Page 4 of 6 1 2 3 4 5 6
Re: RR project 700 hp street/strip [Re: AndyF] #2877650
01/21/21 01:15 AM
01/21/21 01:15 AM
AndyF Online content OP
AndyF  Online Content OP
We're making progress a little bit at a time. I've built several custom wire harnesses for the EFI system as well as the different systems going into the car. We're making all the new harnesses look like factory ones with vinyl wrap and factory hold downs. Just finished up a bracket to mount the Hyperspark coil on the end of the cylinder head next to the distributor. First version I built had the coil vertical but I decided it worked better horizontal so I redid the design.
Re: RR project 700 hp street/strip [Re: AndyF] #2877668
01/21/21 02:30 AM
01/21/21 02:30 AM
Boise
Moparteacher Offline
Boise
That's an interesting pcv fitting on the valve cover. From what I can see it appears to be an 1/8' 90* pipe fitting with a pipe to hose fitting. Are you running a fixed orifice or is there something else to meter crankcase ventilation that's not pictured?
Thanks.
Re: RR project 700 hp street/strip [Re: Moparteacher] #2877672
01/21/21 02:50 AM
01/21/21 02:50 AM
It is an adjustable fixed orifice PCV setup. EFI requires a fixed orifice PCV but nobody makes them for Mopar so I had to improvise. If you own a GM product then you can use the fixed orifice PCV that GM used on a few cars back in the early days of EFI.
Re: RR project 700 hp street/strip [Re: AndyF] #2877699
01/21/21 07:55 AM
01/21/21 07:55 AM
portland, ct
Since1822 Offline
Since1822  Offline
portland, ct
Looks great Andy! Have you thought about making your valley plates with a removable center? Wondering if that is the trick flow one?
Re: RR project 700 hp street/strip [Re: Since1822] #2877828
01/21/21 01:09 PM
01/21/21 01:09 PM
I was making plates with a removable center before Trick Flow came along. I stopped making them when Trick Flow started to sell theirs.
Re: RR project 700 hp street/strip [Re: AndyF] #2878246
01/22/21 10:16 AM
01/22/21 10:16 AM
Rockford,Il
DFlanagan Offline
DFlanagan  Offline
Rockford,Il
What brand of plug wire looms are you using? Those are very neat and tidy.
Re: RR project 700 hp street/strip [Re: DFlanagan] #2878937
01/23/21 02:45 PM
01/23/21 02:45 PM
moparx Offline
moparx  Offline
they look like the "made for you" [?] brand.
if that's not the brand, try looking up nylon plug wire separators.
i know they are made in several sizes, at least 7, 8, 8.5, and 10mm.
you can find these on the 'bag, or amazon.
beer
Re: RR project 700 hp street/strip [Re: moparx] #2879462
01/24/21 04:29 PM
01/24/21 04:29 PM
Rockford,Il
DFlanagan Offline
DFlanagan  Offline
Rockford,Il
Ya, that’s what I was thinking they probably are.
Re: RR project 700 hp street/strip [Re: AndyF] #2879615
01/24/21 09:35 PM
01/24/21 09:35 PM
We moved the front spring eye to the upper hole to see how the car looks. Also added a thin wheel spacer and then lowered the front a couple of turns. The car is starting to look like the owner wants it. Still a work in progress since the glass isn't in the car and the interior is bare. So the car is probably light by at least 200 lbs.
Re: RR project 700 hp street/strip [Re: AndyF] #2879619
01/24/21 09:37 PM
01/24/21 09:37 PM
I'm still working on the electrical system. I have a couple of the new wiring harnesses built and have a couple more to go. Looks like the best way to go is to mount a small relay module under the battery tray. The relays will handle the fuel pump as well as both electric fans.
Re: RR project 700 hp street/strip [Re: AndyF] #2879696
01/24/21 11:47 PM
01/24/21 11:47 PM
USA
hudsonhornet7x Offline
USA
Looks very nice Andy. I would like to know more about the battery. What is it? What needs changed in the electrical system to run it? Since this car will be street driven and not just raced, I am very curious. Thank you.
Re: RR project 700 hp street/strip [Re: hudsonhornet7x] #2879712
01/25/21 12:49 AM
01/25/21 12:49 AM
It is a half sized battery from Braille. Nothing in the electrical system needs to be changed to run it, you just need a good alternator to keep it charged. I use the same battery in both of my cars.
Re: RR project 700 hp street/strip [Re: AndyF] #2879726
01/25/21 01:19 AM
01/25/21 01:19 AM
Sac, CA
mopowers Offline
mopowers  Offline
Sac, CA
What alternator do you run with it?
Re: RR project 700 hp street/strip [Re: mopowers] #2879895
01/25/21 02:18 PM
01/25/21 02:18 PM
I use a Denso alternator on anything I build.
Re: RR project 700 hp street/strip [Re: AndyF] #2884471
02/05/21 07:24 PM
02/05/21 07:24 PM
The black out paint behind the grille is finished and the new instrument cluster from Dakota Digital is here.
Re: RR project 700 hp street/strip [Re: AndyF] #2885259
02/07/21 06:51 PM
02/07/21 06:51 PM
S.F. Ca.
DirectConnection Offline
S.F. Ca.
what is the wheel tire combo upfront
backspacing etc
looks great
Re: RR project 700 hp street/strip [Re: DirectConnection] #2885329
02/07/21 09:34 PM
02/07/21 09:34 PM
Minnesota
RROD Offline
RROD  Offline
Minnesota
What block are you using? I see cross bolt main bolts.
Re: RR project 700 hp street/strip [Re: RROD] #2885355
02/07/21 10:46 PM
02/07/21 10:46 PM
USA
USA
It looks like a modified stock block to me, but I could be wrong.
Re: RR project 700 hp street/strip [Re: hudsonhornet7x] #2885357
02/07/21 10:55 PM
02/07/21 10:55 PM
Mo.
racerx Offline
racerx  Offline
Mo.
I believe that's the 514 stock block that was modified work the test mule.
Re: RR project 700 hp street/strip [Re: DirectConnection] #2885404
02/08/21 01:33 AM
02/08/21 01:33 AM
backspacing etc
looks great
Tires are 225/70-15. I don't know the wheel specs.
