Re: Push rod oiling [Re: n20mstr] #2869930
01/06/21 06:05 PM
01/06/21 06:05 PM
WA
JD Dart Offline
JD Dart  Offline
WA
Yea what he said plus when you go to bushed on the roller for the lifter they need oil.
best so far 8.53 @ 158.59 MPH 60'1.240
Re: Push rod oiling [Re: JD Dart] #2870196
01/07/21 12:17 AM
01/07/21 12:17 AM
NY
challenger451ci Offline
NY
I mostly did it because I wanted to run Crower HIPPO lifters that pressure feed the roller axles.
Re: Push rod oiling [Re: n20mstr] #2870260
01/07/21 09:09 AM
01/07/21 09:09 AM
an8sec70cuda Offline
Originally Posted by n20mstr
Originally Posted by an8sec70cuda
Stupid question...what situation/combo requires pushrod oiling? Or is just a preference?
The stuff I've messed w/ has all been conventional oiling.
Paired T and D individual shaft rockers need pushrod oiling.
Gotcha...no other way to get oil to the other 3 shafts if they are separate, unless you have spray bars. The B1 motors I've messed with were common shaft w/ T&D rockers.
Spray bars in the valve covers seem like a simpler solution, but I guess they aren't as effective?
I've always liked the fact that my KB block doesn't oil the lifters. After 14 years I've had no issues, but my cam isn't aggressive either.
CHIP
'06 GMC 2500HD LBZ Duramax
