4 link setup question #2882425
01/31/21 03:15 PM
01/31/21 03:15 PM
Lethbridge, AB, Canada
dangina Offline OP
dangina  Offline OP
If your cars suspension is fully loaded (ie car on the ground) ideally at what angle do you want the 4 link bars? (angled up, down or straight?) Thanks!
Re: 4 link setup question [Re: dangina] #2882496
01/31/21 05:28 PM
01/31/21 05:28 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Depends on power level type of tire. weight distribution power level. The lower bar on a bias slick will probably be some where close to parallel with the ground. The upper bar will be pointed down in front to intersect the imaginary extended length of the lower bar some where around 40-45" out. the spread of the bars on the brackets makes a difference.
This may help you. https://www.youtube.com/watch?v=nU4PXWg2Dg8
Doug
