Re: Hemi-style caps for B/RB [Re: 67_Satellite] #2862873
12/21/20 10:12 AM
12/21/20 10:12 AM
Taxes & Virus's R-US, NY
Dragula Online content
Dragula  Online Content
Show me one, I can go pick up right now....My point is, they are not available yet.
Re: Hemi-style caps for B/RB [Re: mr_340] #2862909
12/21/20 12:24 PM
12/21/20 12:24 PM
NW Illinois
MoonshineMattK Offline
NW Illinois
Originally Posted by mr_340
Originally Posted by AndyF
If the Mopar engineers had been thinking they would have cast the bosses in the side for the cross bolts and just left them unmachined on the production blocks. It would not have cost any more money but it would've made the blocks capable of being properly cross bolted down the road. They could sold cross bolted wedge blocks over the counter thru Direct Connection. They just weren't thinking that far ahead.
They did produce some cross bolted wedge blocks for NASCAR so they knew how to do it. They just never convinced the production guys to add the material for the bosses.
I have a 426 marine block that has the bosses cast in to the sides like a Hemi block. They are not machined, but the bosses are there.
That's a neat piece you've got there. Always something new. If you have pictures of the lifter valley I'm curious to see if it has bosses for the hemi style head stud.
Re: Hemi-style caps for B/RB [Re: MoonshineMattK] #2863331
12/22/20 01:04 PM
12/22/20 01:04 PM
Southern Alberta
Uberpube Offline
Uberpube  Offline
Southern Alberta
http://www.dvorakmachine.com/4boltconversion.shtml
I thought about doing this, but my machine shop didn't think it was necessary for a 5600 rpm engine. Just doing studs and an align hone.
Re: Hemi-style caps for B/RB [Re: MoonshineMattK] #2864645
12/25/20 03:29 PM
12/25/20 03:29 PM
DFW
mr_340 Offline
mr_340  Offline
DFW
Unfortunately, no. Just the standard wedge valley. This is about the only photo I took years ago that shows anything up top. It has bosses at the back for some sort of water connections. Maybe these were machined out for truck or industrial applications?
Floyd Lippencott IV
Re: Hemi-style caps for B/RB [Re: mr_340] #2864765
12/25/20 09:09 PM
12/25/20 09:09 PM
Your pictures look exactly like all the 413 H.D. Industrial , marine and truck motor blocks I've bought and used to make 426 W motors, including the wired looking water like pump bosses on the rear shruggy
The last one, 413 H.D. truck block I took in trade was cast in 1972 and came with the H.D. crankshaft which I used the crank to offset grind it to make a 3.91 stroke crank with 2.200 rod journals and put it in a 440 block for pump gas street motor. I had a Mopar 8 bolt crank flange 4.150 stroke crank in stock and used that crank in the 413. block bore to 4.25 to put in my 1963 Plymouth Fury with a set of 440 source heads so I can tell the locals that old Plymouth has a 413 C.I. junkyard truck motor in it that runs pretty good for a 413 devil stirthepot
