Setup for torqueflite safe neutral vb and air shifter?
#2870054
01/06/21 08:42 PM
01/06/21 08:42 PM
Posts: 10,021 Frostbitefalls MN (Rocky&Bullw...
gregsdart
I have the following componants. Dednbear command center. B&M ratchet shifter. CO2 air shifter. RPM switch that fires the air shifter. I. want to install a safe neutral valvebody by Transzact. With the current setup the airshifter is fired by an rpm switch in the digital 7 ignition. I need a safe way to interupt that rpm signal after the 2/3 shift or the shifter will go to safe neutral before the traps. For referance the safe neutral vb pattern is PR123N. I will have to check and see if i can set up a timed grounding circuit and connect the ground for the airshifter to it? At this time i only use one of two circuits from the command center.
Re: Setup for torqueflite safe neutral vb and air shifter?
[Re: gregsdart]
#2870081
01/06/21 09:17 PM
01/06/21 09:17 PM
Posts: 3,105 Michigan
A727Tflite
X
[Re: J_BODY]
#2870215
01/07/21 01:21 AM
01/07/21 01:21 AM
gregsdart
After rereading the dedenbear instructions it looks like i just need to change from the MSD7 rpm switch to the dedenbear RPM switch. If i read it correctly i can select 3 spd and set rpm for each shift, which would indicate it shouldn't shift a third time. Will call Dedenbear to confirm.
[Re: J_BODY]
#2870221
01/07/21 02:17 AM
01/07/21 02:17 AM
Posts: 209 Finland
Hessu
Finland
I have same set up. rpm switch control b&m sifter with air and safe neutral valve body. I just add one micro switch to eliminate automatic shift to safe neutral. I can teke pic of it if it help.
[Re: Hessu]
#2870250
01/07/21 08:40 AM
01/07/21 08:40 AM
Posts: 209 Finland
Hessu
Finland
[Re: Hessu]
#2870251
01/07/21 08:41 AM
01/07/21 08:41 AM
Posts: 209 Finland
Hessu
Finland
