Megablock repair; what would you do?
#2861613
12/18/20 05:07 AM
12/18/20 05:07 AM
Posts: 10,016 Frostbitefalls MN (Rocky&Bullw...
gregsdart
First off, i stated earlier that #2 cylinder was split. I was wrong. The spot was deep enough to catch a finger nail on, but may clean up with a hone. At most it would end up about 4.508. Water must have sat in there a long time to leave a mark like that. #1 has a minor scratch that needs a rehone. So what i have is a Megablock from. Year 2000. Fresh line hone. Bushed lifter bores with .060 holes for oiling. Deck hieght of 10.695. Cylinders 3,4,5,6,7,8 are at 4.5043 bore and only have dyno time and seven runs on them. Here are the sonic #s. How would you fix it? What would you value it at as is?
Re: Megablock repair; what would you do?
[Re: gregsdart]
#2861614
12/18/20 05:29 AM
12/18/20 05:29 AM
gregsdart
Would a half fill with hardblock be ok without a rehone? For cylinder thickness #8 needs the most help. #6 isn't far behind. If that would work, i could put it back together with little expense. Recoat #1 and #2 piston at line2line to the new size. There is a scratch in #1 that needs to be cleaned up too.
[Re: gregsdart]
#2861676
12/18/20 11:49 AM
12/18/20 11:49 AM
Posts: 315 Northeast Indiana
73DAD
Northeast Indiana
Sleeve all 8 back to 4.310 & sell it to me for 3k, & I'd be a happy camper! I bet you would! On a serious note though, sell that lump off before the new Callies blocks come out. Winter is here & folks have nothing to do with their cars except build. Its worth the most it can be worth right now. And, if the Callies thing falls through, put the money toward an aluminum block and go faster. That's what I'd do, to answer your question.
[Re: dvw]
#2862282
12/19/20 07:27 PM
12/19/20 07:27 PM
gregsdart
What caused the nick? If the nick wont catch the ring and it's not a crack, touch hone and run it. It's not like you put many passes on it anyway. The bores will be as round and stiff as they've always been. Or spend 10k on a new short block and maybe pick up .10 Doug There is a scratch in #1 that is barely able to be felt. Todd (Sasquatch) from Marsh performance and said my block will ship soon. So i plan on selling the megablock, pistons and rods. Listed in the engines 4sale forum. Thanks everybody for input. It has helped me make a lot of decisions. I plan on starting a new post on the next build.549 cubes, new pistons, long rods, getting rid of the gear drive , moving to a belt drive.
