The first blown pump gas KB street Hemi block I assembled and dyno tested years ago leak water into the motor due to the sleeves being a tad bit too high
![whiney whiney](/ubbthreads/images/graemlins/custom/whiney.gif)
, .005/.006 instead of .003 to .004 at room temps. It was a 4.375 bore with a Mopar brand 8 bolt 4.150 stroker crank.
Long story short I ended up working with SCE gaskets to get a custom set of their ICS Titan head soft copper head gaskets made to cure all the gasket sealing issues I had with that project
![scope scope](/ubbthreads/images/graemlins/custom/scope.gif)
I'm getting ready to start making a 4.500 bore new KB street wedge 572 C.I. B1 race motor for myself and I bought a set of the SCE Titan head gasket with the Teflon sealant rings around all the water passages ,
That type of gasket worked really well for me on the last KB aluminum block I built: up:
I've also use them on other cast iron blocks high compression builds and roots blower motor builds with really good success
![up up](/ubbthreads/images/graemlins/custom/thumbs_up.gif)
IHTHs
![luck luck](/ubbthreads/images/graemlins/custom/luck.gif)
