shorter timing chain #2871174
01/08/21 03:51 PM
01/08/21 03:51 PM
ontario canada
sonny54 Offline OP
sonny54  Offline OP
ontario canada
I believe that I have a line bored block causing the problem of a too long timing chain. I know they make chains for this application .Can anybody tell me a supplier and even a part # If possible? This would be for a 1969 340 with a double roller. This site is fantastic for info. and help. Thanking you all in advance.
Re: shorter timing chain [Re: sonny54] #2871283
01/08/21 07:04 PM
01/08/21 07:04 PM
Colorado
spk2go Offline
spk2go  Offline
Colorado
Cloyes makes a 5 and 10 thousands Gear 9-3603X9-5 Gear 9-3603X9-10
Re: shorter timing chain [Re: sonny54] #2871312
01/08/21 07:41 PM
01/08/21 07:41 PM
MYRTLE BEACH SOUTH CAROLINA
E
ek3 Offline
ek3  Offline
E
saw your other post... tried to say this.. correct part iagree
Re: shorter timing chain [Re: ek3] #2871320
01/08/21 07:56 PM
01/08/21 07:56 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Rollmaster - and they tell you how to determine which size you need. Also, FWIW, the chain length does not change - they actually make the sprocket a tad larger. That way, you can easily swap the chain should it ever need replacement
Re: shorter timing chain [Re: Stanton] #2871373
01/08/21 09:40 PM
01/08/21 09:40 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
That is good to know, I have 2 Hemi blocks that’s gonna need a line hone.
Re: shorter timing chain [Re: Stanton] #2871713
01/09/21 03:45 PM
01/09/21 03:45 PM
E
ek3 Offline
ek3  Offline
E
i always thought it was the chain that was - .005 " i think they come in .002 -.0010 " shorter chains.. we would always measure and then order the correct chain ..?
Re: shorter timing chain [Re: ek3] #2871769
01/09/21 05:10 PM
01/09/21 05:10 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Quote
Ok, then think about it ... you have what, maybe 50 links in the chain and you want to make that chain .005" shorter. So each link has to be made roughly .0002" shorter. Or you can just make the sprocket bigger !!
Re: shorter timing chain [Re: Stanton] #2871775
01/09/21 05:28 PM
01/09/21 05:28 PM
E
ek3 Offline
ek3  Offline
E
Quote
COMES WITH .005 SHORTER CHAIN --- https://billmitchellproducts.com/pr...sprocket-005-chain-click-here-more-info/
Re: shorter timing chain [Re: Stanton] #2871799
01/09/21 06:23 PM
01/09/21 06:23 PM
Sault Ste. Marie, Ontario, Can...
moparmike1 Offline
moparmike1  Offline
Quote
Or, maybe, the master link is manufactured in standard length and reduced lengths?
Mike.
Re: shorter timing chain [Re: moparmike1] #2871814
01/09/21 06:57 PM
01/09/21 06:57 PM
Alberta
440_Offroader Offline
Alberta
Wouldn't a different length master link ride on the gear incorrectly? I would think all the chain links would have to match the tooth pitch on the gears.
Re: shorter timing chain [Re: ek3] #2871816
01/09/21 07:01 PM
01/09/21 07:01 PM
Keizer, Oregon U.S.A.
E
elmor353 Offline
elmor353  Offline
E
I read that ad and it doesn't say what they do to shorten it. I'm leaning towards the master link being different sizes, because it makes no sense to make the chain itself smaller.
Re: shorter timing chain [Re: elmor353] #2871829
01/09/21 07:33 PM
01/09/21 07:33 PM
Kirkland, Washington
Pacnorthcuda Offline
But wouldn’t that result in erratic cam timing?
Re: shorter timing chain [Re: Pacnorthcuda] #2871854
01/09/21 08:59 PM
01/09/21 08:59 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Ok, enough of this BS ...
Straight from the Rollmaster tech page:
When you machine the engines main bearing tunnel the distance between the camshaft and the crankshafr can become closer causing a standard timing set to fit with slack in the chain. Rollmaster solves this problem by manufacturing sprockets slightly larger in thou increments. Yadda, yadda, yadda .
Re: shorter timing chain [Re: Stanton] #2871888
01/09/21 10:19 PM
01/09/21 10:19 PM
E
ek3 Offline
ek3  Offline
E
Quote
---gotcha on the gears! ---advertisements show shorter chains .. i know, so much for repeating bad info.. the op would understand it ... i am curious in your example of if the chain needs to be .005" shorter though. its the [ CENTER ] distance that is .005" shorter. the chain length should be completely different as it is on 2 different radius x lengths .. rite?
Re: shorter timing chain [Re: ek3] #2871896
01/09/21 10:35 PM
01/09/21 10:35 PM
N
NITROUSN Offline
NITROUSN  Offline
N
Quote
---gotcha on the gears! ---advertisements show shorter chains .. i know, so much for repeating bad info.. the op would understand it ... i am curious about the chain needs to be .005" shorter though. its the [ CENTER ] distance that is .005" shorter. the chain length should be completely different as it is on 2 different radius x lengths .. rite?
No. Read what is posted. Nothing to to do with the chain. Gear is compensated to the height change the pitch stays the same. Now you should of before and surely need to now DEGREE THE CAM.The wheel has already been invented.
Re: shorter timing chain [Re: NITROUSN] #2871905
01/09/21 10:54 PM
01/09/21 10:54 PM
Cloyes sells shorter chains, .005 and .010 according to Summits site for BB Mopar 3 bolt timing sets scope
Re: shorter timing chain [Re: NITROUSN] #2871910
01/09/21 11:03 PM
01/09/21 11:03 PM
E
ek3 Offline
ek3  Offline
E
Quote
no? was referencing the math for a shorter chain.................read my post. i said i got the gear deal.... was talking about the math for a shorter chain by .005" --by 50 links.. .005 is c-c measurement.. chain length is around it...thats all
