Re: shorter timing chain
[Re: Stanton]
#2871373
01/08/21 09:40 PM
01/08/21 09:40 PM
Posts: 8,356 fredericksburg,va
cudaman1969
fredericksburg,va
Rollmaster - and they tell you how to determine which size you need. Also, FWIW, the chain length does not change - they actually make the sprocket a tad larger. That way, you can easily swap the chain should it ever need replacement That is good to know, I have 2 Hemi blocks that’s gonna need a line hone.
[Re: Stanton]
#2871713
01/09/21 03:45 PM
01/09/21 03:45 PM
Posts: 1,899 MYRTLE BEACH SOUTH CAROLINA
ek3
Rollmaster - and they tell you how to determine which size you need. Also, FWIW, the chain length does not change - they actually make the sprocket a tad larger. That way, you can easily swap the chain should it ever need replacement i always thought it was the chain that was - .005 " i think they come in .002 -.0010 " shorter chains.. we would always measure and then order the correct chain ..?
[Re: ek3]
#2871769
01/09/21 05:10 PM
01/09/21 05:10 PM
Posts: 8,914 Ontario, Canada
Stanton
Don't question me!
Don't question me!
Ontario, Canada
i always thought it was the chain that was - .005 " i think they come in .002 -.0010 " shorter chains.. we would always measure and then order the correct chain ..? Ok, then think about it ... you have what, maybe 50 links in the chain and you want to make that chain .005" shorter. So each link has to be made roughly .0002" shorter. Or you can just make the sprocket bigger !!
[Re: Stanton]
#2871799
01/09/21 06:23 PM
01/09/21 06:23 PM
Posts: 1,863 Sault Ste. Marie, Ontario, Can...
moparmike1
i always thought it was the chain that was - .005 " i think they come in .002 -.0010 " shorter chains.. we would always measure and then order the correct chain ..? Ok, then think about it ... you have what, maybe 50 links in the chain and you want to make that chain .005" shorter. So each link has to be made roughly .0002" shorter. Or you can just make the sprocket bigger !! Or, maybe, the master link is manufactured in standard length and reduced lengths? Mike.
[Re: elmor353]
#2871829
01/09/21 07:33 PM
01/09/21 07:33 PM
Posts: 21,847 Kirkland, Washington
Pacnorthcuda
I read that ad and it doesn't say what they do to shorten it. I'm leaning towards the master link being different sizes, because it makes no sense to make the chain itself smaller. But wouldn’t that result in erratic cam timing?
[Re: Stanton]
#2871888
01/09/21 10:19 PM
01/09/21 10:19 PM
ek3
i always thought it was the chain that was - .005 " i think they come in .002 -.0010 " shorter chains.. we would always measure and then order the correct chain ..? Ok, then think about it ... you have what, maybe 50 links in the chain and you want to make that chain .005" shorter. So each link has to be made roughly .0002" shorter. Or you can just make the sprocket bigger !! ---gotcha on the gears! ---advertisements show shorter chains .. i know, so much for repeating bad info.. the op would understand it ... i am curious in your example of if the chain needs to be .005" shorter though. its the [ CENTER ] distance that is .005" shorter. the chain length should be completely different as it is on 2 different radius x lengths .. rite?
[Re: ek3]
#2871896
01/09/21 10:35 PM
01/09/21 10:35 PM
Posts: 18,427 UPPER MICHIGAN, MARQUETTE COUN...
NITROUSN
i always thought it was the chain that was - .005 " i think they come in .002 -.0010 " shorter chains.. we would always measure and then order the correct chain ..? Ok, then think about it ... you have what, maybe 50 links in the chain and you want to make that chain .005" shorter. So each link has to be made roughly .0002" shorter. Or you can just make the sprocket bigger !! ---gotcha on the gears! ---advertisements show shorter chains .. i know, so much for repeating bad info.. the op would understand it ... i am curious about the chain needs to be .005" shorter though. its the [ CENTER ] distance that is .005" shorter. the chain length should be completely different as it is on 2 different radius x lengths .. rite? No. Read what is posted. Nothing to to do with the chain. Gear is compensated to the height change the pitch stays the same. Now you should of before and surely need to now DEGREE THE CAM.The wheel has already been invented.
[Re: NITROUSN]
#2871910
01/09/21 11:03 PM
01/09/21 11:03 PM
ek3
i always thought it was the chain that was - .005 " i think they come in .002 -.0010 " shorter chains.. we would always measure and then order the correct chain ..? Ok, then think about it ... you have what, maybe 50 links in the chain and you want to make that chain .005" shorter. So each link has to be made roughly .0002" shorter. Or you can just make the sprocket bigger !! ---gotcha on the gears! ---advertisements show shorter chains .. i know, so much for repeating bad info.. the op would understand it ... i am curious about the chain needs to be .005" shorter though. its the [ CENTER ] distance that is .005" shorter. the chain length should be completely different as it is on 2 different radius x lengths .. rite? No. Read what is posted. Nothing to to do with the chain. Gear is compensated to the height change the pitch stays the same. Now you should of before and surely need to now DEGREE THE CAM.The wheel has already been invented. no? was referencing the math for a shorter chain.................read my post. i said i got the gear deal.... was talking about the math for a shorter chain by .005" --by 50 links.. .005 is c-c measurement.. chain length is around it...thats all
