383hp #286805
04/13/09 01:36 AM
04/13/09 01:36 AM
Spokane Wa
CrazyRocker70 Offline OP
Spokane Wa
gotta 71 383 hp motor, been sitting for 20 years, no idea what shape its in. did the 71's come with a forged crank? how stout is the bottom end? just looking to do a fairly mild build, daily driven street motor, hyd flat tappet cam.
the car came with headders, and has 3.55's out back and a bone stock 727.
anyone feel like sharing mild 383 builds?? any help would be great. thanks.
Re: 383hp [Re: CrazyRocker70] #286806
04/13/09 01:41 AM
04/13/09 01:41 AM
I think the 71 had a cast crank. It'd work for your intended app.
Re: 383hp [Re: CrazyRocker70] #286807
04/13/09 02:12 AM
04/13/09 02:12 AM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
Yes, forged crank. My only attempt at rebuilding my '71 383 had so/so results. My first mistake was using the replacement flat top pistons which did not have valve reliefs. Because the 383 (and 400) have a fairly large bore and short stroke it is very important to keep track of the chamber volume or the compression will drop quickly with any additional chamber volume/head gasket thickness/deck height. I think I may have only had a bit over 8:1 compression?
My second mistake was using a cam that was a total compromise. It was just a bit too big for my low compression, so I killed alot of low end torque, but the cam was a bit mild to make good top end power. The killer was the car had a stock torque converter. A higher stall converter would have helped cover up the lack of low end torque, but having higher compression ratio would also have helped. Anyhow, back to the pistons... Since they did not have valve notches I could not easely install a larger cam, or advance the cam I had. Anyhow, short story, I built the 451 stroked 400 and the 383 is still setting on an engine stand in the corner of the garage minus the ported 906 heads that I sold to a friend for his 440.
The KB #162 piston with a 0.040" head gasket and 84cc heads only get the compression ratio to about 8.5:1. The KB #400 domed (-6cc) pistons would make about 9.5:1 compression with the same 84cc heads and 0.040" head gasket.
Re: 383hp [Re: 451Mopar] #286808
04/13/09 02:41 AM
04/13/09 02:41 AM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
Budget?
stroke it! I've got what is basically a 440 stuffed into a 383 block, and made 505 hp, 535 tq on the engine dyno, with an otherwise, mild build.
10.5 compression
eddy heads
RPM intake
holly 750HP
comp xe275hl hydraulic flat tappet cam
torque curve was pretty much flat at 500 from 3000 rpm through 5800, with the peak of 535 at 3600.
if you have a good solid complete 383, the build could be done for $3500-$4000 plus machine costs...all depends on what you already have available, and what you can find by shopping around for good deals on used stuff
**Photobucket sucks**
Re: 383hp [Re: RapidRobert] #286809
04/13/09 09:27 AM
04/13/09 09:27 AM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
Only the 383 2 bbl engines in 71 had the cast crank , forged in the HP 383 .
Re: 383hp [Re: JohnRR] #286810
04/13/09 10:43 AM
04/13/09 10:43 AM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
I know i'm going to get flamed here, but if your just looking for a mild build i would get a set of 516 close chamber heads nice v/j open up the bowls and install 1.74 exhaust valves, get a set of flat tops and zero deck, this should put you right around 9.2 to 9.5cr, and a good .039 quench with the felpros to boot. then keep the cam in the 218 to 224 @.050 range. I know plenty of guys running 516 heads in the high 11's and 12's. so they will flow plenty for a mild 383.
Re: 383hp [Re: CrazyRocker70] #286811
04/13/09 10:48 AM
04/13/09 10:48 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
all 383's had a forged crank.
If the cylinder walls look good you might get away w/ cleaning the ridges, new rod bearings, new T-chain set and cam/lifters (488 summit is good and cheap) I'd also get a new oil pump, fuel pump and have the heads checked out real good. Probably will need a vavle job.
Re: 383hp [Re: Mr.Yuck] #286812
04/13/09 11:38 AM
04/13/09 11:38 AM
JohnRR Offline
JohnRR  Offline
EXCEPT for the 71 383-2bbl ...
Re: 383hp [Re: ademon] #286813
04/13/09 11:41 AM
04/13/09 11:41 AM
JohnRR Offline
JohnRR  Offline
Mike I would do basically the same thing , but I think the 71 383 HP had a lower compression rating ( closer to what it actually may be??) , piston is a little deeper in the hole and I think a composite felpro would make the quench distance larger than .039
Re: 383hp [Re: JohnRR] #286814
04/13/09 01:24 PM
04/13/09 01:24 PM
Harlan, Iowa
69CoronetRT Offline
69CoronetRT  Offline
Harlan, Iowa
John,
There is a note in the 70-71 parts book (page 9-1 note 2) stating a 383 2bbl could have either a cast or forged crank. It goes on to describe how to determine which crank came with the block. (Letter E on pad, balancer, etc)
Seeking:
1969 St. Louis plant VINs, SPD, and VONs.
Over 2,000 thanks to you!
Re: 383hp [Re: 69CoronetRT] #286815
04/13/09 01:38 PM
04/13/09 01:38 PM
JohnRR Offline
JohnRR  Offline
John,
Thanks Doug , my interest/knowledge in the 383 sort of stops at the end of the 69 model year
Re: 383hp [Re: ademon] #286816
04/13/09 01:49 PM
04/13/09 01:49 PM
IL
71383beep Offline
71383beep  Offline
IL
No flaming here...like 451mopar and others i am officially part of the been there done that crowd as far as producing a compressionless lame duck 383 by reading too many magazines and listening to too many experts.
Best bang for the buck to get compression is closed chamber heads. I am running 516's and it brought my 383 back from the grave.
'73 GK6 Challenger Rallye - 340 4-Speed
Re: 383hp [Re: 71383beep] #286817
04/13/09 03:12 PM
04/13/09 03:12 PM
Spokane Wa
Spokane Wa
anyone know what heads the hp motor came with in 71? where would be a good place to find the 516 heads?
Re: 383hp [Re: CrazyRocker70] #286818
04/13/09 03:34 PM
04/13/09 03:34 PM
Wherever I am.
Junky Offline
Junky  Offline
Wherever I am.
Mine, from a '71 Newport, has 346 heads and has a forged crank. When I had the heads off I used a feeler gauge to check how far in the hole the pistons were. Measured a snug 0.020 in the hole, flat top pistons, no valve reliefs.
2010 Black Challenger SE <> 3.5 V6
Custom Shift Knobs www.flameball.com Check It Out
Re: 383hp [Re: Junky] #286819
04/13/09 03:55 PM
04/13/09 03:55 PM
JohnRR Offline
JohnRR  Offline
68-69 pistons are .003 in the hole 4bbl or 2 bbl , the 2bbl also has a dish , are the 2bbls dished in 71 ?
Re: 383hp [Re: CrazyRocker70] #286820
04/13/09 10:37 PM
04/13/09 10:37 PM
IL
71383beep Offline
71383beep  Offline
IL
most likely 346's. decent heads, but open chamber. I should clarify that you can use them you just need to get good pistons that have a good compression height.
Re: 383hp [Re: 71383beep] #286821
04/13/09 10:48 PM
04/13/09 10:48 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Re: 383hp [Re: Alaskan_TA] #286822
04/14/09 12:30 AM
04/14/09 12:30 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Had a nice mild 383 with open chamber heads. It was a 70 block with stock pistons and the 452 heads were milled about .070 to get 9.5 comp with the .020 steel head gaskets. I used the MP .484 cam on a 104 centerline. The 452 heads had some mild pocket porting done on them but that was it. Had a Performer RPM intake with a 750 DP. Used CPPA 2" headers and a TA 10" tight 3000 converter. With 3.91's in my sons 3575 lb Dart (with him in it) it ran as fast as 12.31 @ 110. Ron
Re: 383hp [Re: CrazyRocker70] #286823
04/14/09 02:25 AM
04/14/09 02:25 AM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
The '71 should have has 346 heads. I don't think I mentioned why they were not on my engine...
I over-reved the 383 (rember pistons with no valve reliefs), and bent two intake valves
The '71 Charger 500 in my user photo was an original numbers matching 383HP 4-bbl car, and it had the 383 I described in it before I installed the 451 stroker.
Re: 383hp [Re: 451Mopar] #286824
04/14/09 08:43 AM
04/14/09 08:43 AM
JohnRR Offline
JohnRR  Offline
did you deck the block to zero the pistons ? how big was the lift of the cam ??? Replacement 383 pistons are at best .015 in the hole .
