Re: 92 Ram Van
[Re: cudaman1969]
#2871818
01/09/21 07:08 PM
01/09/21 07:08 PM
Posts: 10,228 Colleyville
3hundred
Colleyville
Start with the fuel pump relay. We had a fuel pump failure @ 200,000 miles, started running lean, after ~ 200 miles it was barely running. If you need a fuel pump, I'd pick something besides Airtex if possible. 2¢
'68 Fury Convertible '69 300 Convertible '15 Durango 5.7 Hemi '16 300 S Hemi
Re: 92 Ram Van
[Re: stumpy]
#2871886
01/09/21 10:17 PM
01/09/21 10:17 PM
Posts: 856 Southeast Pa.
SALEM1912
Southeast Pa.
Try banging on the bottom of the fuel tank. Sometimes a fuel pump will lockup. I also believe there is a fuel pump relay somewhere in the system. Might want to look it up online. X2 on banging the tank while cranking. Don't be afraid to wack it.
Re: 92 Ram Van
[Re: cudaman1969]
#2881412
01/28/21 05:23 PM
01/28/21 05:23 PM
Posts: 2,415 Connecticut
Ron_M
Connecticut
Every so often my 93 Dakota decides to "play dead". Checked the obvious: wire harness, battery voltage, sensors, relays, coil. Believe it or not, I'll swap the ECM to a spare I bought from a member here and it will fire right up. Then I'll swap back to the first ECM and it'll be fine until it happens again and the cycle repeats itself which is trending to once a year.
Common sense is a flower that does not grow in everybody's garden
Re: 92 Ram Van
[Re: cudaman1969]
#2881514
01/28/21 11:58 PM
01/28/21 11:58 PM
Posts: 10,546 Freeport IL USA
poorboy
Freeport IL USA
I guess the fact that the 92 is 29 years old and the 01 is 20 years old, its still Dodge's fault the stuff no longer works like new?
They just don't make stuff like they used to.
Back in the 60s and 70s, very few 20 year old vehicles, and even fewer 30 year old vehicles were still daily drivers, most would have already been dead. Back then, few vehicles made it to 100,000 miles, I suspect both trucks mentioned here have well over 100,000 mile on them as well.
The reliability of these newer vehicles has screwed up our perspective on how things work. Gene
Re: 92 Ram Van
[Re: poorboy]
#2881542
01/29/21 01:46 AM
01/29/21 01:46 AM
Posts: 8,241 fredericksburg,va
cudaman1969
fredericksburg,va
And the 01 has had EVERYTHING replaced except the heads- block over a 3 year period. I’m so deep in it now I don’t know which way to go. Parts today are crap compared to 30-40 years ago. I won’t even go into how many things I’ve fixed-replaced and will have to fix-replace in the future on my 06 3500 4x4 diesel pickup. Be nice for one of them to go 6 months without working on either. I have a 15 SRT that’s been in the shop four times and only 20 thousand miles on it. Warranty runs out on the first and scared shitless with what breaks next. I love Mopar but they’re junk today. I’ve had many old mopars and drove them till the wheels fell off, so been there done that. Oh and if you’re 30-35 20 years is a long time but at 71, 20 years is a blip
Re: 92 Ram Van
[Re: cudaman1969]
#2881736
01/29/21 02:25 PM
01/29/21 02:25 PM
Ron_M
Connecticut
I sympathize. My Dad's 01 Dakota was bought new. Very little left of the original truck! I won't even start with the adventures that I have had with my 2000 LHS or the 2002 Durango that STB at a young age. IMHO ALL the DAIMLER era Mopars were cursed by the boys in Stuttgart!
Re: 92 Ram Van
[Re: cudaman1969]
#2882037
01/30/21 01:54 PM
01/30/21 01:54 PM
Posts: 1,061 Atlanta, GA
mgoblue9798
Atlanta, GA
And the 01 has had EVERYTHING replaced except the heads- block over a 3 year period. I’m so deep in it now I don’t know which way to go. Parts today are crap compared to 30-40 years ago. I won’t even go into how many things I’ve fixed-replaced and will have to fix-replace in the future on my 06 3500 4x4 diesel pickup. Be nice for one of them to go 6 months without working on either. I have a 15 SRT that’s been in the shop four times and only 20 thousand miles on it. Warranty runs out on the first and scared shitless with what breaks next. I love Mopar but they’re junk today. I’ve had many old mopars and drove them till the wheels fell off, so been there done that. Oh and if you’re 30-35 20 years is a long time but at 71, 20 years is a blip Cudaman, I like you and many others have found replacement parts are now crap for the most part. I have gone back to having starters and alternators fixed locally rather than replaced. I also will not buy any part made in China if there is any choice. Lastly I surf ebay all the time for OEM parts for my 2002 Ram van, and buy them up when they don't break the bank- even before they are needed. If I can't find OEM parts, I try to buy from the original OEM supplier at least. Just a couple tips trying to help out sir.
Re: 92 Ram Van
[Re: cudaman1969]
#2882183
01/30/21 09:44 PM
01/30/21 09:44 PM
poorboy
Freeport IL USA
And the 01 has had EVERYTHING replaced except the heads- block over a 3 year period. I’m so deep in it now I don’t know which way to go. Parts today are crap compared to 30-40 years ago. I won’t even go into how many things I’ve fixed-replaced and will have to fix-replace in the future on my 06 3500 4x4 diesel pickup. Be nice for one of them to go 6 months without working on either. I have a 15 SRT that’s been in the shop four times and only 20 thousand miles on it. Warranty runs out on the first and scared shitless with what breaks next. I love Mopar but they’re junk today. I’ve had many old mopars and drove them till the wheels fell off, so been there done that. Oh and if you’re 30-35 20 years is a long time but at 71, 20 years is a blip I fully understand your position. The parts available today are no where near as good as they were 10 years ago. The last "new" car I bought was a 2004, and as far as I'm concerned, it will be the last "new" car I buy. From here on, when I absolutely need a different car, I will buy the used car that is in the best condition I can find. I can put a couple of months worth of car payments (I can't imagine what the monthly payment on a 70K truck looks like) in car repair on the 04 I already own, every 6 months and still be way ahead of the game, and I know what I have. Oh, and for the record, I was born in 56, 30 years old was more then a 1/2 of life ago. The 20 years I was referring to was in car life, and that still stands true today, like it did back then. Modern vehicles are designed to last to the end of the payment book, or to the end of the warranty, whichever comes first. If they make it to the end of the payment book, the odds are pretty high, the manufacturer got a replacement sale. The problem with Mopar is it has changed hands so many times in the last 20 years, concerns about returning sales have gone out the window. If they don't expect to own the company in 10 years, why would they care if anyone returns to buy another car or truck? Once it gets through the warranty time, their burden ends.
Re: 92 Ram Van
[Re: poorboy]
#2882190
01/30/21 10:06 PM
01/30/21 10:06 PM
cudaman1969
fredericksburg,va
Agree on all you said. On the warranty thing I’m gonna put $200 in my other checking each month, end of year I’ll have $2400. Keep doing the same each year. After two years if lucky that’ll but a lot of parts, tires and upkeep. If you paid the warranty people that money and not need them, that money is theirs.! That $200 comes from the SS check anyway (1949 here)
Re: 92 Ram Van
[Re: cudaman1969]
#2882579
01/31/21 08:47 PM
01/31/21 08:47 PM
poorboy
Freeport IL USA
That is a solid plan. When we made that last payment on our 04, all those years ago, I told my wife to keep track of how much we were saving by not having a car payment. She didn't really understand, but when we did the timing belt a couple years later, she was crying about the bill. I asked her how much would she had spent doing car payments for those two years, then suddenly, the light came on.
I think she has actually been putting money aside for car repair, along with all those other things we need to get every so often.
We are both retired. Everything is paid for, all we need is to cover utility bills, food, and upkeep on the stuff we have. We each have an allowance to get stuff we want. I'm building a 49 Dodge pickup, and we just finished a kitchen update she has wanted for years, both paid for with money already saved for those purposes. Being debt free is a great place to be. Gene
