511” stroker! Rear suspension&gear selection. #2872306
01/10/21 10:36 PM
01/10/21 10:36 PM
junction city oregon
V
viperblue72 Offline OP
V
I am almost finished with my 511” stroker and need to start thinking about the back end of the car.
It’s street strip and I know I’ll get a few different opinions on this. Combo is
511
11.6 comp.
TF 270 heads
Indy sp ported 1050/4150
2 to 2 1/8 header
265/268 .660 on 108 solid roller.
4 speed
It’s a Cuda. I plan a 1” spring relocate and a 9”. I want a 29.5 or 30” tire.
I don’t know what leaf springs and cal trac? My thoughts are a 3.73/3.91/4.10
Gear. I’m thinking it should trap around 130?!
What would you go with for suspension and gear?
Re: 511” stroker! Rear suspension&gear selection. [Re: viperblue72] #2872316
01/10/21 10:51 PM
01/10/21 10:51 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
Calvert split monos and Cal-tracs work really well. Buy the best double adjustable shocks you can afford, but the Calvert 9 positions will work fine to begin with.
You don't need a lot of gear with a stroker. I would do the 3.73's.
'63 Dodge 330
11.19 @ 121 mph
Re: 511” stroker! Rear suspension&gear selection. [Re: GY3] #2872327
01/10/21 11:22 PM
01/10/21 11:22 PM
V
V
My only worry about the 3.73 is that it’s harder to launch with taller gears. Although I’m switching from small block to big block so it may be different.
Re: 511” stroker! Rear suspension&gear selection. [Re: viperblue72] #2872358
01/11/21 01:06 AM
01/11/21 01:06 AM
I had a Mopar brand 2.77 low gear set installed in my old pump gas Duster, that worked well with 3.73,3.91, 4.10 and 4.30 running 315x60x15 M/T Et Street Radials and the same size ET Street bias ply tires with that 400 stroker motor with both the 4.25 stroke crank and the longer 4.300 stroke crank later up
That car ran 127.+ MPH with the Eddy RPM CNC heads and pickup to 134.+ MPH with the M.W. size Indy SR with a Indy 400-3 intake and several different 1050 CFM Holley Dominator carbs corked up with the air cleaner on using 92 octane OR pump swill from Bend shruggy
I haven't used the TF270 heads yet and I don't know how they compare to the Indy SR M.W. heads non ported work
The 4.250 stroke will move the mass a lot easier than the SB motor will with a 4.00 stroke in a SB 340 or 360 motor twocents
Good luck on your new build thumbs
Re: 511” stroker! Rear suspension&gear selection. [Re: Cab_Burge] #2872362
01/11/21 01:37 AM
01/11/21 01:37 AM
aotearoa
rebel Offline
rebel  Offline
aotearoa
I'm running a 512 in my 'cuda. I'm restricting power as I built the engine combo for our local track series where streetcars are limited to 11.00et's.but on a prepped track it'll go 10.5's. I have 325x50 ET Street R's on a 8 3/4 4.3 geared Detroit locker with old school SS springs & old Comp Eng 3 way adj shocks.. It puts 645 HP to the rear wheels, runs 1.5 60 fts & usually tops out at 125 mph..
Re: 511” stroker! Rear suspension&gear selection. [Re: Cab_Burge] #2872364
01/11/21 02:05 AM
01/11/21 02:05 AM
V
V
Cab, according to Porter the 270s make identical power to a cnc 295.
I had 3:55 behind the small block and I had to slip the clutch a lot to get out there without falling on its face.
Switched to 4:30 and it was much easier. Sounds like I’ll be fine with whatever I choose. I won’t be going for ultimate ETs anyways.
Re: 511” stroker! Rear suspension&gear selection. [Re: rebel] #2872365
01/11/21 02:07 AM
01/11/21 02:07 AM
V
V
That’s impressive power. What’s the combo? Is this a stick car? Also does it too out due to being out of RPM?
Re: 511” stroker! Rear suspension&gear selection. [Re: viperblue72] #2872366
01/11/21 02:23 AM
01/11/21 02:23 AM
I forgot to mention that Duster had ladder bars and coil over rear suspension with single adjustable Strange Engr. rear shocks that I change to double adjustable later, which where well worth swapping to up
I also had two different converters, a 10 Inch Contintental at first until it broke and then switch to a older type 727 T/A 8 inch SS/HA converter which was a ton better than the larger 10 inch up Faster and quicker and easier to drive at the track and on the street boogie
Re: 511” stroker! Rear suspension&gear selection. [Re: Cab_Burge] #2872369
01/11/21 02:45 AM
01/11/21 02:45 AM
V
V
Cab I do remember your old duster pretty well. I loved that car. Do you still have the b5 Cuda?
Re: 511” stroker! Rear suspension&gear selection. [Re: GY3] #2872371
01/11/21 02:56 AM
01/11/21 02:56 AM
V
V
Do you remember the spring length to use with offset shackles?
Re: 511” stroker! Rear suspension&gear selection. [Re: viperblue72] #2872372
01/11/21 02:59 AM
01/11/21 02:59 AM
AndyF Offline
AndyF  Offline
511
11.6 comp.
TF 270 heads
2 to 2 1/8 header
4 speed
Do you have the rear yet? If not you might be interested in the S60 that I'm pulling out of my Duster. I'm going to sell the S60 plus the wheels and tires. It might slide right under your car. It has 4.10 gears and a Detroit Locker along with disc brakes.
Re: 511” stroker! Rear suspension&gear selection. [Re: viperblue72] #2872376
01/11/21 03:50 AM
01/11/21 03:50 AM
Yes, I still want to sell it also so I can finish the new car, 1965 Dart back half car luck
Re: 511” stroker! Rear suspension&gear selection. [Re: AndyF] #2872395
01/11/21 05:19 AM
01/11/21 05:19 AM
V
V
511
11.6 comp.
TF 270 heads
2 to 2 1/8 header
4 speed
AndyF, ideally I need a b-body width 60”, but I could go as narrow as 58” and use a 15x8 with 3.5bs. Let me know I would absolutely be interested. And I’m not too far from you.
Re: 511” stroker! Rear suspension&gear selection. [Re: viperblue72] #2872396
01/11/21 05:43 AM
01/11/21 05:43 AM
aotearoa
rebel Offline
rebel  Offline
aotearoa
No, car is an auto with a loose 8" converter. Its a 400/512 stroker, Stage 6 MW heads with an 850 QF carb on a Super Victor manifold, runs on Pump Gas.
Re: 511” stroker! Rear suspension&gear selection. [Re: rebel] #2872412
01/11/21 09:11 AM
01/11/21 09:11 AM
MI, usa
dvw Online content
dvw  Online Content
MI, usa
I'm assuming 2.66 1st gear 833. At least the 4.10 probably could run a 4.56. If street driven Cal Tracks. Good shocks, bias slicks. The clutch better have some slip. If not the 833 may not have a long life span for track use. If it was an auto 3.91-4.10
Doug
Re: 511” stroker! Rear suspension&gear selection. [Re: viperblue72] #2872413
01/11/21 09:13 AM
01/11/21 09:13 AM
Wichita
GY3 Offline
GY3  Offline
Wichita
I use 20" front segment springs but keep in mind mine is a '63 B-body and, on those cars the spring length is the same as an A-body. Not going to be the same as yours.
Call Calvert Racing and they can walk you through the proper selection for your car.
'63 Dodge 330
11.19 @ 121 mph
Re: 511” stroker! Rear suspension&gear selection. [Re: dvw] #2872439
01/11/21 09:55 AM
01/11/21 09:55 AM
V
V
Doug
I believe the 1st gear is 2.47 or similar. I don’t know what clutch to run yet. That will be one of my next questions.
Re: 511” stroker! Rear suspension&gear selection. [Re: viperblue72] #2872445
01/11/21 10:16 AM
01/11/21 10:16 AM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
Quote
That really doesn’t sound like something I would say(not in that way at least).
Re: 511” stroker! Rear suspension&gear selection. [Re: viperblue72] #2872446
01/11/21 10:19 AM
01/11/21 10:19 AM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
Our pump gas 512/400 made 770hp...It was a beast....I like the Indy EZ1 325's for this combo....Gearing & tires should be set to hit the traps at 6500-6600max...Love the 71 Cuda posted above by the way!
Re: 511” stroker! Rear suspension&gear selection. [Re: Dragula] #2872485
01/11/21 11:58 AM
01/11/21 11:58 AM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
Mine is an auto 512 street car, BUT I had 3.54's for a long time & the car ran ok, 4100lb 11.04 @ 123, then went with Stack EFI & still sorting it out,,, fuel delivery problems, that said I went 4.10 & it made it VERY happy just cruising the streets, the 410 is MUCH better for drivability , I have Caltracs, split monos, & sliders , & had MT Radials 325-50-15 R, now I have Hoosiers Radials, with a stick shift I would say go Bias tires ,, I forgot to mention I do have an Overdrive A518
