Re: NE1 tried any LED headlight conversions?
[Re: crackedback]
#2867117
12/31/20 07:03 PM
12/31/20 07:03 PM
Posts: 4,764 Florida
BDW
If you are running the factory OEM wiring harness, please don't hook your relays up at the battery.
If anyone tells you or suggest that on a muscle era factory OEM wired mopar... RUN!!!!! So where do you hook up a relay?
[Re: BDW]
#2867119
12/31/20 07:05 PM
12/31/20 07:05 PM
Posts: 6,362 nowhere
Sniper
nowhere
If anyone tells you or suggest that on a muscle era factory OEM wired mopar... RUN!!!!! So where do you hook up a relay? Alternator output stud via a fuse or fusible link.
[Re: BDW]
#2867199
12/31/20 09:41 PM
12/31/20 09:41 PM
Sniper
nowhere
Ok, but most bypass the amp meter and connect the alternator directly to the battery? Some of us know what an ammeter is good for too.
