Page 2 of 3 1 2 3
Re: Are new intake designs needed for big engines? [Re: feets] #2882791
02/01/21 03:20 PM
02/01/21 03:20 PM
DFW
mr_340 Offline
mr_340  Offline
DFW
Originally Posted by feets
I used 93% efficiency to suggest a typical moderate build. At 100% it slides up to 116 cfm per runner. As a whole, the math says 936 cfm for a 541 at 100%. Then, you get into real world restrictions, carb sizing bumps, and such.
I think you are assuming that all eight cylinders have the intake valve open at the same time. If #1 cylinder is just opening the intake valve, and we have a 300 degree duration cam at .006" lift, then we have #2 still open (90 degrees past opening), #7 still opening (180 degrees), #5 closing at 270 degrees past opening, and #6 is already closed assuming the standard firing order. So only two cylinders are flowing a lot of air. I think Darin Morgan said we have about 2-1/2 cylinders open at any time. 936cfm (total)/2.5 cylinders=374cfm per cylinder.
Correct me if I'm thinking this the wrong way.
Floyd Lippencott IV
Re: Are new intake designs needed for big engines? [Re: Thumperdart] #2882799
02/01/21 03:31 PM
02/01/21 03:31 PM
moparx Offline
moparx  Offline
Originally Posted by Thumperdart
Tunnel ram is the answer here.....
with that in mind, what about the long ram intakes with about a 3-4" [or larger] spacer ?
just thinking out loud here, as both a tunnel ram and a set of long rams with spacers would require hood modifications.
if the long rams ran out of steam at around 4500rpm or so, was that because of plenum volume being very small to allow for hood closure ?
what would a large spacer, open or 4 hole, do to these intakes, provided the spacer be sized for a much larger carb ?
beer
Re: Are new intake designs needed for big engines? [Re: feets] #2882875
02/01/21 07:14 PM
02/01/21 07:14 PM
Cranberry Twp PA (North of Pit...
rumblefish72 Offline
I'm saving my lunch money for one of these ... Hemi blower manifold with Wilson fabricated top. Will run NA on my 604 and am boost ready for the ProCharger F-3R-130
1972 Pro-Street 'Cuda, 500" Eagle stoker B Block, Eddy RPM heads, Victor Manifold, 850 Mighty Demon, Hemi 4 Speed, Dana 60 w/4.88 gears - Built by Hansen Racing Middlesex - NJ
Re: Are new intake designs needed for big engines? [Re: moparx] #2882876
02/01/21 07:17 PM
02/01/21 07:17 PM
Taxes & Virus's R-US, NY
Dragula Online content
Dragula  Online Content
The short answer is yes.....When I mill out the clover leaf in an Indy 4500 single plane intake and go quicker by .11, then I would say yes. Plenums for today's stroker motors is too small.
Re: Are new intake designs needed for big engines? [Re: Dragula] #2882886
02/01/21 07:47 PM
02/01/21 07:47 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
The plenum of the Indy 440-25 is quite large. Runners have good taper. Even with Eddy carbs its seems to work pretty well on my 572. We'll see how it works with some custom built 4150's this spring.
Doug
Re: Are new intake designs needed for big engines? [Re: dvw] #2882983
02/02/21 01:55 AM
02/02/21 01:55 AM
Melbourne , Australia
LA360 Offline
LA360  Offline
The RPM range stated with a manifold design is more about marketing than anything else. The average person isn't going to be able to select an intake manifold based on port cross section information etc, so this recommended RPM range is used instead.
A larger dual plane intake might fit the requirements you've discussed for a carburetted engine, but I doubt the ROI is there. Unless Trickflow decide the dual plane market is something they want to pursue.
As far as an intake for EFI, something like the manifold used on the Gen III Hemi, where the plenum sits under the long runners, might be the best compromise. Most of those wanting low RPM torque are probably not wanting to modify their factory hoods, so low profile would be something they'd want.
Alan Jones
Re: Are new intake designs needed for big engines? [Re: feets] #2883016
02/02/21 09:07 AM
02/02/21 09:07 AM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
Just do this with 2 of Doms carbs. Only thing better would be blower or turbo. The fuel goes from the blades directly into the cylinder. No better design for n/a that i know of.
Re: Are new intake designs needed for big engines? [Re: mopar dave] #2883020
02/02/21 09:24 AM
02/02/21 09:24 AM
MD
JACK1440 Offline
JACK1440  Offline
MD
We I went to the 572", I went to the Indy 3x.
Re: Are new intake designs needed for big engines? [Re: JACK1440] #2883079
02/02/21 12:37 PM
02/02/21 12:37 PM
rust belt
Moparite Offline
Moparite  Offline
rust belt
Quote
That skews the results since the cam will still dictate the operating rpm. Overlap is overlap no matter how many inches you have.
I've got Edelbrock Performer RPM heads being ported as we speak.
From what i found that's a duel plane intake. Duel planes are good for low to mid rpm performance. A tunnel ram is not going to work! Seems everybody is all over the place here. Sounds like that is what you are after low-mid rpm. With that said you need to match the other components accordingly. A duel quad tunnel ram is not going to perform well with a stump pulling cam. Unfortunately there is not a lot of aftermarket support stump pulling motors(low rpm performance). Until someone comes up with variable valve timing for big blocks it's a compromise where you want your power range.
Re: Are new intake designs needed for big engines? [Re: moparx] #2883114
02/02/21 02:15 PM
02/02/21 02:15 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
No long rams for me just a good ol fashioned in line tunnel ram and enjoy the new found torque and hp.....
Re: Are new intake designs needed for big engines? [Re: Thumperdart] #2883185
02/02/21 04:27 PM
02/02/21 04:27 PM
Sydney,Australia
tex013 Offline
tex013  Offline
Sydney,Australia
you want a intake of sufficient capacity to easily feed 500+ cubes . You dont always want a "race" motor . You would prefer under bonnet .
Why not look at the Modman ? Dual Eddy/Carter carbs , 6 pack and a large plenum . Will it make most power ? probably not . Will it feed the motor , yep . I never found it a problem on the street though it was soft leaving at the track . But i was only using a 440. Intake volume was right at about 5 L . Seems a few NSS guys are running them happily .
Tex
New best ET 10.259@129.65 .
New best MPH 130.32
Finally fitted a solid cam,
stepped it up a bit more
3690lbs through the mufflers
Power by Tex's Automotive
Re: Are new intake designs needed for big engines? [Re: tex013] #2883201
02/02/21 05:05 PM
02/02/21 05:05 PM
Red Deer, Alberta
Greenwood Offline
Greenwood  Offline
Red Deer, Alberta
Forgive me if I'm wrong, but am I recalling correctly that you're going FI on this beast? Another thread on hemi bathtub and cross ram intakes made me wonder if modifying a wedge cross ram for port injection with a couple of throttle bodies up top wouldn't be a way to go. Maybe a bit on the spendy side, but it seems that drilling and tapping the intake manifold ports would be easy, and you can keep it all under the lid. If you had no compunctions about doing the same to a long-ram intake, would also be a potential avenue. (Or, am I going to be told to put down the whiskey and back slowly away...?)
Re: Are new intake designs needed for big engines? [Re: Greenwood] #2883247
02/02/21 07:20 PM
02/02/21 07:20 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
Im no expert but my 5500 lb truck is not lacking much TQ down low with a 392 and 3.55s, it could use a little more but it is mostly due to CID witch you have covered, I would run something like a single plane trickflow with some port work, a dual plane is gonna give you more TQ down low and restrict it up high, with a TQ oriented manifold on a 500+ engine your gonna need a very tight converter to even be able to use that low end TQ. Theories are great and all but a lot of times they are not much ffun or just don't work in the real world.
Re: Are new intake designs needed for big engines? [Re: HotRodDave] #2883348
02/02/21 10:31 PM
02/02/21 10:31 PM
Minnesota
Hemi_Joel Offline
Hemi_Joel  Offline
Minnesota
I'm not a scientist, so take this with a grain of salt. But I think that using the 110 CFM in your formulas is messed up. Because of different vacuum levels. Heads and intake ports are generally tested at 28 in of water column. That is an equivalent of approximately 2 in of mercury. Atmospheric pressure is approximately 14 inches of mercury pressure trying to fill your cylinder. 14 in of mercury pressure is going to push a lot more air through your ports than 2 in of Mercury.
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: Are new intake designs needed for big engines? [Re: Hemi_Joel] #2883358
02/02/21 11:03 PM
02/02/21 11:03 PM
Southern Alberta
Uberpube Offline
Uberpube  Offline
Southern Alberta
Be nice to see something like the pro-flow efi manifold in a max wedge port, or the weiand dual carb tunnel ram in max wedge.
I ended up with Indy dual plane with MW ports.
Re: Are new intake designs needed for big engines? [Re: Uberpube] #2883610
02/03/21 03:19 PM
02/03/21 03:19 PM
If you look at the SS/AH motors that require a "cross ram " intake almost all of them have very small offsets with more than likely runners that go straight to the intake valves, not like the Rat Roasters and NASCAR intakes with intake runners that are on the other side of the manifolds feeding across the motor to the intake valves work scope
Re: Are new intake designs needed for big engines? [Re: Cab_Burge] #2883661
02/03/21 04:51 PM
02/03/21 04:51 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Originally Posted by Cab_Burge
If you look at the SS/AH motors that require a "cross ram " intake almost all of them have very small offsets with more than likely runners that go straight to the intake valves, no like the Rat Roasters and NASCAR intakes with intake runners that are on the other side of the manifolds feeding across the motor to the intake valves work scope
The offset is rule driven or they would be straight. At the RPM they run, no need for a long runner. Hence no crossed runners. Decent sized plenum especially with undersize carbs.
Doug
Re: Are new intake designs needed for big engines? [Re: Hemi_Joel] #2884181
02/05/21 12:42 AM
02/05/21 12:42 AM
Irving, TX
feets Offline OP
Senior Management
feets  Offline OP
Senior Management
Irving, TX
I agree. I brought that up because it's the simple math many people will refer to. I tried to temper that statement with the the other variables.
Hard to say what the actual flow is because conditions change and head flow is modified by the intake. Due to the different shapes and lengths of the runner path (throttle to valve) it's a bit of a crap shoot. I was thinking that most street oriented intakes are designed with stock-ish head flow values. Bigger engines really perk up with bigger heads. A little more intake might help.
I really like the idea of the Indy 2D intake but the casting quality really seems like second rate Chinese garbage. Drop good money on the intake and drop that much more getting someone to straighten it out and make it fit the heads.
- Stu Harmon
Re: Are new intake designs needed for big engines? [Re: Greenwood] #2884184
02/05/21 12:45 AM
02/05/21 12:45 AM
Irving, TX
feets Offline OP
Senior Management
feets  Offline OP
Senior Management
Irving, TX
I will try to run my EFI intake if I can fit it under the hood. The height is good but the throttle body neck might need to be reworked. It will require a different engine accessory arrangement due to the AC lines passing across the front of the engine.
It's an old Weiand tunnel ram with the top replaced by a 390 cubic inch plenum and a forward facing 1700 cfm throttle body. It's currently set up with 120 lb/hr injectors but that's a wee bit big for this engine.
- Stu Harmon
Re: Are new intake designs needed for big engines? [Re: feets] #2884417
02/05/21 05:08 PM
02/05/21 05:08 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
i would think the real issue is building for 5300lbs and 3.23 gear. what are the goals? i don't think there is one correct answer for the question of manifolds.
Page 2 of 3 1 2 3
