Re: Lets See Your Trucks
[Re: larrymopar360]
#2832489
10/13/20 10:02 PM
10/13/20 10:02 PM
Posts: 4,283 Florida
blewbyu
Well I just got this old Truck Bought.
[Re: mccannix]
#2864000
12/23/20 06:08 PM
12/23/20 06:08 PM
Posts: 2,684 Des Moines IA
Soopernaut
Des Moines IA
This isn't a "whats it worth" but rather a 'what is it' question. I was hoping perhaps one of the many truck owners here could tell approximately what years this tailgate is from, that I found at an old dealership. They also have the Canadian only, FARGO tailgate from the same era, both fleetside as it is the same basically except embossed Fargo instead of Dodge. Thanks in advance Technically, it will fit all late 65-71 (early 65 had a different bed) trucks with the sweptline bed. However, it may not be correct for all years since 71 trucks did not have a stamped tailgate.
1970 Dodge d100/eventually going on a 77 D100 frame
[Re: JeepTony]
#2873521
01/13/21 05:07 AM
01/13/21 05:07 AM
Posts: 20 Tampa, FL
Andrew Giles
Tampa, FL
The wheels on that 2011 Ram looks amazing!
[Re: 440newport]
#2897147
03/08/21 04:04 PM
03/08/21 04:04 PM
Posts: 20 Tampa, FL
Andrew Giles
Tampa, FL
"My Mopars. 2011 Ram 3500 Cummins, 2001 Ram 2500 Cummins, 1997 Jeep TJ" They all look awesome, JeepTony.
[Re: SALEM1912]
#2924362
05/19/21 12:31 PM
05/19/21 12:31 PM
Posts: 2,114 Byron, NY
W.I.N. Racing
Byron, NY
Not the best pic but the best I got for now...9/20 shake down run. 6/5 should be first real full out pass Update; 9/24 best of 4.87 1/8th mi (black traacking thru first gear) .3 more to go...With lots of ways to improve (front strut dampening not even close to correct, Wheelie bar height, Timing tweeking, Converter charge pressure) all have yet to be optimized
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60 '01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust, '05 Dodge Magnum R/T - Too Much to list '60 Willys CJ5 '01 International LPX - Project,DT466, Allison '64 Plymouth Valiant, Inj 528 Hemi, 2spd
[Re: cwkerr007]
#2949587
08/02/21 06:47 AM
08/02/21 06:47 AM
Posts: 4,798 Castlegar, BC, Canada
That AMC Guy
I call it: General Delivery.
My first mopar truck. '88 Ram D100, 3.9 TBI V6, Auto. Buddy turned it into a 440 Shorty, but then said something about the changes done to the '88 frame don't allow headers on a big block? I'm not 100% sure why he gave up on the project. It's a 75,000 km truck, the interior is MINT, body is flawless and rust free.... just needs some assembly. Did another trip out to his place just today and we found a whack of parts he thought he'd lost: shroud, kickdown linkage, headlight buckets, engine brackets....etc....
The last item on my list of things to find is just a 2wd transmission bracket. Then I can really get going on re-assembly!
Bloody Mary, Full of Vodka, Blessed art thou among cocktails....
