Re: lift off to hinged
[Re: poorboy]
#2864706
12/25/20 05:55 PM
12/25/20 05:55 PM
Posts: 20,813 A collage of whims
topside
A collage of whims
Depends on the panel, whether it's "race-weight" or has any inner structure. My race-weight lift-off hood is also something I'm "over". Had another Duster, had a nice 'glass hood with stock-ish inner structure, used hinges w/o springs, worked fine. Heavier of course, but still lighter than an OEM hood. Pins were not an issue, stood up vertical, and I used a Toyota PU prop rod. If doing your own inner reinforcement for hinges, they should be full-length, and joined at front & back (basically fab a square).
[Re: topside]
#2864836
12/26/20 10:19 AM
12/26/20 10:19 AM
Posts: 4,779 Holland MI Ottawa
2boltmain
Holland MI Ottawa
In 2000 I bought a flat stock appearing fiberglass hood for my Challenger from AAR. I planned to cut a hole for a tunnel ram but noticed I would be cutting thru the underlayment structure. A gentlemen at AAR told me to place hood upside-down on a blanket or lawn/grass. Then cut slabs of styrofoam insulation board like Celotex and fit them into and in between the existing structure. Then lay fiberglass cloth over the foam board. After it cured I cut my hole and the hood remained uncompromised and stiff as can be.
Keep old mopars alive.
[Re: 2boltmain]
#2864838
12/26/20 10:23 AM
12/26/20 10:23 AM
Posts: 630 Ct
Wirenut
Ct
In 2000 I bought a flat stock appearing fiberglass hood for my Challenger from AAR. I planned to cut a hole for a tunnel ram but noticed I would be cutting thru the underlayment structure. A gentlemen at AAR told me to place hood upside-down on a blanket or lawn/grass. Then cut slabs of styrofoam insulation board like Celotex and fit them into and in between the existing structure. Then lay fiberglass cloth over the foam board. After it cured I cut my hole and the hood remained uncompromised and stiff as can be. Interesting thanks
[Re: cudaman1969]
#2865164
12/27/20 10:12 AM
12/27/20 10:12 AM
Posts: 630 Ct
Wirenut
Ct
We did it on a Dart, glassed in aluminum angles to attach the hinge. Removed big springs then used 2 poles (millions in the junk yards) to swing up into the pin holes with the standard 2 hood pins to hold the hood down. This was along my line of thinking . Good to know it’s been done
[Re: Stanton]
#2865167
12/27/20 10:15 AM
12/27/20 10:15 AM
Posts: 630 Ct
Wirenut
Ct
Build a square frame from thin wall square tubing. Hinge to the frame. Make brackets off the frame to use existing pins and pin holes to attach the hood to the frame. I think this would be the idea with the hood as its likely a bit more flexible than the deck lid. Thanks for the advice
[Re: Wirenut]
#2865184
12/27/20 10:58 AM
12/27/20 10:58 AM
Posts: 8,290 fredericksburg,va
cudaman1969
fredericksburg,va
We did it on a Dart, glassed in aluminum angles to attach the hinge. Removed big springs then used 2 poles (millions in the junk yards) to swing up into the pin holes with the standard 2 hood pins to hold the hood down. This was along my line of thinking . Good to know it’s been done It had a built in six-pac scoop, not flimsy
[Re: dOoC]
#2865898
12/28/20 10:24 PM
12/28/20 10:24 PM
Posts: 630 Ct
Wirenut
Ct
Pic of the underside of the bracing you have now ? Dug out the donor hinges for the deck lid and started mocking things up . The hinges will need to be dearched as they hit the oversized wheel tubs . I’ll fool with that next and get it so the lid can be set on with the hinges in place . Then I may find a small person to put in the trunk to make some marks where the hinges land on the lid. Is it kidnapping if you let them go after only a short period of time? Anyhow , Doc this is the underside of the lid. I think I can make the hinges fall on the extruded area
[Re: dOoC]
#2866626
12/30/20 06:09 PM
12/30/20 06:09 PM
Posts: 630 Ct
Wirenut
Ct
nut... You going to lose the springs and torsion bars ? Doc , All that stuff was removed when it was turned into a race car. I have a set of hinges alone that I have been massaging and mocking up and they actually look like they will work out. Because of how the hinges layout vs the lid I will have to cut into the and remove a section of raised support you see on the underside of the lid . Thats where I will attach a 2x2 piece of aluminum angle to bolt to the hinge. Ultimately I will epoxy and glass mat the angle in once I have the angle in the correct position. Is there anything I can use to like glue , or contact cement or???? to temporarily put those angles on good enough to mock up and test position? Something that could be removed to reset the angle if wrong?
[Re: dOoC]
#2866995
12/31/20 02:13 PM
12/31/20 02:13 PM
Posts: 630 Ct
Wirenut
Ct
Kinda have to see the hinge setup your going to use on each part Ok let me ask this. The surface is kinda rough fiberglass with what looks like flat black paint . Any special prep or can I just lay down some resin / glass and good?
[Re: Wirenut]
#2867514
01/01/21 01:39 PM
01/01/21 01:39 PM
Posts: 30,450 Florida STAYcation
dOoC
The village idiot's idiot
Florida STAYcation
Kinda have to see the hinge setup your going to use on each part Ok let me ask this. The surface is kinda rough fiberglass with what looks like flat black paint . Any special prep or can I just lay down some resin / glass and good? I would get as much paint OFF THERE as I can
