Re: 511” stroker! Rear suspension&gear selection.
[Re: viperblue72]
#2872316
01/10/21 10:51 PM
01/10/21 10:51 PM
Posts: 4,694 Wichita
GY3
Wichita
Calvert split monos and Cal-tracs work really well. Buy the best double adjustable shocks you can afford, but the Calvert 9 positions will work fine to begin with.
You don't need a lot of gear with a stroker. I would do the 3.73's.
[Re: viperblue72]
#2872358
01/11/21 01:06 AM
01/11/21 01:06 AM
Posts: 43,259 Bend,OR USA
Cab_Burge
I had a Mopar brand 2.77 low gear set installed in my old pump gas Duster, that worked well with 3.73,3.91, 4.10 and 4.30 running 315x60x15 M/T Et Street Radials and the same size ET Street bias ply tires with that 400 stroker motor with both the 4.25 stroke crank and the longer 4.300 stroke crank later That car ran 127.+ MPH with the Eddy RPM CNC heads and pickup to 134.+ MPH with the M.W. size Indy SR with a Indy 400-3 intake and several different 1050 CFM Holley Dominator carbs corked up with the air cleaner on using 92 octane OR pump swill from Bend I haven't used the TF270 heads yet and I don't know how they compare to the Indy SR M.W. heads non ported The 4.250 stroke will move the mass a lot easier than the SB motor will with a 4.00 stroke in a SB 340 or 360 motor Good luck on your new build
[Re: Cab_Burge]
#2872364
01/11/21 02:05 AM
01/11/21 02:05 AM
Posts: 2,141 junction city oregon
viperblue72
I had a Mopar brand 2.77 low gear set installed in my old pump gas Duster, that worked well with 3.73,3.91, 4.10 and 4.30 running 315x60x15 M/T Et Street Radials and the same size ET Street bias ply tires with that 400 stroker motor with both the 4.25 stroke crank and the longer 4.300 stroke crank later That car ran 127.+ MPH with the Eddy RPM CNC heads and pickup to 134.+ MPH with the M.W. size Indy SR with a Indy 400-3 intake and several different 1050 CFM Holley Dominator carbs corked up with the air cleaner on using 92 octane OR pump swill from Bend I haven't used the TF270 heads yet and I don't know how they compare to the Indy SR M.W. heads non ported The 4.250 stroke will move the mass a lot easier than the SB motor will with a 4.00 stroke in a SB 340 or 360 motor Good luck on your new build Cab, according to Porter the 270s make identical power to a cnc 295. I had 3:55 behind the small block and I had to slip the clutch a lot to get out there without falling on its face. Switched to 4:30 and it was much easier. Sounds like I’ll be fine with whatever I choose. I won’t be going for ultimate ETs anyways.
[Re: rebel]
#2872365
01/11/21 02:07 AM
01/11/21 02:07 AM
viperblue72
I'm running a 512 in my 'cuda. I'm restricting power as I built the engine combo for our local track series where streetcars are limited to 11.00et's.but on a prepped track it'll go 10.5's. I have 325x50 ET Street R's on a 8 3/4 4.3 geared Detroit locker with old school SS springs & old Comp Eng 3 way adj shocks.. It puts 645 HP to the rear wheels, runs 1.5 60 fts & usually tops out at 125 mph.. That’s impressive power. What’s the combo? Is this a stick car? Also does it too out due to being out of RPM?
[Re: viperblue72]
#2872366
01/11/21 02:23 AM
01/11/21 02:23 AM
Cab_Burge
I forgot to mention that Duster had ladder bars and coil over rear suspension with single adjustable Strange Engr. rear shocks that I change to double adjustable later, which where well worth swapping to I also had two different converters, a 10 Inch Contintental at first until it broke and then switch to a older type 727 T/A 8 inch SS/HA converter which was a ton better than the larger 10 inch Faster and quicker and easier to drive at the track and on the street
[Re: GY3]
#2872371
01/11/21 02:56 AM
01/11/21 02:56 AM
viperblue72
You don't need a lot of gear with a stroker. I would do the 3.73's. Do you remember the spring length to use with offset shackles?
[Re: viperblue72]
#2872372
01/11/21 02:59 AM
01/11/21 02:59 AM
Posts: 31,060 Oregon
AndyF
I am almost finished with my 511” stroker and need to start thinking about the back end of the car. It’s street strip and I know I’ll get a few different opinions on this. Combo is 511 11.6 comp. TF 270 heads Indy sp ported 1050/4150 2 to 2 1/8 header 265/268 .660 on 108 solid roller. 4 speed
It’s a Cuda. I plan a 1” spring relocate and a 9”. I want a 29.5 or 30” tire. I don’t know what leaf springs and cal trac? My thoughts are a 3.73/3.91/4.10 Gear. I’m thinking it should trap around 130?! What would you go with for suspension and gear? Do you have the rear yet? If not you might be interested in the S60 that I'm pulling out of my Duster. I'm going to sell the S60 plus the wheels and tires. It might slide right under your car. It has 4.10 gears and a Detroit Locker along with disc brakes.
[Re: viperblue72]
#2872376
01/11/21 03:50 AM
01/11/21 03:50 AM
Cab_Burge
Yes, I still want to sell it also so I can finish the new car, 1965 Dart back half car
[Re: AndyF]
#2872395
01/11/21 05:19 AM
01/11/21 05:19 AM
viperblue72
It’s a Cuda. I plan a 1” spring relocate and a 9”. I want a 29.5 or 30” tire. I don’t know what leaf springs and cal trac? My thoughts are a 3.73/3.91/4.10 Gear. I’m thinking it should trap around 130?! What would you go with for suspension and gear? Do you have the rear yet? If not you might be interested in the S60 that I'm pulling out of my Duster. I'm going to sell the S60 plus the wheels and tires. It might slide right under your car. It has 4.10 gears and a Detroit Locker along with disc brakes. AndyF, ideally I need a b-body width 60”, but I could go as narrow as 58” and use a 15x8 with 3.5bs. Let me know I would absolutely be interested. And I’m not too far from you.
[Re: viperblue72]
#2872396
01/11/21 05:43 AM
01/11/21 05:43 AM
Posts: 4,647 aotearoa
rebel
aotearoa
No, car is an auto with a loose 8" converter. Its a 400/512 stroker, Stage 6 MW heads with an 850 QF carb on a Super Victor manifold, runs on Pump Gas.
[Re: viperblue72]
#2872413
01/11/21 09:13 AM
01/11/21 09:13 AM
GY3
Wichita
You don't need a lot of gear with a stroker. I would do the 3.73's. Do you remember the spring length to use with offset shackles? I use 20" front segment springs but keep in mind mine is a '63 B-body and, on those cars the spring length is the same as an A-body. Not going to be the same as yours. Call Calvert Racing and they can walk you through the proper selection for your car.
[Re: dvw]
#2872439
01/11/21 09:55 AM
01/11/21 09:55 AM
viperblue72
I'm assuming 2.66 1st gear 833. At least the 4.10 probably could run a 4.56. If street driven Cal Tracks. Good shocks, bias slicks. The clutch better have some slip. If not the 833 may not have a long life span for track use. If it was an auto 3.91-4.10 Doug I believe the 1st gear is 2.47 or similar. I don’t know what clutch to run yet. That will be one of my next questions.
[Re: viperblue72]
#2872445
01/11/21 10:16 AM
01/11/21 10:16 AM
Posts: 14,513 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
according to Porter the 270s make identical power to a cnc 295. That really doesn’t sound like something I would say(not in that way at least).
[Re: Dragula]
#2872485
01/11/21 11:58 AM
01/11/21 11:58 AM
Posts: 2,871 Pattison Texas
CSK
Pattison Texas
Mine is an auto 512 street car, BUT I had 3.54's for a long time & the car ran ok, 4100lb 11.04 @ 123, then went with Stack EFI & still sorting it out,,, fuel delivery problems, that said I went 4.10 & it made it VERY happy just cruising the streets, the 410 is MUCH better for drivability , I have Caltracs, split monos, & sliders , & had MT Radials 325-50-15 R, now I have Hoosiers Radials, with a stick shift I would say go Bias tires ,, I forgot to mention I do have an Overdrive A518
