Re: New build HP potential?
[Re: dvw]
#2866885
12/31/20 10:54 AM
12/31/20 10:54 AM
Posts: 10,044 MN
JERICOGTX
MN
DVW, to answer your question about pistons, I got them with the block. They were setup for the 4.375 crank. Talked to my machinist, and we discussed why the previous builder set it up that way. To help get the crank out of the oil better. He agreed, and said the 16ci difference wasn’t worth buying new pistons for.
69 GTX
68 Road Runner
[Re: racerx]
#2866898
12/31/20 11:12 AM
12/31/20 11:12 AM
Posts: 4,210 New York
polyspheric
New York
mopars love fuel/air Everything does
Boffin Emeritus
[Re: JERICOGTX]
#2866913
12/31/20 11:39 AM
12/31/20 11:39 AM
Posts: 19,382 Las Vegas
Al_Alguire
Las Vegas
IMO you are going to be leaving some power on the table with the compression ratio for sure. Also depending on the cam it could be a make or break deal too. Lastly assuming the carb is a 2" throttle plate Dominator its going to cost you some power to. So I would say as listed 825ish +-25.
FWIW I did a very similar combo that was meant for our dragster but sold to a friend of a friend instead. Id estimate it makes 750ish. The only difference was it is a stock block(smaller bore) 512" deal. Same heads, same 2" carb, 13.5-1 compression, NO vacuum pump and it has been 9.40's in a 3300lb road runner. Of course its got one of those mystery power robbing slush box torque multiplier things behind it. I think the carb is killing it as well as the very conservative timing(locked at 26) they run. But the owner is 76 and as he says is going plenty fast enough for him.
[Re: Al_Alguire]
#2866956
12/31/20 01:12 PM
12/31/20 01:12 PM
Posts: 10,016 Frostbitefalls MN (Rocky&Bullw...
gregsdart
What rockers do you plan to run? Pushrods? Installed hieght? All that combined with the life you expect out of your cam and valvetrain will need to be thought out thoroughly. If you want to push it, i have a 283/296/112 with .500 intake lobes and .460 exhaust sitting on my bench. I can send you a pic of the camcard
[Re: JERICOGTX]
#2866976
12/31/20 01:43 PM
12/31/20 01:43 PM
Posts: 31,073 Oregon
AndyF
Curios on why the 1050 with that much cubic in?I always thought mopars love fuel/air. Simply because it’s what I have. Switch to EFI and run a 2000 cfm throttle body. Worked for me.
[Re: AndyF]
#2866982
12/31/20 01:48 PM
12/31/20 01:48 PM
Posts: 16,930 NC
440Jim
NC
In your case if you just bolt it all together right out of the box then you should be in the 800 range. If you have everything touched up by pros and have the right cam in it then you could be up in the 900 range.
Andy said pretty much my opinion. I think 820 is pretty easy with the CNC 345 heads and a cam around 0.750" lift (1.6 rockers)
[Re: racerx]
#2867001
12/31/20 02:42 PM
12/31/20 02:42 PM
Posts: 288 NW Illinois
MoonshineMattK
NW Illinois
Curios on why the 1050 with that much cubic in?I always thought mopars love fuel/air. Simply because it’s what I have. I understand it is what it is.......i just think you leavening some on the table,i had a 451" BB with a 850 that ran very lean. Put a 1050 on a/f came down engine was happy. Aren't those 440/six packs rated at 1200cfm? For some reason 2 barrel carbs and 4 barrel carbs are not rated the same way. The 6pack carbs come out to around 950cfm in 4 barrel rated numbers If I recall correctly
[Re: rb446]
#2867002
12/31/20 02:45 PM
12/31/20 02:45 PM
Posts: 2,933 A shed in England
Tig
A shed in England
We have a guy here in UK who posts on here, runs a 580 wedge, 12.5:1, ported -13's, 385CNC roller of approx 750 lift, TR with 2 x 1150's and according to his weight/mph he is making around 895fwhp....perhaps he'll see this and post up maybe something I missed. Hi Les, The 580 wasn't built as an all out effort but as a reliable low maintenance bracket motor, we've learned some stuff along the way and got it running good without loosing any reliability. You are correct, it's just under .750 net lift on the inlet and .730 exhaust with 1.6 arms (tempted to go to 1.7's but it just ain't that easy) It picked up some running low tension rings and a vac pump. We also found a couple of things at the end of the 2019 season so we may pick up a little next time out but we'll see. The OPs engine should easily crest 800hp with a couple of tricks maybe 850, an all out effort and some real attention to detail should see 900hp IMHO
'74 Challenger..9.46 @ 145.9 1/4, 6.001 @ 118 1/8 so far. 4023lb !!! # N/A, Marsh performance 655ci, Indy Maxx, T/R, Indy 600-13 X's, Street legal, pump gas, full interior, Cal-Tracs, mufflers, 3:73's and real 10.5 radials. 9.51 @ 142.4 1/4, 6.003 @ 114 1/8 with our old mule KB, 572-13, 580 wedge. RHD '68 Barracuda Fastback 323ci street/strip. Best ET 13.88 @ 99.03
[Re: Tig]
#2867035
12/31/20 03:26 PM
12/31/20 03:26 PM
Posts: 4,696 On the parachute mount
n20mstr
I run a 1050 on my engine BUT that’s acceptable to under carb a nitrous engine to get some carb signal when using larger amounts of nitrous . I would think a larger carb would help . But it is an easy upgrade later , and real easy to even borrow one and A-B test it at the track
....BAD A$$ STREET CAR.....
