Re: Removal of Thrust Buttons in 8.75 SG ?? [Re: Chi_Town_Runner] #287223
04/14/09 02:02 PM
04/14/09 02:02 PM
IL
71383beep Offline
71383beep  Offline
IL
How about that.
I didn't think the button was a problem becasue I was already using the SG in a 741 case w/ 3.91 gears and stock axles w/ green bearings originally.
Over the winter i discovered that my vibration problem was mostly due to the poor build on the 3rd member so I rebuilt a spare 489 chunk with the SG and 3.73 gears.
It turns out is that my installation problem was due to me not having the side gears lined up right when rebuilding the SG.
I tell ya though turning that half in axle to get it lined up was no picinic. I was just about to give up and pull the whole thing apart when I gave her one good last try. At most i could turn the axle about 1/16 of a turn and I ended up turnit a full 1/3 to finally get it lined up.
At least now you know if you have the same issue. If one axle doesn't go all of the way in don't panic just get the other side all put together, put the wheel on, set her down and block the wheel and get ready to sweat!
'73 GK6 Challenger Rallye - 340 4-Speed
Re: Removal of Thrust Buttons in 8.75 SG ?? [Re: 71383beep] #287224
04/14/09 02:59 PM
04/14/09 02:59 PM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
How about that.
i took 2 old axles and cut the ends of them off to make a holer and alignment shaft for reaseemebly , it's still takes a little to get them straight as I have had the stub get stuck in the unit from misalignment . I have a couple to do for myself for 2 different chucks of my own and I think I'm going to buy 1 piece side gears .
Re: Removal of Thrust Buttons in 8.75 SG ?? [Re: JohnRR] #287225
04/14/09 04:19 PM
04/14/09 04:19 PM
MARYLAND
69Cuda340S Offline
69Cuda340S  Offline
MARYLAND
Is this sure grip alignment issue with the Power Lok clutch sure grips? I saw a note in the '68 FSM about Power Lok side gear alignment but it seems like the side gear is held in place and doesn't need to be aligned?? I know with the cone sure grips the side gear and cone splines must be aligned but I don't see any alignment issues with the Power Lok sure grips.
Re: Removal of Thrust Buttons in 8.75 SG ?? [Re: 69Cuda340S] #287226
04/14/09 04:37 PM
04/14/09 04:37 PM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
The side gear and hub splines must be aligned on all factory equipped 8 3/4" sure-grips, except for the late '68 model power-locks.
Re: Removal of Thrust Buttons in 8.75 SG ?? [Re: DoctorDiff] #287227
04/14/09 04:44 PM
04/14/09 04:44 PM
MARYLAND
69Cuda340S Offline
69Cuda340S  Offline
MARYLAND
Thanks Cass. Maybe mine is a late '68 Power Lok because when I look in the sides everything looks like its lined up. But I'll make sure the axles go in easily before I install it just to be sure.
Re: Removal of Thrust Buttons in 8.75 SG ?? [Re: 69Cuda340S] #287228
04/14/09 04:48 PM
04/14/09 04:48 PM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
Repro power-locks also use the redesigned (1 piece) side gears.
Re: Removal of Thrust Buttons in 8.75 SG ?? [Re: DoctorDiff] #287229
04/14/09 05:16 PM
04/14/09 05:16 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Just Because..Two piece gear...
Re: Removal of Thrust Buttons in 8.75 SG ?? [Re: 1_WILD_RT] #287230
04/15/09 10:33 AM
04/15/09 10:33 AM
MARYLAND
69Cuda340S Offline
69Cuda340S  Offline
MARYLAND
Mine has a one piece side gear. Guy I bought it from has been sitting on it for over 20 years. Says it came out of a late '60s C-body. Sounds like I don't need to worry about spline alignment.
Re: Removal of Thrust Buttons in 8.75 SG ?? [Re: 69Cuda340S] #287231
04/15/09 11:39 AM
04/15/09 11:39 AM
JohnRR Offline
JohnRR  Offline
Interesting , I have not found a 1 piece side gear in an original spicer power lock
Re: Removal of Thrust Buttons in 8.75 SG ?? [Re: JohnRR] #287232
04/15/09 03:40 PM
04/15/09 03:40 PM
Wheatfield, NY
Cuda340 Offline
Cuda340  Offline
Wheatfield, NY
Like Cass said in 1968 they finally smartened up and made the two piece side gears one piece. I know b/c I had one that the spiders and side gears were chewed up. When I bought the rebuild kit they were the one piece ones as well. But if you have the two piece and the splines are not aligned, take the axle shafts loosen the bolts on the carrier and turn until they (both axles) drop in fully and retorque the carrier bolts.
Re: Removal of Thrust Buttons in 8.75 SG ?? [Re: Cuda340] #287233
04/15/09 05:30 PM
04/15/09 05:30 PM
IL
71383beep Offline
71383beep  Offline
IL
To clarify you are refering to assembling the SG assembly right? Not the whole assembled 3rd member...Once its on the car I can't imagine doing anything other than what I did to get them to line up.
I remember the 68 FSM had a detailed description of insertng the axles when assembling the SG case halves and tightening. Now it all makes sense...
Re: Removal of Thrust Buttons in 8.75 SG ?? [Re: JohnRR] #287234
04/15/09 06:02 PM
04/15/09 06:02 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
Re: Removal of Thrust Buttons in 8.75 SG ?? [Re: MoparforLife] #287235
04/15/09 07:11 PM
04/15/09 07:11 PM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
Original units with 1 piece side gears are rare. They were only used for the second half of the 1968 model year.
I just sold a nice original 2.76/7290/742 case equipped with 1 piece side gears at MATS.
Re: Removal of Thrust Buttons in 8.75 SG ?? [Re: DoctorDiff] #287236
04/15/09 07:20 PM
04/15/09 07:20 PM
JohnRR Offline
JohnRR  Offline
learned something new , but I have to say that all the power locks i have are of 66 vintage so that;s why I haven't stumbled on one yet .
Re: Removal of Thrust Buttons in 8.75 SG ?? [Re: JohnRR] #287237
04/16/09 01:58 PM
04/16/09 01:58 PM
MARYLAND
69Cuda340S Offline
69Cuda340S  Offline
MARYLAND
So the one I have must be a late '68 because it is definitely an old original one and it definitely has one piece side gears. So no alignment needed for mine like I had originally thought.
