Hello and welcome to the board !!
..Nobody took this one so I'll step up...
...Starting from the top left in your pic...First strap is the heater hose retainer that goes on the passenger side inner fender above the shock nut...One end snaps into the fender hole, the hoses are added then it loops back around and fastens to itself....
...The next two black straps are wiring retainers that are located at the battery tray area of the drivers inner fender...Look close to the top of where the battery would be and you'll see the two holes for each strap strattling the wiring recess channel...
...The 6 white wiring retainers go various spots in the engine bay...Two near the mastercylinder/prop valve area then one farther down the wiring near the shock tower on that side..One on the firewall above the heater motor...And possibly one near the horns but I've also seen a black retainer in that position {like the ones in the last set of three in your bottom row}...Last strap in the top row is the positive battery cable strap...That one slips over the shock stud then loops/fastens to itself to hold the cable in that area...So the pos. cable would route from the starter, to the frame bracket {under the mastercylinder} then up to that shock stud retainer... And lastely the lower 3 black retainers...Two go on the firewall below the voltage regulator/wiper motor area to hold the big bundle of wiring coming across that area...3rd goes in the hole to the rear of the upper horn on the pass.inner fender if originally equipted....So now that I have your head spinning...
...Check out this site and look at the engine bay pics for some reference material...
moparr consulting guide ... If you're still hung up on any of the pieces let me know and I'll post some pics if the peticular strap in question...
Colin
