Re: 516 vs 915 heads [Re: Cab_Burge] #2881124
01/27/21 10:39 PM
01/27/21 10:39 PM
s. e. pa.
calrobb2000 Offline
calrobb2000  Offline
s. e. pa.
hi
i have done several sets with hard seats installed for 1.74 valves for 383 s . use bronze guide liners also !
light port and blend and no problems . work good .045 milled off for compression .
intake side milled also .
Re: 516 vs 915 heads [Re: an8sec70cuda] #2881146
01/28/21 12:04 AM
01/28/21 12:04 AM
AndyF Online content
AndyF  Online Content
Originally Posted by an8sec70cuda
There was a set of 516s needing to be rebuilt on one of the Mopar Facebook pages for sale earlier this week I believe for $100.
Sounds like $100 too much. I throw 516 heads away when they come in my shop.
Re: 516 vs 915 heads [Re: Cab_Burge] #2881177
01/28/21 06:22 AM
01/28/21 06:22 AM
North Sweden
RT540 Offline
RT540  Offline
North Sweden
Originally Posted by Cab_Burge
Originally Posted by fouronthefloor77
I had some 906 heads rebuilt with hardened exhaust seats, With new valve seals and OEM valvesprings the tab was $674
he is in Sweden, probably harder to get them fix over their.
It might be cheaper, easier and better to buy a new set of aluminum heads like 440 source, Speedmasters or Pro Comps scope twocents
I would rather buy Edelbrock street heads, than the above china brands. I will get Eddys for the 440 build for a Satellite 68 I bought in december.
The 516 would be a budget build with homeporting the bowls. But I guess there is limit on how much to spend before new alum heads would be a much better choise.
Re: 516 vs 915 heads [Re: calrobb2000] #2881178
01/28/21 06:24 AM
01/28/21 06:24 AM
North Sweden
RT540 Offline
RT540  Offline
North Sweden
Originally Posted by calrobb2000
hi
Thanks for the info, any size or even better part nr for the hard seats? My machinist is a metric for mm instead of inches.
Milling the intake side is a good move.
Re: 516 vs 915 heads [Re: RT540] #2881458
01/28/21 08:39 PM
01/28/21 08:39 PM
s. e. pa.
calrobb2000 Offline
calrobb2000  Offline
s. e. pa.
S B I
is the brand he uses but i dont konw the part no .
Re: 516 vs 915 heads [Re: calrobb2000] #2881575
01/29/21 07:58 AM
01/29/21 07:58 AM
North Sweden
RT540 Offline
RT540  Offline
North Sweden
Sent an e-mail to tech at S.B. international asking for the smallest outside diameter hard seat for a 1,74 valve.
Will have my machinist give me a total cost for both seat work and bronze guides, then will se if these heads will either end up in the attic, or on the 383-70 D200 truck of mine.
Re: 516 vs 915 heads [Re: calrobb2000] #2881774
01/29/21 04:31 PM
01/29/21 04:31 PM
North Sweden
RT540 Offline
RT540  Offline
North Sweden
S B I is the brand he uses but i dont konw the part no .
Here is the answer from SBI : I would recommend the SB1812-12 for the 1.74” valve.
Depth 7/32
Exact O.D. 1.8175
I.D. 1-5/8
Re: 516 vs 915 heads [Re: AndyF] #2882805
02/01/21 03:58 PM
02/01/21 03:58 PM
an8sec70cuda Offline
That's all well and good if your customer has enough of a budget to spend $1200+ on new cylinder heads. Many do not.
Before you say you'll spend that much on rebuilding stock heads...that all depends on where you're located and who's doing the work. I've had stock cast iron heads rebuilt and spent way less than I see a lot on here quoting.
All depends on the end goal, but a pair of 516 heads can be made into very capable high performance heads that make good power.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: 516 vs 915 heads [Re: an8sec70cuda] #2882877
02/01/21 07:21 PM
02/01/21 07:21 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
Not without added costs over buying a core and just rebuilding them. Then you are stuck with iron heads that cost about as much as the Aluminum heads and don't make more HP, not to mention the AL heads still have room to improve if you want to go that route.
Stock rebuilt they are fine. You start porting and such then you have to think hard about how to spend your money.
Re: 516 vs 915 heads [Re: Sniper] #2995715
12/16/21 08:08 AM
12/16/21 08:08 AM
Isle of Sheeps
Gtxxjon Offline
Gtxxjon  Offline
Isle of Sheeps
If you have to spend more than $600 on a refresh, then you must go Aluminium.
But I would never spend time and effort on a 516 anyways!
I have wrecked several pairs trying to get the exhaust ports 'into shape'. sawzall ozbbq
Some are cast with the very bad roof port bulge that cannot be enlarged.
But I recently came across some 516 castings 1964 and 1965 that have the later style '915' 'LARGE' exhaust port, go figure? realcrazy
All the 1966 heads that I have ported and subsequently ruined have the collapsed roof...
So I cut my old 1966-516 race heads up to see why?
I'm guessing its a 'foundry flaw' with damaged casting-moulds from 'over use'...
Pictures to follow for anyone who 'maybe' interested lol... fan
Carpe diem, quam minimum credula postero, thanx Horace!
There’s no point trying to fix stuff that ain’t broke,,, 'but if ain’t broke',,, you is not trying hard enough...
Re: 516 vs 915 heads [Re: Gtxxjon] #2995729
12/16/21 09:08 AM
12/16/21 09:08 AM
North Sweden
RT540 Offline
RT540  Offline
North Sweden
Here´s my 516 from -66 that now have 2,14 and 1,74 Milodon valves.
New valve guides and hardened exhaust seats plus valves cost me as much as Edelbrock street heads.
Live and learn!
Re: 516 vs 915 heads [Re: RT540] #2995938
12/16/21 09:12 PM
12/16/21 09:12 PM
MYRTLE BEACH SOUTH CAROLINA
E
ek3 Offline
ek3  Offline
E
one thing i learned long ago, brand new heads can be junk out of the box. one of the most important parts on your engine! how well i know the sound of a great valve job when it first fires it off... you should spend whatever it takes to get them right no matter what head you use. if it cost to much , then you should save some more money! up
Re: 516 vs 915 heads [Re: ek3] #2996008
12/17/21 06:35 AM
12/17/21 06:35 AM
Isle of Sheeps
Gtxxjon Offline
Gtxxjon  Offline
Isle of Sheeps
Stuff is expensive to get done in Euroland these days!
I worked at a place called ''Rovercraft'' a specialist V8 workshop.
We very rarely did iron head work since the Millennium...
Seat work was always Aluminium heads and guides were 'knock out and re-fit new ones.
The last set of iron heads I had done was approx £250 to fit seats and 3-angle cut, per head!
Guides are always worn and some heads are on their second or third set of guides...
But now I see a different issue with heads!
Worn out 'stainless steel' exhaust-valve 'stems and seats', at an alarming rate...
The stainless is much softer than the older steel/alloy exhaust valves?
Now there is 'head warpage' too!
I took a set of Mopar performance '452 aluminuim' heads off a low mileage 440ci engine and one head was badly BENT/BOWED etc!
It was in fact 1/2mm which is 0.020 thousanths... fan
Once it had been machined flat the outer combustion chambers were way out of cc spec.
So you have to reseat the valves to match the centre cylinders and re-shape the chamber to get the volume right again.
Then you have to re-machine the rocker pedestal channels as they are 0.020 bowed as well...
All in all it was much work I would have called it scrap myself... spank spank drumhit
You fix one problem and get another... drinking
Re: 516 vs 915 heads [Re: Gtxxjon] #2996011
12/17/21 06:51 AM
12/17/21 06:51 AM
Isle of Sheeps
Gtxxjon Offline
Gtxxjon  Offline
Isle of Sheeps
If you own a pre 1966 car/truck and you are only grocery getting, then 516 heads are FINE!
My grocery getting days in a Mopar are well and truly over for me...
I love Mopar iron heads and am always happy to spend an hour or twenty on them.
My own bug-bear' with 516 heads is, they ''break through' real easy on the exhausts, even with mild port work... panic violin fan
They have a bad exhaust port and that's how it is... ozbbq
The 'Stan Weiss' Flowchart is mind-blowing and takes some reading!
516 Intakes around 220 cfm which is poor.
No 915 'raised port' flow numbers, but they are basically 'closed chamber 906's.
A very trick 906 intake will get you somewhere near too 300 cfm's...COOLIO...
So if you can get 300cfm with any head you need approx, 75% for the exhaust too...(225 cfm).
There is one set of stock '2.08-1.74' 906 heads with 250cfm flow.
If you can start with those numbers you are onto a winner lol... drive
