Duane this was your quote. From a trick flow 270 thread. I was a little off. Would you mind explaining a little more in detail? I apologize
“It’s not really that much different of a head than a ported EZ head.......like an EZ295.
Power should be very similar if the heads got swapped on the dyno”
Seems pretty self explanatory.
What I said was speculative........ “power
should be very similar”.
You made it sound like the test had been done, and the results were that the power was “identical”.
I knew I wouldn’t have said it that way.
Until someone actually does the test........ how close the power would be between those two heads is an unanswered question.
