Re: comp cam xx series SFT
[Re: mopar dave]
#2858655
12/11/20 05:23 PM
12/11/20 05:23 PM
Posts: 4,221 West Plains, MO
DrCharles
West Plains, MO
Back in the day, I switched from a 635/645 - 276/280@.050 mushroom solid(similar to Mini Express) to a Comp 720-274@.050 roller in a 451/400 12.0 CR with valve pockets & OK piston to valve clearance ported 906's, tunnel ram w/ 2-650 DP's. The roller was over a tenth & 1 1/2 MPH slower. Comp re-ground the roller to 660/280 which was equal to the mushroom in performance. I bought a used Mini-Express and lifters for a good price, and sent them off to Schneider Cams for restoration of the lobe taper and the lifter bottoms. They measured the cam at the advertised .654 lift and 278@.050. The original lash spec I think was .024/.028 with 1.5 rockers, which is only about .630 net lift (before pushrod flex, etc). After regrinding, it measured out at .652, 272@.050, and they recommended .018/.018 lash. So there's now .634 net lift. It has a 107 LSA and I put it in at 105. Moderately intimidating idle in my 451 at 1200 rpm, 8" vacuum, 27 degrees idle timing, and it absolutely hauls ass above 3000 rpm. It's very useable on the street with 3.91 gears and a four-speed. Haven't found the high end of the powerband yet on the street! Anyhow, everyone who's tried the Mini loved it, and it's a lot cheaper to install than a full roller setup. As the Direct Connection used to say, "Comes very close to roller cam performance at about half the cost"
[Re: mopar dave]
#2858695
12/11/20 06:52 PM
12/11/20 06:52 PM
Posts: 11,825 Portage,michigan
B3422W5
Portage,michigan
Yes, in the flat tappets the Howards 274/280@50 looks good on paper as i run it thru dynomation5. Hughes 272/274@50 is a bit better. Howards makes all the cams for Hughes. Anything you see Hughes sells is in the Howards catalog and available to be made.
69 Dart GTS A4 Silver All steel, flat factory hood, 3360race weight 418 BPE factory replacement headed stroker, 565 lift solid cam, footbrake street/strip car
1.41 best 60 foot 6.54 @ 105.20
[Re: mopar dave]
#2858713
12/11/20 07:24 PM
12/11/20 07:24 PM
DrCharles
West Plains, MO
Never heard of this Mini-express til today. Who made them? Whats the lobe sep on yours? I don't know who ground them for Mopar, but it was Direct Connection/Mopar Performance part number P3690588. My post says LSA 107 It's pretty similar to a Racer Brown mushroom. There was also an even bigger one, .690 lift with 328 seat duration (mine was originally 316, now 312). Don't know the .050 duration. The DC Engine bible said it made 10 hp more than the .654 but "does lose some low end torque".
[Re: Dragula]
#2858856
12/12/20 08:43 AM
12/12/20 08:43 AM
Posts: 8,182 Mt Morris Michigan
mopar dave
Mt Morris Michigan
Your bobweight is lighter than mine. I'm, at 2100. In your vids i noticed your engine revs super fast. That is a badass cam with 196* duration at .200". I do less than 1000 miles on the street per season. Do you think that cam would be an issue on the street? I still need to research Bradh posts about victor install height limits to see what kind of spring i can fit. I would want that cam on something less than 110* with my heavy 3400#. One other thing. Do you have a timing curve in it or locked out and what at total?
[Re: B1MAXX]
#2858886
12/12/20 10:27 AM
12/12/20 10:27 AM
mopar dave
Mt Morris Michigan
I read his bobweight as 2060. I'm not concerned about street manners as i have manual brakes and steering. Its basically a race car with a full interior(5500 stall). I'm concerned with spring and roller lifter longevity on the street and looking at his specs show a very steep ramp. Not sure that i can make his cam work with my limited install height. Could do a custom grind with less lift and on a 108, but not sure how that would affect the performance characteristics of that cam. How much compression in your 511?
[Re: mopar dave]
#2858932
12/12/20 12:01 PM
12/12/20 12:01 PM
Thumperdart
State of confusion
Lift and duration have little to do with it being "street able" or not it's the aggressiveness of the lobes that dictate that and my .680.660 Isky has the most aggressive street lobe available at the time I bought it years ago.....
[Re: mopar dave]
#2858945
12/12/20 12:34 PM
12/12/20 12:34 PM
Posts: 10,180 Frostbitefalls MN (Rocky&Bullw...
gregsdart
Because of lobe wear? One other thing, The xx series produce a stable valve train at 8500 continues rpm. Not sure how they do this with a large cam. Intensity at the start of the ramp and up somewhere around .150 tappet lift would be the acceleration, or highest load area of the cam. Comp used to sell a 268 @ 50 hydraulic with .540 lift. I believe it was based on a .842 sbc tappet diameter. I used it to go 10.15 at 131 mph in a 475 cube motor with unported 440-c heads, 3180 race wieght running a lowly 750 holley methanol carb. So a super agressive cam isn't always needed to produce some decent power. I shifted that motor at 5800 or 6000 rpm. Ran the same.
8.582, 160.18 mph best, 2905 lbs 549, indy 572-13, alky
