Re: any Thermoquad experts here?
[Re: cudaman1969]
#2875259
01/16/21 09:03 PM
01/16/21 09:03 PM
Posts: 2,863 middle Tennessee
mopower440
middle Tennessee
You been running regular?! no, 93 octane..wonder what the MOST total timing this thing should be able to stand? 9.5:1 440 bored .030 over, stock iron 452 heads, MP 284/484 cam installed 4 degrees advanced at 104. Holley SD intake, hooker 1 7/8 fenderwell headers, 3000 stall convertor. Idles in park at 900 rpm with between 11-12 inches of vacuum and in park at 700 rpm with 8-9 inches of vacuum.
[Re: B1MAXX]
#2875269
01/16/21 09:32 PM
01/16/21 09:32 PM
Posts: 20,212 Park Forest, IL
slantzilla
Park Forest, IL
What total timing do you have? Is the vacuum advance dropping out at WOT?
[Re: slantzilla]
#2875404
01/17/21 10:17 AM
01/17/21 10:17 AM
Posts: 348 Isle of Sheeps
Gtxxjon
Isle of Sheeps
Nice to see someone in Moparland still playing with their Thermoquads! I have a pile of them waiting for when I get my 71 Gtx back on the road. Always liked the design and I’m sure they can be made to work. As we all know the tuning parts are not readily available these days? I was so busy waffling I forgot my reply. In recent years we have given up playing with vac advance and tuned without it! Give the engine as much advance as she will take to turn over and run (approximately 14 degrees). Have a 20 degree advance plate in the dizzy and the jobs a gooden... Then all that’s left to do is advance spring selection.
Carpe diem, quam minimum credula postero, thanx Horace!
There’s no point trying to fix stuff that ain’t broke,,, 'but if ain’t broke',,, you is not trying hard enough...
[Re: BSB67]
#2875589
01/17/21 03:36 PM
01/17/21 03:36 PM
Posts: 19,629 north of coder
moparx
years ago and i'm talking around 1986 or so] i made some programs for jets, both primary and secondary, and metering rods on a Hardinge CNC machine. i still have the program and tool sheets, but the program itself is on a paper tape. the parts worked good on the several thermoquads i tinkered with ! if i had been smart [YEAH, right.......] i would have cranked out a bunch of those parts and sold them in kits like the strip kits had. i am such a DUMAZZ at times........
[Re: mopower440]
#2875671
01/17/21 06:12 PM
01/17/21 06:12 PM
mopower440
middle Tennessee
also, please verify im looking at the timing numbers correctly: Ok, i have the MP timing tape on the balancer. Using a regular old timing light, i have the distributor at 20 degrees BTDC initial timing..it sits and idles its best at 20. ok, watching the timing tape with the timing light as i bring up the RPM's, it should top out at somewhere between 34-36 BTDC on an engine like this, correct? No matter if the vacuum advance is hooked up or not, it should end up between 34-36 at WOT, correct? Then WITH the vacuum advance hooked up, i may see 40 degrees BTDC at a light cruise, but when stomping it to WOT, it should still drop back to 34-36..correct?
[Re: mopower440]
#2875858
01/18/21 12:34 AM
01/18/21 12:34 AM
Posts: 1,767 Windsor, ON, Canada
Diplomat360
Windsor, ON, Canada
Yes, that is the good way to check. To be safe, I would disconnect the vacum to the distributor altogether and just have mechanical being the ONLY advance it sees. Of course, plug up the hose end, otherwise you've got a small leak.
If this takes care of the problem than you know your vacum is not pulling off when at WOT and your distributor continues to see additional advance beyond just the mechanical.
If that is that case, what is your source for the vacum advance?
[Re: Diplomat360]
#2876233
01/18/21 06:18 PM
01/18/21 06:18 PM
mopower440
middle Tennessee
If that is that case, what is your source for the vacum advance? oh ya, ive disconnected the vacuum advance and its still advancing too far.
[Re: BSB67]
#2876314
01/18/21 09:47 PM
01/18/21 09:47 PM
mopower440
middle Tennessee
Your plugs are too hot. Go two steps cooler. That might eliminate your problem. just curious as to why you say the plugs are too hot? Not debating you at all, just wondering..learning.. Here is a pic of one i pulled yesterday when i checked the cranking pressure.
[Re: dOc …]
#2877158
01/20/21 12:27 PM
01/20/21 12:27 PM
Posts: 892 MA
steve70
MA
Hay guyz .... if you close-up the secondary door ... it WILL richen the mixture up. Y ES You can get secondary jets here; https://www.carbsonly.com/When i talked to him he only had .134, .137 and .143 but you could drill them out to a larger size if needed. The opening of the air door on the secondary's has a huge impact on mixture
1970 Challenger T/A 4 speed
[Re: dOc …]
#2877567
01/20/21 10:08 PM
01/20/21 10:08 PM
Diplomat360
Windsor, ON, Canada
Hay guyz .... if you close-up the secondary door ... it WILL richen the mixture up. Yes, that's what both B1MAXX and I suggested a few days ago...no response though, so I'm not sure if the OP tried or not?
[Re: Diplomat360]
#2877600
01/20/21 11:22 PM
01/20/21 11:22 PM
mopower440
middle Tennessee
Hay guyz .... if you close-up the secondary door ... it WILL richen the mixture up. Yes, that's what both B1MAXX and I suggested a few days ago...no response though, so I'm not sure if the OP tried or not? I did try it..I tightened the air door significantly and even tried limiting how far the air door opens. It MAY have helped a small bit but not near enough. The secondarys have been drilled out for a richer mixture by Demonsizzler who used to be on this site as the thermoquad guru. I have found the timing going way too far.It was advancing into the 50's and with the vacuum advance hooked up, into the 60's! Surprised it didnt ping more than it did! How does the colr of that plug in the pic i posted above look to yall? It red in color instead of tan? Its not black and rich looking though..
