Does indexing a rotor affect A/F ratio? #2868916
01/04/21 04:07 PM
01/04/21 04:07 PM
Mo.
racerx Offline OP
racerx  Offline OP
Mo.
I want to say yes.........but i will like your thoughts on this?
Re: Does indexing a rotor affect A/F ratio? [Re: racerx] #2868951
01/04/21 05:17 PM
01/04/21 05:17 PM
Central TEXAS!!!!
sr4440 Offline
sr4440  Offline
Central TEXAS!!!!
nope, once the fuel is mixed with the incoming air the A/F ratio is set. now you can get a different reading depending on where the O2 sensor is located and the timing of the spark, but the ratio hasn't changed.
Joe
Without Data, you’re just another guy with an opinion.
Re: Does indexing a rotor affect A/F ratio? [Re: sr4440] #2868978
01/04/21 06:20 PM
01/04/21 06:20 PM
deltona, fl.
mike laws Offline
mike laws  Offline
deltona, fl.
Might want to give this one a little thought.
Re: Does indexing a rotor affect A/F ratio? [Re: mike laws] #2869050
01/04/21 07:37 PM
01/04/21 07:37 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Yep, exactly what I was thinking and I know for a fact phasing/timing can and does change afr's......
Re: Does indexing a rotor affect A/F ratio? [Re: racerx] #2869057
01/04/21 07:55 PM
01/04/21 07:55 PM
Any tuning done to the motor will have direct affect on how it runs so I'm sure a good O2 gauge should measure and display the changes twocents
My Innovate system did shruggy
Now if you mean your going to change the rotor phasing and not the ignition timing at all then maybe that won't affect the AFR readings confused
Re: Does indexing a rotor affect A/F ratio? [Re: Cab_Burge] #2869085
01/04/21 09:12 PM
01/04/21 09:12 PM
Milwaukee WI
TRENDZ Offline
TRENDZ  Offline
Milwaukee WI
Unless rotor phasing is so far out of whack that the spark jumps to the next post, no. It will have no effect. The rotor phasing and ignition timing are two separate things that are inter-related. The spark will occur at the same time in the cylinder regardless of phase. The exception to that is if phase is so far out that the spark doesn’t make it to the correct cylinder.
Re: Does indexing a rotor affect A/F ratio? [Re: racerx] #2869134
01/04/21 10:56 PM
01/04/21 10:56 PM
Aus
hysteric Offline
hysteric  Offline
Aus
What do you mean by "Affect"?
The AFR your carb meters is set and cant be affected by ignition as Its a mechanical device. But a change in ignition will affect combustion and that could change the "AFR" your O2 sensor is interpreting.
Re: Does indexing a rotor affect A/F ratio? [Re: mike laws] #2869158
01/04/21 11:53 PM
01/04/21 11:53 PM
AndyF Offline
AndyF  Offline
Mike, I don't recall ever seeing you on this board before. How is life after leaving Bo Laws?
I'm not sure on the OP question. I do know that changing timing will change the AFR. I suppose indexing the rotor could also make a change but I'd be surprised if it was significant. I'm not exactly sure why the AFR changes when timing changes. I suppose that if the combustion becomes more efficient it changes the signal on the booster.
With an EFI car when you change the timing the AFR stays the same. But, the fuel flow will change since the EFI system compensates for the change in AFR by adjusting the fuel flow. I've seen it work on the dyno but the percentage change is usually fairly small. Of course, the NASCAR boys would kill for a small percentage increase in BSFC.
Re: Does indexing a rotor affect A/F ratio? [Re: AndyF] #2869165
01/05/21 12:15 AM
01/05/21 12:15 AM
CT
GTX MATT Offline
GTX MATT  Offline
CT
The answer should be no theoretically, but the reality is that you may observe a small change in measured AFR if it changes timing (or combustion efficiency) by a significant amount. If you see a large change you probably had an issue or caused one.
Re: Does indexing a rotor affect A/F ratio? [Re: AndyF] #2869249
01/05/21 11:29 AM
01/05/21 11:29 AM
deltona, fl.
mike laws Offline
mike laws  Offline
deltona, fl.
Hi Andy. Life is busy, thanks for asking.
Re: Does indexing a rotor affect A/F ratio? [Re: mike laws] #2869278
01/05/21 01:18 PM
01/05/21 01:18 PM
AndyF Offline
AndyF  Offline
Glad to see you stopping by. I still remember that Dominator that you built for me so I could test 2 circuit vs. 3 circuit and race gas vs. Q16. That was a trick carb and it worked great. I think it was the last carb I owned since I switched to EFI shortly after that test. It took so much work to run that test with a carb that it wore me out! Once I switched the engine over to EFI I was able to switch fuels by just typing a few numbers!
Re: Does indexing a rotor affect A/F ratio? [Re: AndyF] #2869287
01/05/21 01:33 PM
01/05/21 01:33 PM
deltona, fl.
mike laws Offline
mike laws  Offline
deltona, fl.
I remember that carb as well. It was trick in it's day!
Re: Does indexing a rotor affect A/F ratio? [Re: racerx] #2869661
01/06/21 12:25 PM
01/06/21 12:25 PM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
The experts on here have answered this. I will add that my MSD Pro-billet dizzy was so far out of phase that the tip of my rotor melted off and flew out at the track one day. The top of the rotor was physically melted where the metal was. The heat generated by my high output coil jumping that gap was intense. I put an adjustable MSD rotor in there and found it was nearly at the midpoint between the two terminals.
Re: Does indexing a rotor affect A/F ratio? [Re: jbc426] #2869676
01/06/21 01:02 PM
01/06/21 01:02 PM
AndyF Offline
AndyF  Offline
Yeah I found out about indexing the hard way back in the 90's when I was running a MP electronic distributor. It worked okay until the vacuum advance started to rotate things and then it would start shooting ducks. Took me a while to figure out the problem. I had to machine a new slot in the reluctor to fix it. I don't think Mopar Performance ever fixed the problem.
Re: Does indexing a rotor affect A/F ratio? [Re: AndyF] #2869685
01/06/21 01:12 PM
01/06/21 01:12 PM
There where two slots (BB-SB?) on the rotor shafts to align the pickup wheel, I found more than one of them aligned, assembled, on the wrong one work shruggy
I would remove the distributor cap and see if the pickup aligned with the star wheel on the rotor shaft with the rotor tip aligned with #1 plug wire terminal on the distributor shaft scope If not moving the star wheel to the other slot would usually fix it scope
Re: Does indexing a rotor affect A/F ratio? [Re: racerx] #2870017
01/06/21 07:14 PM
01/06/21 07:14 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
Could you be more clear in your question? Are you asking:
1) does indexing a rotor affect the reading generated by an exhaust O2 meter?
Or
2) does indexing a rotor actually affect the fuel to air ratio of the mixture entering the cylinder.
Re: Does indexing a rotor affect A/F ratio? [Re: BSB67] #2870130
01/06/21 10:02 PM
01/06/21 10:02 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
Or
THIS ^^^^^^^^
