Re: Valve Cover Bolt Hole Location Variations [Re: markz528] #2860106
12/14/20 11:44 PM
12/14/20 11:44 PM
Melbourne , Australia
LA360 Offline
LA360  Offline
It's been ages since I made the billet valve covers, the first set I made are on a friends engine that is starting to go back together now. I will see him on the weekend, so I will check then. Based on what you've said Mark, I will be adjusting my CAD model. I might get back to making some more valve covers down the track.
Cheers
Alan Jones
Re: Valve Cover Bolt Hole Location Variations [Re: AndyF] #2860165
12/15/20 05:31 AM
12/15/20 05:31 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
Originally Posted by AndyF
Call Russ and ask him why the bolt holes are in the wrong spot. After he yells at you for 20 minutes and tells you how dumb you are and how dumb your mother is you'll forget what the question is and hang up.
Sounds like my one and only phone call with Herb McCandless in my youth laugh2
Re: Valve Cover Bolt Hole Location Variations [Re: AndyF] #2860186
12/15/20 09:06 AM
12/15/20 09:06 AM
anywhere@ anytime
actionange Offline
actionange  Offline
anywhere@ anytime
Don’t think Russ is there anymore
Re: Valve Cover Bolt Hole Location Variations [Re: markz528] #2860198
12/15/20 09:30 AM
12/15/20 09:30 AM
NC
440Jim Offline
440Jim  Offline
NC
Originally Posted by markz528
I machined my B1 adapters to the number Scott Koffel gave me. I think I wanted to locate these tightly (I get too anal sometimes) and made the 4 inner holes .260" and the outer ones .270". The adapters fit well. So I guess the numbers I received are correct.
With those tight drill diameters and them fitting well, that is the tie breaker for me. I am going with 0.325" offset for the B1's.
Even though 0.315 and 0.281" dia holes should fit too.
