Re: PAC spring questions [Re: Jeremiah] #2860752
12/16/20 01:42 PM
12/16/20 01:42 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Forgot my part # but after 9 years on the street they were all within 10lbs.....
Re: PAC spring questions [Re: Thumperdart] #2860845
12/16/20 03:32 PM
12/16/20 03:32 PM
Mt Morris Michigan
mopar dave Offline OP
Mt Morris Michigan
I think the 1243 pac spring is a specialty spring for short install height. Can’t find anything like it on Isky site. $280 is not a bad price either.
Re: PAC spring questions [Re: mopar dave] #2860908
12/16/20 04:52 PM
12/16/20 04:52 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Found my card they are part # 9385.....
Re: PAC spring questions [Re: mopar dave] #2860946
12/16/20 06:26 PM
12/16/20 06:26 PM
Minnesota
Hemi_Joel Offline
Hemi_Joel  Offline
Minnesota
Originally Posted by mopar dave
What application would call for the endurance of the 1300 spring?
Drag Week comes to mind.
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: PAC spring questions [Re: mopar dave] #2860998
12/16/20 08:33 PM
12/16/20 08:33 PM
Central California
MoParFish Offline
MoParFish  Offline
Central California
PAC 1243 and pac 1343 have same dimensions so. What’s the difference and which one is best for street strip .680 roller? Also Howard’s has a pacaloy 98843, same dimensions, is this the same pac spring sold under Howard’s.
Just FYI, I have ran Trick Flow TFS-16943-16 springs since 2013 on Edelbrock MW Victors with.674 Valve Lift. They are re-boxed PAC and I believe the 1200 series. The Trick Flow box says "by PAC". I pulled the heads apart a couple years ago (blew some metal out between 3 and 5) and when I checked the springs, was surprised how pressure readings (seat and open), didn't vary much from when I checked them when they were new out of the box. After fixing the head, I reassembled using same springs. twocents. https://www.summitracing.com/nv/parts/tfs-16943-16
Sworn Member Central Valley MoPar Drag Pack. You can reach me at (done-et-chasing@going-rounds.gone)... :-)
[img]https://s6.postimg.org/v3mbggksx/SAC16.jpg[/img]image hosting more than 5mb
Re: PAC spring questions [Re: MoParFish] #2861008
12/16/20 08:57 PM
12/16/20 08:57 PM
Mt Morris Michigan
Mt Morris Michigan
Cool. That’s an even better price yet. Thanks
Re: PAC spring questions [Re: mopar dave] #2861023
12/16/20 09:35 PM
12/16/20 09:35 PM
I forgot to mention I've had and used a valve spring tester that shows Lbs. and distance when installing valve springs since the mid 1970s, on roller cam springs I shoot for .055 to .080 to coil bind on iron heads and from .065 to .085 on aluminum heads. I try to get the seat pressures within + or- 5 lbs. and shoot for between + or -20 lbs. open pressures by shimming or swapping the inner and outer springs to get what I want wrench
Re: PAC spring questions [Re: Cab_Burge] #2861154
12/17/20 09:02 AM
12/17/20 09:02 AM
Mt Morris Michigan
Mt Morris Michigan
I will check those best i can for coil bind and p-v, but thought if i set them up at 1.900 as they are spec'd by Pac, the pressures would be very close or close enough. I'm not removing the heads. I called Howards yesterday about the Pac 1200 and 1300 series springs and Eric tells me they never seen the 1300 spring last any longer than the 1200. He also said the 1200 is plenty for what i'm doing as some on he have said as well. Thanks guys
