Most drivability techs learned it in the sixties.
[Re: 74RALLYE]
#2884357
02/05/21 02:38 PM
02/05/21 02:38 PM
Posts: 12,232 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
That is a very good video for someone that insists on running one of those for what ever reason. It would have been better for all those that do not have a full set of tiny drill bits to mention what size the orifice started out at and what size it ended up at. .009" bigger is not the best way he could have communicated his changes.
With all the information and parts out there for the Holley platform carbs, I have always been surprised at the lack of CarterBrock parts and this kind of deeper tuning info given how many are out there.
But one look at the tuning charts for the metering rods and jets should still cause most guys to look for a carb elsewhere. I'll say again, the CarterBrocks are not necessarily bad carbs, it's just that there are much better choices out there today. Heck, in the Engine Masters recent cheap carb shoot-out, the CarterBrock came in last place. Even the Summit carb beat it.
Master, again and still
[Re: DaveRS23]
#2884366
02/05/21 03:13 PM
02/05/21 03:13 PM
John_Kunkel
Rio Linda, CA
Since the problem seems to exist throughout the AFB, AVS and Edelbrock series, the tube orifice size varies with the booster. We always increased the orifice two drill sizes at a time without paying any attention to the actual drill size.
[Re: John_Kunkel]
#2884388
02/05/21 04:09 PM
02/05/21 04:09 PM
Posts: 3,916 usa
lewtot184
usa
all they're doing is richening up the idle jet. the idle jet is the small tube in the primary cluster. i do this a bunch and is a major help on factory avs's. in short go to .035" on the 600cfm carbs and somewhere between .037"-.040" on the 750's and 800's. i never use large squirters on anything i drive; they don't work. i do use the tan colored accelerator pumps exclusively. also look for casting flash in the groove that feeds the pump reservoir. simple stuff.
i'm going to add something else. i've found dealing with the 800avs (not the avs2) that taking fuel out does help them drive better off idle. they have a .040" idle jet and don't go bigger. i've reduced main metering jet area and used small squirters to improve tip-in.
[Re: 74RALLYE]
#2884406
02/05/21 04:42 PM
02/05/21 04:42 PM
Posts: 8,403 Highland, MI.
Sunroofcuda
Highland, MI.
74Rallye - is your car out of CA? I looked at one from CA. back around 1984 - looked the same as the car in your avator. It was parked under a car port in Phoenix, AZ. An amazing all original paint car in super condition - 440 automatic. I left a note on it to ask if it was for sale, but never heard from the owner.
[Re: John_Kunkel]
#2884485
02/05/21 07:42 PM
02/05/21 07:42 PM
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
Since the problem seems to exist throughout the AFB, AVS and Edelbrock series, the tube orifice size varies with the booster. We always increased the orifice two drill sizes at a time without paying any attention to the actual drill size. That works for you. You must have a full set of tiny drill bits to choose from. But not everybody does. A post or two later, it is noted that the drill range is " .035" on the 600cfm carbs and somewhere between .037"-.040" on the 750's and 800's." That is more very good info for those that don't want to buy a full set of drill bits to find that one or two that they will need to fix their CarterBrock's problem.
[Re: dragon slayer]
#2884545
02/05/21 10:12 PM
02/05/21 10:12 PM
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
Obviously, you misunderstand.
I have worked on CarterBrocks before so I have plenty of drill bits. I was just thinking of the poor guy that buys one of these things and then realizes that he doesn't have enough tools to get it to run right. And there have been plenty of posts on this and many, many other boards from guys discovering just that.
CarterBrocks are not bad carbs, there are just better choices out there today. Ones that don't require a set of drill bits to get to run right.
And I am not cleaning ANYTHING out of my carbs with a drill bit.
[Re: DaveRS23]
#2884570
02/05/21 11:40 PM
02/05/21 11:40 PM
Posts: 4,694 Wichita
GY3
Wichita
The only reason to run an Edelbrock carb on your car is if you need to knock some power out of it to slow it down.
[Re: lewtot184]
#2884655
02/06/21 11:01 AM
02/06/21 11:01 AM
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
Exactly which of the above posts are more infomercial than information? The Engine Masters shoot-out where the CarterBrock came in last? The fact that the CarterBrocks have a well known off idle hesitation that other carbs don't have? The need for a set of special drill bits to fix the CarterBrock's calibration problems?
Wouldn't any open minded shopper want that information before they pulled the trigger on one of these carbs?
[Re: DaveRS23]
#2884739
02/06/21 04:05 PM
02/06/21 04:05 PM
John_Kunkel
Rio Linda, CA
Since the problem seems to exist throughout the AFB, AVS and Edelbrock series, the tube orifice size varies with the booster. We always increased the orifice two drill sizes at a time without paying any attention to the actual drill size. That works for you. You must have a full set of tiny drill bits to choose from. But not everybody does. They're cheap, no excuse for not having the set. https://www.ebay.com/itm/59Pcs-Prec...l-Bits-Set-Rotary-Tools-Kit/184437419802
[Re: John_Kunkel]
#2884784
02/06/21 05:22 PM
02/06/21 05:22 PM
Posts: 3,903 Oregon
hooziewhatsit
I just pulled a spare 1405 (or was it a 1406? ) off the shelf. A 0.028" drill bit is the biggest that will fit in the orifice. I'm also having an off idle stumble, so I may just drill them out to 0.035"
