Bottom bearing for steering column #2883153
02/02/21 03:39 PM
02/02/21 03:39 PM
GA
roadrunninMark Offline OP
GA
I saw on FB that someone has replaced the plastic bearing in a 70 e body steering column (power, if it matters) to a metal ball bearing. These bearing are cheap and the poster said it made a nice difference as the plastic one was worn out. Has anyone changed their bearing and is this usually the only item that really wears out in a column? I have 2 columns I could do and am curious if this is something that is necessary (both 50 year old coumns). I've attached a link of the bearing that was recommended.
https://www.ebay.com/itm/SER205-16-...With-Snap-Ring-NEW-ER205-16/291415817563
Re: Bottom bearing for steering column [Re: roadrunninMark] #2883167
02/02/21 03:59 PM
02/02/21 03:59 PM
N
NITROUSN Offline
NITROUSN  Offline
N
Not sure on the e-body but the bearing shown is for a 1 inch shaft. I thought they were 3/4 shafts.
Re: Bottom bearing for steering column [Re: NITROUSN] #2883184
02/02/21 04:27 PM
02/02/21 04:27 PM
GA
GA
I don't know, this was the bearing that was mentioned.
Re: Bottom bearing for steering column [Re: roadrunninMark] #2883227
02/02/21 06:09 PM
02/02/21 06:09 PM
Rio Linda, CA
John_Kunkel Online content
John_Kunkel  Online Content
Rio Linda, CA
This one would be more appropriate for the Mopar 3/4" shaft.
https://www.ebay.com/itm/SER204-12-...-Ring-High-Quality-ER204-12/132395499046
Is this supposed to be for a column shift or floor shift?
Re: Bottom bearing for steering column [Re: John_Kunkel] #2883239
02/02/21 06:42 PM
02/02/21 06:42 PM
BDW Offline
BDW  Offline
Re: Bottom bearing for steering column [Re: John_Kunkel] #2883242
02/02/21 07:10 PM
02/02/21 07:10 PM
GA
GA
John, it looks like it is for the floor shift, but according to the write up on cuda-challenger provided link from BDW, it can be for a column shift if one removes the shifting tube.
Nice find BDW, thanks
Re: Bottom bearing for steering column [Re: roadrunninMark] #2883343
02/02/21 10:21 PM
02/02/21 10:21 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Its not a matter of "wear". These things were subjected to all the rain, snow, salt, mud and any other crap that's on the road and getting splashed up there. But I suspect the car won't ever be seeing any of that again so don't worry about "wear".
Re: Bottom bearing for steering column [Re: roadrunninMark] #2883353
02/02/21 10:40 PM
02/02/21 10:40 PM
Texas
GoodysGotaCuda Offline
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
I put a bearing in mine. Can't say it made much of a difference because the whole car was rebuilt, but it seems to be doing fine after 10,000miles.
1972 Barracuda - 5.7L Hemi, T56 Magnum 6spd - https://www.facebook.com/GoodysGotaHemi
2020 RAM 1500
[img]https://i.imgur.com/v9yezP9.jpg[/img]
Re: Bottom bearing for steering column [Re: GoodysGotaCuda] #2883447
02/03/21 09:53 AM
02/03/21 09:53 AM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Its worth noting that the original bearings are a ball bearing encased in plastic - probably provide some protection - as well as something to screw into to retain it in the column. Had the factory used an all steel bearing they'd have been replacing those like crazy under warranty! I think the factory ones would have survived even better had they not put the holes in the outer column - which allowed dirt and moisture to seep down to the bearing with no way to get out. I'm surprised columns didn't rot away to nothing!
