Re: PAC spring questions
[Re: Jeremiah]
#2860752
12/16/20 01:42 PM
12/16/20 01:42 PM
Thumperdart
State of confusion
Forgot my part # but after 9 years on the street they were all within 10lbs.....
[Re: mopar dave]
#2860908
12/16/20 04:52 PM
12/16/20 04:52 PM
Thumperdart
State of confusion
Found my card they are part # 9385.....
[Re: mopar dave]
#2860946
12/16/20 06:26 PM
12/16/20 06:26 PM
Posts: 7,499 Minnesota
Hemi_Joel
Minnesota
What application would call for the endurance of the 1300 spring? Drag Week comes to mind.
[img]http://i.imgur.com/boeexFms.jpg[/img]31 Plymouth Coupe, 392 Hemi, T56 magnum RS23J71 RS27J77 RP23J71 RO23J71 WM21J8A I don't regret the things I've done. I only regret the things I didn't do. "Wise men talk because they have something to say; fools because they have to say something. ~ Plato"
[Re: mopar dave]
#2860998
12/16/20 08:33 PM
12/16/20 08:33 PM
Posts: 485 Central California
MoParFish
Central California
PAC 1243 and pac 1343 have same dimensions so. What’s the difference and which one is best for street strip .680 roller? Also Howard’s has a pacaloy 98843, same dimensions, is this the same pac spring sold under Howard’s. Just FYI, I have ran Trick Flow TFS-16943-16 springs since 2013 on Edelbrock MW Victors with.674 Valve Lift. They are re-boxed PAC and I believe the 1200 series. The Trick Flow box says "by PAC". I pulled the heads apart a couple years ago (blew some metal out between 3 and 5) and when I checked the springs, was surprised how pressure readings (seat and open), didn't vary much from when I checked them when they were new out of the box. After fixing the head, I reassembled using same springs. . https://www.summitracing.com/nv/parts/tfs-16943-16
