Re: Speedmaster timing cover
[Re: 70Drop]
#2878769
01/23/21 08:49 AM
01/23/21 08:49 AM
Posts: 10,555 Rittman Ohio
fourgearsavoy
Rittman Ohio
A while back when they first started selling them I wanted to actually see one at the store but they didn't have one in stock. I was kind of worried that it didn't have dowels to keep the seal centered on the cover portion. I didn't want to get one until I actually could hold it in my hands so I passed. Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
[Re: jlatessa]
#2879220
01/24/21 02:39 AM
01/24/21 02:39 AM
Posts: 223 California
70Drop
California
Did this to our stock cover, had a friend water jet a1/8" thick round piece and welded it to the cover.
Used a bearing button with a few thousands clearance for cam control.
Works great with just a tad interference to the back of the Al. water pump housing.
Joe Great idea and nicely executed. I also like that valley tray
[Re: 70Drop]
#2879270
01/24/21 11:15 AM
01/24/21 11:15 AM
Posts: 1,318 Ohio
jlatessa
Ohio
Thanks, I think it was an Edelbrock tray??
Joe
PS Nice for a change not having to worry about oil being sucked into the intakes.....
[Re: jlatessa]
#2879433
01/24/21 03:17 PM
01/24/21 03:17 PM
70Drop
California
Nice for a change not having to worry about oil being sucked into the intakes..... Exactly! I'm gonna go to Edelbrock and check out that setup
[Re: jlatessa]
#2879435
01/24/21 03:22 PM
01/24/21 03:22 PM
Posts: 19,449 north of coder
moparx
was that the way the elelbrock tray comes, or did you add the wings for the intake ? i agree, nicely executed tray ! what did you use for gasket material on the wings ? TIA.
[Re: moparx]
#2879930
01/25/21 02:53 PM
01/25/21 02:53 PM
Posts: 2,810 Sobieski Wi
bee1971
Sobieski Wi
That tray will not work for RPM Heads or E Street
See the side bolts on the valley tray / pan that the Victor Heads accept or bolt to
1971 Dodge Charger Superbee 2011 Ram Sport 1500 Quad Cab Deep Water Blue Loaded Siberian Huskies
[Re: moparx]
#2879959
01/25/21 03:29 PM
01/25/21 03:29 PM
Posts: 43,213 Bend,OR USA
Cab_Burge
That tray is made for the Victor heads on both RB and B motors, two different trays. They work well on the Speedmaster Victor clone heads also
