Re: 383 Stroker Advice
[Re: AndyF]
#2880036
01/25/21 05:42 PM
01/25/21 05:42 PM
Posts: 4,700 Wichita
GY3
Wichita
I agree with using a 400 block instead of 383. No reason to give up bore sizing and the packaging size is the same.
With my RB 505, I'm at 10.3:1 and can run the cheapest pump swill out there but typically run 91 No Ethanol.
Deep gearing and high stall aren't required when you have a stroker because of the massive torque at low rpm they produce (assuming cam choice is correct).
We run a (rated) 2800 stall 11" converter and 3.54 gears and the car still 60 ft.'s really hard!
[Re: GY3]
#2880064
01/25/21 06:39 PM
01/25/21 06:39 PM
Posts: 3,024 NY
B1duster
NY
If you already have a 383 block and can’t easily get a 400 block, use the 383. I have a 383 .030 with a 440source stroker kit. Makes 489 cubes. Mine has flat top pistons and will be 11-1 with Ported Edelbrock heads. Comp XR292R solid roller and a tunnel ram with dual carbs. I bought the unassembled short block off Greg’s list, 4.25 stroke 6.535 rod, 440source kit. I thought about getting a 400 block and getting new pistons but decided to use what I have. If your starting from scratch, then start with a 400. Your most likely going to want to use a dished piston. http://store.440source.com/Stroker-Kits/products/3/ Good luck.
[Re: RATTRAP]
#2880506
01/26/21 04:41 PM
01/26/21 04:41 PM
Posts: 3,024 NY
B1duster
NY
[Re: B1duster]
#2880514
01/26/21 04:56 PM
01/26/21 04:56 PM
Posts: 43,285 Bend,OR USA
Cab_Burge
I wonder which Gregg they are talking about? OP, don't spend your time and money using this combination, buy a longer stroke crank to make more power, either have a used 440 crank if you have one, and have it ground down on the mains and counter weights to fit your low deck block and have the rods offset ground down to BB Chevy rod journal to increase the stroke to 3.900 or 3.910, what ever the crank grinder can get you If you don't have or can't buy one, forged steel 440 crank, really cheap, buy a new 4.250 stroke crank and buy the parts you need to make the kit you want for your motor. The first low deck pump gas stroker motor I built back in the early 2000 was a 400 block that needed four sleeves to make it useable, I bought a Ohio Crankshaft Company 4.250 stroke low deck crank and a set of China made CAT brand BB Chevy type forged H beam rod that had the BB Chevy wrist pin and rod bearing size that was 6.700 long, I had Ross Pistons make me a set of dished pistons that gave me 9.25 to 1 compression ration with the pistons down .025 from the deck and using a .017 thick beaded steel head gasket with a set of big valve mildly ported 906 heads that had 84.0 to 84.5 CC chambers. These parts made 9.25 to 1 compression ratio for CA pump swill back then. I ended up using a custom ground Comp Cams solid roller cam that was 260 degrees @.050 on the intake with .420 lobe lift and it had 266 @.050 on the exhaust lobes with .409 lobe lift ground on a 108 LSA installed at 107 ILC. I used a low deck dual plane Eddy six pack intake with a set of 1970 440 automatic carbs modded by C and J Engr. in Whittier, CA for street and strip use. That motor made 592 HP at 5000 RPM on the first pull I ended up testing three different sets of carbs on that motor that day, the best set made 612 HP at 5500 RPM with 644 Ft. Lbs. torque at 4500 RPM, the worst set, new 1971 440 automatic carbs, made 5 HP less with 7 ft. lbs. less torque That motor exceeded my wildest hopes and made me open my mind on how to build pump gas Mopar BB stroker for street and strip cars Good luck on your deal Big is best, C.I., cam, heads, carb and intake size, good stall converter, biggest tires you can fit and light is right on rotating parts like the rods, pistons, valves, rocker arms, wheels and tires and crankshaft and car and driver weight
[Re: B1duster]
#2880603
01/26/21 07:36 PM
01/26/21 07:36 PM
Posts: 3,024 NY
B1duster
NY
[Re: Cab_Burge]
#2880748
01/27/21 03:23 AM
01/27/21 03:23 AM
Posts: 3,024 NY
B1duster
NY
[Re: B1duster]
#2880750
01/27/21 03:39 AM
01/27/21 03:39 AM
Cab_Burge
I didn't see any mention of the jetting or AFR on that build in that article I have dyno tested a bunch of motors with jet changes and did a lot of at the track testing to get the best ET and MPH, none of the motors or cars like real rich mixtures below 12.5 AFR, usually 13.2 to 13.6 AFR was the best jetting for that car or engine that day with the weather I've seen .4 ET and 4.0+ MPH gain going from 11.8 AFR to 13.3 at the track on the same day on a pump gas street car That owner loved it
[Re: 69dart]
#2883127
02/02/21 02:56 PM
02/02/21 02:56 PM
Posts: 494 IL
EchoSixMike
IL
ICON has shelf pistons for 3,375, 3.75/4.25 and 4.15 stroke combos, they are the manufacturer for the 440 source pistons. If you want more compression than a flat top gives you, you need to be talking to Diamond for custom/semi-custom stuff. S/F....Ken M
