Back side of disc brake setup 70 cuda #2868266
01/02/21 09:37 PM
01/02/21 09:37 PM
poplar bluff mo.
toplescuda Offline OP
I Whine
I Whine
poplar bluff mo.
Anyone have any clear shots of the back side of the front disc brake setup. And also
If any special bolts needed?
Have the k frame. lower control arms. New bushings in them , disc brake spindle and shields
Would like to see what else need to put it togeather. Car has drum brakes on it now
1970 barracuda convert. 1 of 59
1970 pro street A.A.R. clone (panther pink)
1971 charger
2015 hellcat challenger. Redline red
2014 quad cab 4x4 ram 8 speed hemi
Re: Back side of disc brake setup 70 cuda [Re: toplescuda] #2868908
01/04/21 03:55 PM
01/04/21 03:55 PM
Wheatfield, NY
Cuda340 Offline
Cuda340  Offline
Wheatfield, NY
Are you trying to go entirely original? If so, the calipers would be the wide mouth kelsey hays, two piece rotors, which I may have a pair. I may have the caliper brackets as well.
Re: Back side of disc brake setup 70 cuda [Re: Cuda340] #2872320
01/10/21 11:03 PM
01/10/21 11:03 PM
poplar bluff mo.
I Whine
I Whine
poplar bluff mo.
I stole the front susp. Off a 72 ralley charger that had front sway barn and disc brakes years ago. Now cleaning parts up and trying get it ready to put under the 70 gran coupe
1971 charger
