Re: Removal of Thrust Buttons in 8.75 SG ??
[Re: Chi_Town_Runner]
#287223
04/14/09 02:02 PM
04/14/09 02:02 PM
Posts: 1,647 IL
71383beep
IL
How about that. I didn't think the button was a problem becasue I was already using the SG in a 741 case w/ 3.91 gears and stock axles w/ green bearings originally. Over the winter i discovered that my vibration problem was mostly due to the poor build on the 3rd member so I rebuilt a spare 489 chunk with the SG and 3.73 gears. It turns out is that my installation problem was due to me not having the side gears lined up right when rebuilding the SG. I tell ya though turning that half in axle to get it lined up was no picinic. I was just about to give up and pull the whole thing apart when I gave her one good last try. At most i could turn the axle about 1/16 of a turn and I ended up turnit a full 1/3 to finally get it lined up. At least now you know if you have the same issue. If one axle doesn't go all of the way in don't panic just get the other side all put together, put the wheel on, set her down and block the wheel and get ready to sweat! ![](/ubbthreads/images/graemlins/wrench.gif)
'73 GK6 Challenger Rallye - 340 4-Speed
[Re: 71383beep]
#287224
04/14/09 02:59 PM
04/14/09 02:59 PM
Posts: 75,125 A Banana Republic near you.
JohnRR
How about that.
i took 2 old axles and cut the ends of them off to make a holer and alignment shaft for reaseemebly , it's still takes a little to get them straight as I have had the stub get stuck in the unit from misalignment . I have a couple to do for myself for 2 different chucks of my own and I think I'm going to buy 1 piece side gears .
[Re: DoctorDiff]
#287227
04/14/09 04:44 PM
04/14/09 04:44 PM
Posts: 3,335 MARYLAND
69Cuda340S
MARYLAND
The side gear and hub splines must be aligned on all factory equipped 8 3/4" sure-grips, except for the late '68 model power-locks.
Thanks Cass. Maybe mine is a late '68 Power Lok because when I look in the sides everything looks like its lined up. But I'll make sure the axles go in easily before I install it just to be sure.
[Re: 69Cuda340S]
#287231
04/15/09 11:39 AM
04/15/09 11:39 AM
JohnRR
Mine has a one piece side gear. Guy I bought it from has been sitting on it for over 20 years. Says it came out of a late '60s C-body. Sounds like I don't need to worry about spline alignment.
Interesting , I have not found a 1 piece side gear in an original spicer power lock
[Re: JohnRR]
#287234
04/15/09 06:02 PM
04/15/09 06:02 PM
Posts: 25,200 Upper Midwest
MoparforLife
Upper Midwest
![](/ubbthreads/images/graemlins/iagree.gif)
