Re: Stock 727 planetary with transbrake?
[Re: 70Drop]
#2862045
12/19/20 07:03 AM
12/19/20 07:03 AM
Posts: 2,937 A shed in England
Tig
A shed in England
If it were me, I'd do it now. "Peace of mind", "done before it takes out other stuff with it", "ready for more motor" etc etc.
'74 Challenger..9.46 @ 145.9 1/4, 6.001 @ 118 1/8 so far. 4023lb !!! # N/A, Marsh performance 655ci, Indy Maxx, T/R, Indy 600-13 X's, Street legal, pump gas, full interior, Cal-Tracs, mufflers, 3:73's and real 10.5 radials. 9.51 @ 142.4 1/4, 6.003 @ 114 1/8 with our old mule KB, 572-13, 580 wedge. RHD '68 Barracuda Fastback 323ci street/strip. Best ET 13.88 @ 99.03
[Re: Tig]
#2862059
12/19/20 09:17 AM
12/19/20 09:17 AM
Posts: 9,882 MI, usa
dvw
MI, usa
If it strips it won’t take anything out. Probably not a bad idea to go steel carrier. We’ve stated to twist the splines out of them. Always caught during inspections. For sure you can put a lot of power thru the stock carrier on a foot brake leaving hard. 1.2x 60ft 3350-3550. Doug
[Re: dvw]
#2862065
12/19/20 10:03 AM
12/19/20 10:03 AM
Tig
A shed in England
If it strips it won’t take anything out. Probably not a bad idea to go steel carrier. We’ve stated to twist the splines out of them. Always caught during inspections. For sure you can put a lot of power thru the stock carrier on a foot brake leaving hard. 1.2x 60ft 3350-3550. Doug I had aluminium run through the 'box, cooler and lines after stripping one. It's just a PITA to clean out and my OCD had me freshen the 'box at the same.
[Re: racerx]
#2862068
12/19/20 10:13 AM
12/19/20 10:13 AM
Posts: 12,592 Great Neck,LI,new york
hemi-itis
6 pin comes in the Cummins trans that fits the 727. They cost under $50. Years back I bought the A&A 4 pinion for $500 after wiping out the aluminum!
[Re: dvw]
#2862077
12/19/20 10:46 AM
12/19/20 10:46 AM
Posts: 876 Arizona
PolyDart
Arizona
If it strips it won’t take anything out. Probably not a bad idea to go steel carrier. We’ve stated to twist the splines out of them. Always caught during inspections. For sure you can put a lot of power thru the stock carrier on a foot brake leaving hard. 1.2x 60ft 3350-3550. Doug I stripped one out shifting into 2nd and it was like missing a shift with a manual car. Engine instantly over revved. It may not hurt the tranny, but it could hurt the motor.
[Re: PolyDart]
#2862122
12/19/20 12:49 PM
12/19/20 12:49 PM
Posts: 25,992 Rio Linda, CA
John_Kunkel
Rio Linda, CA
When starting out in 1st, brake or not, both planetaries are sharing the load. but. When shifted to 2nd, the front planetary absorbs the load, so that's the common failure mode.
[Re: John_Kunkel]
#2862400
12/20/20 01:10 AM
12/20/20 01:10 AM
Posts: 223 California
70Drop
California
When starting out in 1st, brake or not, both planetaries are sharing the load. but. When shifted to 2nd, the front planetary absorbs the load, so that's the common failure mode. Very interesting. Puts it into perspective. I've got probably 80 passes on the car, shifted into 2nd gear on every one of them, lol. I'll be sure to inspect carefully next time I take the trans apart, but I think I'll leave it for now
[Re: dvw]
#2862403
12/20/20 01:17 AM
12/20/20 01:17 AM
70Drop
California
The Cummins planet is steel. But your output shaft has to have the correct spline angle to work. The amount of aluminum that came of the the ones we've hurt was gradual. Never saw much shrapnel. Over rev? A race car without a top end rpm limiter? Doug Do you know how I would check for the correct spline type for the Cummins planetary? I know there are early and late shafts, mine is the later (bigger) type.
[Re: 70Drop]
#2862882
12/21/20 10:54 AM
12/21/20 10:54 AM
hemi-itis
I am no expert by any means,,,,,,but I think the 66 to 71 spline is the same ![work work](/ubbthreads/images/graemlins/custom/work.gif) I wiped 2 aluminum sets foot braking off the line with 800 + HP @ 3900#
[Re: hemi-itis]
#2862954
12/21/20 02:25 PM
12/21/20 02:25 PM
John_Kunkel
Rio Linda, CA
The output shaft spline included angles are as follows:
'62-'75= 90°
'76-'93= 75°
'94-on= 60°
[Re: dvw]
#2863066
12/21/20 06:46 PM
12/21/20 06:46 PM
Posts: 876 Arizona
PolyDart
Arizona
Over rev? A race car without a top end rpm limiter? Doug It happened on the street, actually getting onto I-10 after a car show. The car has a limiter, but it still redlined with no load which never feels good.
[Re: PolyDart]
#2863188
12/22/20 12:53 AM
12/22/20 12:53 AM
Posts: 6,569 Downtown Roebuck Ont
Twostick
Still wishing...
Still wishing...
Over rev? A race car without a top end rpm limiter? Doug It happened on the street, actually getting onto I-10 after a car show. The car has a limiter, but it still redlined with no load which never feels good. It's called inertia. If the engine is under load at say 6500 and the load instantly goes away, the inertia of the crank and everything turning with it can accelerate it well past its redline, if only briefly. A rev limiter will have zero control of that. Kevin
[Re: Twostick]
#2863225
12/22/20 08:28 AM
12/22/20 08:28 AM
dvw
MI, usa
Over rev? A race car without a top end rpm limiter? Doug It happened on the street, actually getting onto I-10 after a car show. The car has a limiter, but it still redlined with no load which never feels good. It's called inertia. If the engine is under load at say 6500 and the load instantly goes away, the inertia of the crank and everything turning with it can accelerate it well past its redline, if only briefly. A rev limiter will have zero control of that. Kevin Zero control? So you don’t use one? Doug
[Re: dvw]
#2863314
12/22/20 12:35 PM
12/22/20 12:35 PM
Twostick
Still wishing...
Still wishing...
Over rev? A race car without a top end rpm limiter? Doug It happened on the street, actually getting onto I-10 after a car show. The car has a limiter, but it still redlined with no load which never feels good. It's called inertia. If the engine is under load at say 6500 and the load instantly goes away, the inertia of the crank and everything turning with it can accelerate it well past its redline, if only briefly. A rev limiter will have zero control of that. Kevin Zero control? So you don’t use one? Doug I don't currently have anything that requires one. My point is if you lose the overrunning clutch anywhere towards the top of the RPM range, inertia can accelerate the engine past its redline regardless of any rev limiter. Kevin
