Re: Best Starter for high compression Big Block
[Re: boatracer572]
#2882083
01/30/21 03:44 PM
01/30/21 03:44 PM
Posts: 1,927 Seaford, Va
Kindafast
Seaford, Va
MSD is junk , I have one and it's no better than a stock mini starter.. Just my 2Cents
6.50 @105.26
[Re: Moparrob68]
#2882127
01/30/21 07:14 PM
01/30/21 07:14 PM
Posts: 883 Missouri
jwb123
Missouri
I have been using just a stock chrysler mini starter for many years no issues, current engine is a 540 with 13 to 1 compression, locked distributor, I have a 16 volt battery. But if you retarded the timing with an MSD box and it kicked back something is wrong. If you have a crank trigger, the rotor phase needs to be done just to make sure it runs right, if the box retarded the timing and it kicked back due to improper rotor phase, then you must be very close to being off just to run the engine. One thing on rotor phasing the shorter the gap has to jump in the distributor, the more voltage is left for the spark plugs to fire, if the phase is off you may be losing voltage at the plugs. I use the MSD digital 6 box, it retards the timing 20 degrees for starting, hot or cold it always starts, no kick back, unless the battery is low, I don't run an alternator on my car.
[Re: jim sciortino]
#2882295
01/31/21 09:22 AM
01/31/21 09:22 AM
Posts: 1,629 pa
572charger
pa
1989 dodge dakota mini starter in mine for 20 yrs 600 cuin hemi !!!!
606 hemi pump gas best 9.60 at 142mph on motor 05 hemi daytona 1500 go-mango 4wd quadcab 2007 hotrod mag pump gas drags runner up, roadkill nights dodge big tire winner 2018 2019 back to back
[Re: 572charger]
#2882296
01/31/21 09:33 AM
01/31/21 09:33 AM
RapidRobert
In a yard what is the best yr/make mini to ask for?
[Re: JD Dart]
#2882497
01/31/21 05:31 PM
01/31/21 05:31 PM
Posts: 19,384 Las Vegas
Al_Alguire
Las Vegas
I have a Powermaster on the 605 and a Meziere on the 655. Dont buy MSD its just offshore junk since the Holley takeover.
[Re: Sammy]
#2882702
02/01/21 09:38 AM
02/01/21 09:38 AM
Posts: 13,387 Marion, South Carolina [><]
an8sec70cuda
I've had the MP mini starters on 2 cars for years w/ no issues. One is a 10:1 440 and the other is my 11:1 575" hemi. I have a standard stock replacement mini starter off a '90 something model truck on a 14:1 440 for a long time w/ no trouble either.
[Re: Moparrob68]
#2882734
02/01/21 12:40 PM
02/01/21 12:40 PM
Thumperdart
State of confusion
Stock V-8 Dakota starter....
[Re: Thumperdart]
#2882758
02/01/21 01:48 PM
02/01/21 01:48 PM
Kindafast
Seaford, Va
Not to try and hack this post , but I hear about the 16Volt batteries. How would that voltage effect 12 Volt wiring and lights ?? I have always stayed away from 16 volt stuff from lack of knowledge about it..
6.50 @105.26
