Carter AVS CFM Rating? #2865076
12/26/20 09:34 PM
12/26/20 09:34 PM
New York
rarefish Offline OP
rarefish  Offline OP
New York
Does anyone know what the CFM rating was on the factory installed 1968-69 440-4 AVS carbs?
Re: Carter AVS CFM Rating? [Re: rarefish] #2865121
12/27/20 01:12 AM
12/27/20 01:12 AM
Sobieski Wi
bee1971 Offline
bee1971  Offline
Sobieski Wi
All 440 HP Motors where 750cfm - High Performance or HP Engines 1968 - 1971
Model # is on front passenger side base plate if it doesnt have a tag
The smaller Carter AVS was rated at 630cfm - 383 and 340 Engines and Non HP or Low Performance 440 Motors
Easy way to tell a 750cfm Carter AVS if its off the car , flip it over , all four throttle plates are the same size 1 11/16"
1971 Dodge Charger Superbee
2011 Ram Sport 1500 Quad Cab Deep Water Blue Loaded
Siberian Huskies
Re: Carter AVS CFM Rating? [Re: bee1971] #2865188
12/27/20 11:08 AM
12/27/20 11:08 AM
New York
rarefish Offline OP
rarefish  Offline OP
New York
Thanks....
Re: Carter AVS CFM Rating? [Re: bee1971] #2865365
12/27/20 05:51 PM
12/27/20 05:51 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Those numbers are often quoted but never verified. There's more to CFM airflow than just throttle plate diameter.
