New engine pic...
#2880871
01/27/21 01:10 PM
01/27/21 01:10 PM
Posts: 11,734 Portage,michigan
B3422W5
Portage,michigan
New motor going in my Dart 418, excellerator intake, eddie heads, 260/264 Howards flat tappet, small tube headers. 12.5 compression, 8 inch vert, 275 radial, 4.30 gear. 850 race brawler, red and black carb going on it. Headers( 1 5/8) likely cost a little power, but they fit nice and i have them already. Cam is the same i had in the 360, should be more suited here. https://www.forabodiesonly.com/mopa...-4454-afd4-8d5d7846d223-jpeg.1715675538/
69 Dart GTS A4 Silver All steel, flat factory hood, 3360race weight 418 BPE factory replacement headed stroker, 565 lift solid cam, footbrake street/strip car Best so far, 10.32 1/4 1.41 best 60 foot 6.56 at 104.17
Re: New engine pic...
[Re: n20mstr]
#2880904
01/27/21 02:07 PM
01/27/21 02:07 PM
Posts: 13,419 Marion, South Carolina [><]
an8sec70cuda
looks good, but more importantly im sure its going to run well !! ![up up](/ubbthreads/images/graemlins/custom/thumbs_up.gif) Ought to make short work of that 8.75. ![biggrin biggrin](/ubbthreads/images/graemlins/custom/biggrin.gif)
[Re: Kindafast]
#2881449
01/28/21 07:59 PM
01/28/21 07:59 PM
B3422W5
Portage,michigan
Any idea on HP in that setup ?? Not much...lol Heads go low 270’s at 550. Cam is 565 gross lift. Flat hood. If i had to guess probably 530-540. Hoping it will run 10.70’s in good air at 3300+, maybe 124 ish mph Any more power, even footbraking like i do, the 8.75 wont be happy Also keeping the 1 5/8 headers on it. Hoping for an Allis Chalmers type deal, mild rpm, low, low maintenance.
[Re: dvw]
#2881450
01/28/21 08:02 PM
01/28/21 08:02 PM
B3422W5
Portage,michigan
Yes sir. Hope to see it in my travels this year. Doug Norwalk, Bowling Green, couple outings at Mid Michigan, and lots of US 131 i hope. Sure i will see ya several times Doug
[Re: slantzilla]
#2881520
01/29/21 12:13 AM
01/29/21 12:13 AM
B3422W5
Portage,michigan
Nice! I'm diggin' the valve covers. Had a dickens of a time finding a brand new set of them. Easy finding a carb to match though
[Re: GTS340]
#2881964
01/30/21 09:28 AM
01/30/21 09:28 AM
B3422W5
Portage,michigan
Valley performance and machine, Ionia Mi They are the guys who built that stout stock stroke 360 with Victor heads that won the engine shootout. Several threads on here about it.
[Re: B3422W5]
#2881970
01/30/21 09:51 AM
01/30/21 09:51 AM
Posts: 403 Romulus, MI
GTS340
Romulus, MI
They are the guys who built that stout stock stroke 360 with Victor heads that won the engine shootout. Several threads on here about it. Was the Victor headed build what made you chose them? How is their turnaround time?
