73 challenger quarter window #2858369
12/11/20 07:06 AM
12/11/20 07:06 AM
McMurray PA
K
Kevin E Offline OP
Kevin E  Offline OP
K
McMurray PA
Need some help on the quarter window install on my challenger. I think I’m missing something or assembling incorrect.
I’ve seen the older posts with the diagrams but it doesn’t show clearly what I’m looking for.
I have the smaller bolt with the spring going thru the plastic piece that slides up and down the track, and the longer bolt I assume goes thru that bigger
hole in the pivot piece. It’s just that the hole is much larger than the diameter of the bolt. I’ve checked my bags of hardware and didn’t have any pieces
that look like they would go into that hole.
Any and all advice is appreciated.
Thanks,
Kevin
Re: 73 challenger quarter window [Re: Kevin E] #2858376
12/11/20 07:57 AM
12/11/20 07:57 AM
MD
floyd Offline
floyd  Offline
MD
It’s been awhile since I installed mine and this is the only picture I have handy. I think you’re talking about this attachment right?
Re: 73 challenger quarter window [Re: floyd] #2858384
12/11/20 08:20 AM
12/11/20 08:20 AM
McMurray PA
K
Kevin E Offline OP
Kevin E  Offline OP
K
McMurray PA
Yes, that is the one. It looks like I need the black piece that slides over the longer bolt. Am I correct in assuming the bolt and spring go into the slide that mounts to the middle hole in the glass assembly?
Re: 73 challenger quarter window [Re: Kevin E] #2858421
12/11/20 09:38 AM
12/11/20 09:38 AM
MD
floyd Offline
floyd  Offline
MD
Here’s a pic installed.
Re: 73 challenger quarter window [Re: floyd] #2858439
12/11/20 10:05 AM
12/11/20 10:05 AM
McMurray PA
K
Kevin E Offline OP
Kevin E  Offline OP
K
McMurray PA
Great thanks so much! It makes it easier to see that way.. thanks for the quick replies. I’ll get those plastic guides ordered today. Your
parts cleaned up really well. Thanks again
Re: 73 challenger quarter window [Re: Kevin E] #2858498
12/11/20 12:06 PM
12/11/20 12:06 PM
MD
floyd Offline
floyd  Offline
MD
NP. I had all my window hardware soda blasted. It did a really nice job removing all the dried crud, etc.
